Hot Rods Garage lifts
Discussion in 'The Hokey Ass Message Board' started by flatford39, Oct 10, 2019.
  1. flatford39
    flatford39
    Life has been good to me lately and it looks like I might have the funds to invest into a 2 post or 4 post lift for my garage.
    My problem is that I only have 8'-0 ceilings in my shop. Just getting the vehicle up 4 feet would be handy and two of my cars are roadsters so they can get up a little higher with the top down.
    What have you guys with low ceiling like I have done??
    Thanks for any feedback. It's appreciated.
  2. Scissor lift or low rise 2 post.
    Scissor and 4 posts are great for body work. 2 posts are great for mechanical work.
  3. I have one like this.
    These work with a low ceiling. Gonna have to watch the roof
    8AF86F48-477D-4FFD-82CE-78FFD57ED0D7.jpeg 9F0B486B-B34D-4E2D-93E7-BE74D06BAFD1.jpeg
    flatford39 likes this.
  4. ramblin dan
    ramblin dan
    I too have a low ceiling but due to my project car being a lowboy I have just enough clearance for one or the other of my cars on top of my 4 post Direct lift. If you go with one keep in mind you have to have at least another two inches more travel up to release the locks so you can lower it and they lock at certain amount of inch intervals. I also had to extend my garage door to the very top of the ceiling and relocate the door opener to one side.You will not regret getting one even if you don't get a lot of height out of it.
    Bondo Slinger likes this.
  5. Flathead Dave
    Flathead Dave
    from So. Cal.
    I have a QuickJack system. Lift the car about 24 inches. Portable. $1500
    Bugguts likes this.
  6. Never2old
    Never2old
    from so cal
    Shop for one that offers wheels so you can work outside when you need the height.
  7. miker98038
    miker98038
    I did exactly as ramblin dan, including the close to ceiling garage door and side opener. Working under the car was usually on a rolling stool, sometimes on a creeper. It let me store two roadsters in the winter (needed the top down on both, so it was tight).
    The jack tray let’s you use a bottle jack for wheel and brake work, and my buddy has the sliding, locking jack that lets you lift the frame when parked on the lift. A**** our group we’ve got 5 of them, with no problems over 10+ years. The other guys have 12 ft shops which is better.
    I don’t sell these, I’m just a user.
    http://www.directlift.com/Four-Post-Lift-Pro-Park-8S-Standard-P44C9.aspx
  8. Never2old
    Never2old
    from so cal
    This one comes with wheels. Mine came with wheels though I’ve not used them.
  9. bobkatrods
    bobkatrods
    from aledo tx
    Before I built a new shop ,I used a mid rise lift,found a used one for 600,, not as good as a two post full height but a lot better than nothing
  10. TagMan
    TagMan
    Friend of mine had the same problem. He cut out a 6' or so section of the joists and boxed them in. He had enough room to raise the lift with the car on it so he could walk under it. That was 25 years ago and the roof is still in place with no harm done and that was in NYS with big snow loads.
    lothiandon1940 and Hnstray like this.
  11. My scissor will lift around 50’’
    Rolls out of the way easily and portable.
    I have carried it to at least 3 shops
  12. Dick Stevens
    Dick Stevens
    What model and brand scissors lift do you have?
  13. Phil P
    Phil P
    I have a maxjax 48" lift. Once it's installed it can be removed with only 10 bolts to the floor.
  14. ekimneirbo
    ekimneirbo
    As mentioned above, cut a rafter or two out and box it and a little additional bracing. Get a 2 post lift you can stand under. It will give you way more usefulness,......
    55styleliner likes this.
    (Generic online pic)
    It’s made by wheeltronic.
    Bought it used from snapon
    It’s perfect for body work.
    I can load it with an engine hoist
    Chavezk21, gnichols and Dick Stevens like this.
  16. Flathead Dave
    Flathead Dave
    from So. Cal.
    Is your system on wheels?
  17. Phil P
    Phil P
    The power pack is on wheels and is connected to the 2 posts with quick disconnects. After you un bolt the posts from the floor there are small wheels on the bottom so you can move them like a dolly. If you wanted to use it in more than one location you can buy anchors separately and put them in the floor in a second spot.
    Phil
    Flathead Dave likes this.
  18. Flathead Dave
    Flathead Dave
    from So. Cal.
    Just watched a MAXJAX video. Cool lift.
  19. Mr48chev
    I've got a buddy who did the make space between the rafters thing on his shop when he put the lift in and was working on raised roof vans for a company daily. That should work if you have enough room up between the bottom of the rafters and the roof and you will have to put in 2x8 or 210s to support the area you cut the rafters out of. Box the other rafters with plywood as the guys said.
  20. oldwood
    oldwood
    from arkansas
    I moved my house 'in 89. 2k sq ft for a $1000. I found a old lady that had 1 block. I bought 2 lots and started my 5 yr rehab. The slope of the land created 17 ft ceilings. Bought a 2 post lift from a friend who was down sizing his business.
  21. COCONUTS
    COCONUTS
    I believe that most lifts, 2 post or 4 post that bolt into the floor, required 6 inches of concrete.
    Jalopy Joker likes this.
  22. dave 62 pb
    dave 62 pb
    I have same problem, the workshop I am about to put up is 11 foot to the ridge inside
    I have to either raise the roof or in stall a shallow pit 2 foot deep so I can stand under and work on cars/mini van Been looking at a 5 foot lift portable 2 post lift where the securing plates are bolted to the floor so you can store away the posts when not in use so free up floor space , I was given this workshop on the condition I had a week to dismantle and transport away DSC_0537.JPG DSC_0538 (1).JPG
  23. Phil P
    Phil P
    When you re***emble this building you should be able to put it on knee walls as high as you need.
    Phil
    H380, Frankie47, tb33anda3rd and 4 others like this.
  24. partssaloon
    partssaloon
    I have a door out the back and did this.
    jim snow, Frankie47 and Fiftee3 like this.
  25. dave 62 pb
    dave 62 pb
    Thanks, did think along those lines , the steel frame is roof support only so also thought of extending those or sitting them on 2 foot concrete block pads and adding extra steel to the end A frames
  26. Olds Dad
    Olds Dad
    I recently installed a MaxJax M6 & I’m pretty happy with it. My ceiling is ~8’-9”. Lifts stuff high enough to scoot around underneath on a roller stool.
    IIRC the installation instructions wanted 5” of concrete.[​IMG][​IMG][​IMG]
  27. Jalopy Joker
    Jalopy Joker
    just chop/section all of your rides
  28. dirty old man
    dirty old man
    My son has a long term resto mod of an OT car in the way right now, but if he gets through with it before I die, I want to try a Max Jax myself. A friend has put one is his shop and , and I've been over and looked at it.Got to first drill a few test holes to determine concrete thickness before I buy one though, as I bought this old building and it was built in the late 40s.
    There's several threads on this subject over on Garage Journal, btw.
  29. gnichols
    gnichols
    from Tampa, FL
    Good to know stuff. Great thread.
  30. ekimneirbo
    ekimneirbo
    If you just want to raise things a few feet, shop around for some of those used air bumper jacks that used to be popular. Put one at each end of the car and raise it to the desired height. That way they are not in the way while working on the car. Then stow them by the wall when done. I have a frame for a 56 Chevy truck that I'm working on and thats how I do it. In another bay I have a two post lift. It makes doing things underneath a vehicle much much easier. I know some of the guys here have said they have the lifts that raise things a few feet, but for the cost, I would want a full on lift. These jacks show up on CL for $150/$300 if you watch for them. PICT1553.jpg
    stanlow69, Budget36 and flatford39 like this.
