Garage windows
Discussion in 'The Antiquated' started by WastedYouth666, Oct 8, 2019.
  1. WastedYouth666
    WastedYouth666
    I recently moved into a house with a garage built in the 60’s that has the old metal frame nine pane windows does anyone know where I can get the props and locks?
  2. Petejoe
    Petejoe
    from Zoar, Ohio
  3. WastedYouth666
    WastedYouth666
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    No you have to start by joining the forum.
  5. WastedYouth666
    WastedYouth666
    Ok thank you sir
  6. deathrowdave
    deathrowdave
    from NKy
    My garage has 3 double pane sliding windows . I found a piece of old iron railing with the c channel at the top and bottom . I cut the bottom off marked and drilled into the casing lowered the railing into the holes about 3 inches , and bolted the top inside the c channel with 3 in lag bolts for security . Opening the windows spring and fall , and relaxing with the radio , it’s about as good as it can get .
    1morecarIpromise! likes this.
