Customs Corvair transmission question
Discussion in 'The Hokey Ass Message Board' started by conn.rod, Oct 9, 2019.
  1. conn.rod
    conn.rod
    from atlanta
    Ok, I came across some old chopper books, I know thus isn't a chopper board but. The article I was reading was about a trike called Cinderella cart. It was built around 1970, it used a corvair engine, trans and 3rd member. I did some research and it is said guys had to mount the trans in an inverted position to be able to utilize forward and reverse property. Has anyone ever seen this done? I mean, my idea of inverted is upside down and, how would s 2 speed powerglide get trans fluid.
    Sent from my SM-G955U using Tapatalk
  2. squirrel
    looks like the engine is installed in front of the transmission/final drive, so yeah, it would be backwards. The final drive is what would need to be inverted, but not the transmission. Wonder how he did it?
    maybe if you post pictures that show more of it, we could figure it out?
  3. conn.rod
    conn.rod
    from atlanta
  4. conn.rod
    conn.rod
    from atlanta
    Ok, I think after reading and putting pictures together from earlier, I think I understand. If I'm not mistaken, the third member is right off the engine, then the trans. The third member/ring and pinion is inverted, not the trans. I did not realize the configuration until I looked at pics again[​IMG]
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Too bad Don Kendall isn't still around ,he knew how !
    What about the crown kits , a v-8 was installed forward of the trans ....
  6. conn.rod
    conn.rod
    from atlanta
    Idk, I read this, it really got my interest and I got curious. I'm the type of guy, if I got questions, I'll ask and hopefully, someone knows the answer
