Technical Does your hot rod or custom have any leaks?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 7, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Over the years I have been plagued with a leak or two with my hot rods, sometimes hard to locate where it's coming from other times it's obvious.
    A small transmission fluid leak can leave a huge puddle under the car and a generally easy fix, often it's just a mater of tightening a bolt or replace a gasket.
    Most of my oil leaks can be traced to my valve covers, how do you guys make your engines leak proof, or can that possibly be done? HRP
    3W JOHN likes this.
  2. error404
    error404
    from CA
    surprisingly, my 33 is the only vehicle I have that doesn't leak! I'm sure it'll be leaking when I'm done with it though, hah
    my 46 Willys I used to park it over a large (4'x3'?) concrete mixing tray. Engine, transmission, transfer case, and front diff always leaked. haha
    3W JOHN and HOTRODPRIMER like this.
  3. Boneyard51
    Boneyard51
    My avatar car, has a bad transmission leak, but I plan on replacing both the engine and transmission with larger units, so I just let it leak now and put a pan under it. Seems like I don’t sweat the small stuff as much... anymore.
    Bones
  4. squirrel
    My Chevy II has not been leaking at all for a couple years now. It's spooky!
    but my old pickup truck leaks, so all is not lost.
  5. mad mikey
    mad mikey
    They all leak. Sooner or later. Its unavoidable, LOL.
    wicarnut, 3W JOHN, Sandgroper and 3 others like this.
  6. rustydusty
    rustydusty
    I have spent a fair amount of time trying to get my cars to not leak. Never been completely successful! If it's not leaking, it's probably out of oil...
    wackdaddy, vtx1800, 3W JOHN and 4 others like this.
  7. ct1932ford
    ct1932ford
    Flatheads leak, period! That front seal does anything but seal.
    mad mikey, 3W JOHN, WB69 and 8 others like this.
  8. AVater
    AVater
    Both my rides don’t have valve covers yet still manage to leak some oil. Mark nailed it.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Yes gentlemen, my flathead front deal didn't! :rolleyes: HRP
    3W JOHN, ct1932ford and Boneyard51 like this.
  10. dirt t
    dirt t
    Hot Rods don't leak , there marking there territory.
  11. jim snow
    jim snow
    Yup. Just keep diapers under it. Check fluids often. Snowman
  12. 2935ford
    2935ford
    I'm on gasket set 3 to try to stem the flow from the front oil pan with my SBC 327.
  13. AldeanFan
    AldeanFan
    The original 239 y block in my wagon leaked every type of fluid, transmission, power steering, oil, coolant and the carb seeped.
    The new 292 has no leaks sofar :) I’m super picky about installing gaskets and will spend a lot of time with a hammer and dolly straightening flanges.
    The car still has a power steering leak but only in the winter. Each spring I add a bottle of Lucas power steering stop leak and it won’t leak all summer. Over the winter the seals dry up and it leaks on the floor of my friends garage where I store her.
    The windows all leak but I try not to drive it in the rain.
  14. 49ratfink
    49ratfink
    my Dodge Dart has a differential leak, the motor is still tight from a rebuild 30 years ago.
    my daily has an intake leak and I don't want to fix it. you can see the giant black spot where I park on Google Earth
    3W JOHN, Sandgroper, Stogy and 2 others like this.
  15. have had really good luck with The Right Stuff. that stuff is amazing.
    mad mikey, 3W JOHN, LBCD and 3 others like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    leaking is not the car's fault... It is the oil trying to find its way back home.....
  17. squirrel
    Might be that the gasket isn't the problem...try replacing the timing cover and/or oil pan. If either of them are aftermarket chrome, especially...see if you can find good old OEM original old parts.
    nunattax, Nick O, RICH B and 6 others like this.
  18. Gman0046
    Gman0046
    Down to one car my 60 Pontiac Bubbletop, less then 400 miles on it. To new to leak.
    3W JOHN, HOTRODPRIMER and Boneyard51 like this.
  19. 51504bat
    51504bat
    Not a good thing when you park cars in the house:)
  20. 56shoebox
    56shoebox
    I concur. Much like a Harley, it's simply marking its territory.
    3W JOHN, Stogy, HOTRODPRIMER and 2 others like this.
  21. da34guy
    da34guy
    You need to get out more Gary.
    3W JOHN, Sandgroper and HOTRODPRIMER like this.
  22. DDDenny
    No car leaks here but the owner does!:eek:
    vetteguy402, 3W JOHN, 56don and 2 others like this.
  23. Boneyard51
    Boneyard51
    Back when I working...... my OT daily driver had a huge leak, that kept my frame from rusting! Lol
    I parked in the same spot every day. Between the oil, carbon, dirt and whatever, I was getting a fairly big thick spot. Being a public garage, I got a lot of salesmen coming through trying to sell me everything in the book! If it was a chemical salesman with cleaners....... I would send him out to THAT spot! Told him if his product cleaned that spot , I would buy.....never bought a thing! But it sure sent them on their way! I kinda liked that spot! I’ve been retired 7 years now, and it’s almost gone.
    Bones
  24. HOTRODPRIMER
    HOTRODPRIMER
    Mark, you ain't right! :D HRP
  25. ct1932ford
    ct1932ford
    Did you put oil in it?:confused:
  26. ct1932ford
    ct1932ford
    Actually only one leaks there.:rolleyes:
    3W JOHN, Stogy and HOTRODPRIMER like this.
  27. Stogy
    Stogy
    I challenge any Harley for the Championship of #1 Oil Leaker...:D...and Secondly I think The Ole Hotrod might not be a Witch as I don't think it would Float...:eek:
  28. Slopok
    Slopok
    I simply have an engine that doesn't use valve covers!;)
    3W JOHN, clem, Boneyard51 and 2 others like this.
  29. typo41
    typo41
    Chicks roadster leaks a bunch because we like the look of a fined oil pan,,, the fined oil pan come from across the pacific ocean, where they make all thing metric,, so the pan seal ****s,,, but it looks cool.
    So the drip-pan under the motor had almost more oil than the motor,,,
    But we have a new clean-up solution,,,
    For those of you that have kids or aged parents, a absorbent bed pad under the motor grabs the oil and after a while, a proper disposal takes care of the once oil soaked floor
    3W JOHN, Jibs, Stogy and 1 other person like this.
  30. AldeanFan
    AldeanFan
    I had a friend with an MG, leaked a quart of oil per week and the underneath was always soaked in oil, somehow the floors still rotted out.
