Technical Strange 400 Pontiac engine
Discussion in 'The Hokey Ass Message Board' started by Johnny G 500, Sep 11, 2019.
  1. Johnny G 500
    Johnny G 500
    I coudnt see anything under the car but I found this under the distributor.... see picture.
  2. Johnny G 500
    Johnny G 500
    I also found a 97790 on the driver side
  3. Johnny G 500
    Johnny G 500
    I think I found a transfer lug too... see picture
  4. Johnny G 500
    Johnny G 500
    I removed a spark plug wire and found a 9336
  5. Joe H
    Joe H
  6. Johnny G 500
    Johnny G 500
    So Joe, you think it's a 428? Why do you think the block is stamped XJ in the front? Could they have used a 428 block for this 400 engine? It is the original engine for the car and has regular valve covers and air cleaner. I understand that the 428 had chrome valve covers and air cleaner.
  7. kidcampbell71
    kidcampbell71
    Valve covers can be changed. Although ... in 1969, you wouldn't have to change from chrome valve covers. That was the lower horsepower year, with painted covers.
    Previous years, '67, and '68 had chrome valve covers, and the higher hp engines. 370 plus. '69 was a torque monster, but about 100 hp less.
    I'd take any year of those engines. My parents' neighbor has a '69 Bonneville convertible with a 428. It will definitely, get out of it's own way.
  8. 51 Hemi J
    51 Hemi J
    Is there any chance you could take a photo of your Engine Code stamping? You may want to s****e paint if needed. I am leaning toward it being a 67 400, 350 HP, 10.5:1 Compression with 670 heads. I seem to recall running across a 400 block with the transfer lug, but let me check my sources on that one. I have a block that I need to check at my folks place and its quite buried so It may be a while, sorry.
  9. Johnny G 500
    Johnny G 500
    Where would I find the engine stamping? i found some numbers in the pictures I posted above.
  10. kidcampbell71
    kidcampbell71
    67' up, will have a code, stamped on the p***enger side block, under the p***enger side head, indicating the car that the original engine, came out of.
    Having said that, with the casting codes, etc ... that you have thus far, ac***ulated ... this next web page may help zero it in, further.
    http://www.pontiacpower.net/numbers/
  11. Elcohaulic
    Elcohaulic
    670 heads are decent heads. They are the last of the closed chambers but have the new big valves..
    I always thought the closed chambered heads ran better on street engines... I always wanted to put a set of closed chambered heads on a 455/462.. I think they made low compression heads in 67 with the big valves and closed chambers. Put a Nunzi 2041 cam in there, have the machine shop install screwed in rocker studs and your set..
    http://ronspontiacpage.com/reference-pages/nunzi.htm
  12. Johnny G 500
    Johnny G 500
    Thanks everyone for the help. From everything I can gather, I believe my block is a 400 block but Pontiac included some 428 parts. The transfer lug is there but not a pyramid, it has a flat top so I wonder if they used whatever parts they had to build the engine. In any case, when the engine was rebuilt, the engine shop spec'ed it to a 428. I just need chrome valve covers and air cleaner and away I go. Thanks.
  13. Johnny G 500
    Johnny G 500
    I took a picture of a friends 428 engine and he has the exact looking transfer lug as I do. Now I don't know what I have again. I have attached a picture of his engine near the distributor. Is that the transfer lug on the top?
  14. Johnny G 500
    Johnny G 500
    Mine looks like this
  15. lostone
    lostone
    from kansas
    If its a 428 it will say 428 between the freeze plugs.
    If its a 428 its stamp codes will list it as a 428. The stamp code location was given above. Pad on front of block on p***enger side just below the head.
    What is the codes on the pad?
  16. If it is actually stamped XJ , that pretty much narrows it down to a 1969 428 .
    Not a 400 and not an original engine..Bad info
    (Yes, I know about the 67 heads but it's been apart and rebuilt so whoever did it originally may have wanted the 67 400 appearance)
  17. Joe H
    Joe H
    Yours will be stamped just like this 455,
    First photo shows the transfer lug ( ONLY used on the big engines 421, 428, 455 ) and casting date ( 1971 for this block )
    Second photo shows the lifter galley, with " 55" cast into it, for 455
    Third photo, 455 cast in side of block behind dipstick
    Forth photo, 455 cast into side of block on drivers side front
    Fifth photo, shows engine code stamped into the p***enger side front of block.
    Yours will have all the same markings. Pontiac did not install 428 pieces on a 400, someone else might have, but the factory never did. And again, 400s did not have the lug on the rear of the block, that was there to identify the bigger engines on the ***embly line.
    Deuces, Johnny G 500 and Mark Yac like this.
  18. This has been said 47 times already,,,,
    It’s getting old already.
    I don’t know what this engine is,,, Pontiac must have installed large journal parts in my 400 because it’s got painted valve covers.
    Sell the damn car or go buy a flashlight.
  19. lostone
    lostone
    from kansas
    31vicky if i ever run into you in the wild remind me i owe you a beer !! :D
  20. Absolutely,,,,,,!!!
    It is cast into the block near the freeze plugs,,,they have even shown pics of where it is.
    Unless you have a health issue and can’t get down on the ground.
    Jack it up and look,,,really easy to see.
    If not,,,get a friend to help,,,maybe they can see it.
    They are right,,,,Pontiac did not put different parts in there from the factory.
    Tommy
  21. I don't know but changing the badges might turn into a real project here;)
  22. Johnny G 500
    Johnny G 500
    Thanks to everyone. I also owe 31vicky and the rest of you beers as well.
    Deuces likes this.
  23. Tequila for me please.
    I’m allergic to beer
    Deuces likes this.
  24. And then..the verdict is ??
  25. DDDenny
    I don't know Pontiacs but I like beer!
    Does that count?
    Jet96 and Deuces like this.
  26. Okay! I'll bring the Cuervo Gold, you bring the beer, and we'll go over to Johnny G's and change the badges for him.
  27. DDDenny
    Let me look, I think I have some bowtie badges lay'n around!:D
    Deuces and GordonC like this.
  29. JC Sparks
    JC Sparks
    from Ohio
    He could have pulled the head off and posted the bore n stroke by now and we would all be drunk.
  30. Ha ha..Actually don't need to measure a thing. a 428 piston is unique and easily recognized.
    Not sure about the head pullin' here .So far , no underneath picture of the block marking behind the fuel pump.;)
    kidcampbell71 and Desoto291Hemi like this.
