Projects Kicking the T bucket build
Discussion in 'The Hokey Ass Message Board' started by raven, Oct 8, 2019.
  1. raven
    raven
    Does anyone have an extra T frame front cross member they would part with. I’m trying to use as much original T parts on the frame as I can. No use building a cross member when Ford already made them.
    r
    Thor1 and loudbang like this.
  2. DDDenny
    Riiight!
  3. OFT
    OFT
  4. OFT
    OFT
    Hard to see the front plate, best picture I have.
    Thor1, gonzo, pitman and 1 other person like this.
  5. loudbang
    A little bigger shot :)
    Thor1, charleyw and OFT like this.
  6. raven
    raven
    With the spring on top of the mount did you realize any difference in handling?
    r
  7. OFT
    OFT
    Not really as it was set up that way when I built it for lowness. It had 4.10 gears with a 5 speed that was non overdrive. Handled like it was on rails:). Blast to drive with the 153" Chevy II motor.
    It handled lots better than "fad T" I had in 80's (sold in the late 80's).
  8. OFT
    OFT
  9. raven
    raven
    Steel came in and I was able to complete the perimeter of the frame. I’ll need to make some adjustments before I move to the next thing, but it’s closer to rolling now.
    r
    Thor1, Stock Racer, AHotRod and 6 others like this.
  10. raven
    raven
    Just a note, never be afraid to redo something. I wasn’t happy with the frame and started to remeasure everything. Was a little out of square. Realized tha one frame rail was ahead of the other a little. Came up with a plan of action and started cutting specific spot welds to relieve the frame. On the last cut, the game did it’s best Jenga impersonation. I just had to laugh. I had rushed a bit of the first time. Took it almost all apart and started again. Got it back together and am much happier with it now.
    r
    Thor1, Blues4U, brEad and 13 others like this.
  11. Roothawg
    Roothawg
    Go man Go! I have a similar pile of parts I may throw together.
  12. You're not going to run those hairpins like that are you? Don't you know that it will turn your rear end into a sway bar? :rolleyes:
    Sorry I just could not resist. :D
    Movin right along looks good.
    Thor1, Tim and loudbang like this.
  13. raven
    raven
    :p
    Got the rear suspension tacked in.
    Now to start making upper mounts for the coil overs.
    Just need to cut the tubing and weld.
    Mounts from scratch.
    r
    Thor1, brEad, Stock Racer and 5 others like this.
  14. raven
    raven
    A little update, got the rear half of the frame sitting on its own.
    Coil overs mounted with the adapters I had to build to go from stud mount to eye mounts. Had to redesign a couple of times but moderately pleased with the outcome.
    The coil overs can be changed out to eye mounts at both ends of someone wanted to. I just used what I had.
    [​IMG][​IMG][​IMG]
    Test fit the body to discover what needs to change and found a couple of things that I will have to redo or rethink.
    First the ladder bars interfere with the turtle deck.
    Thor1, brEad, Stock Racer and 4 others like this.
  15. raven
    raven
    I think that I will bring in the rear mount another 1.5” on each side and move the front mounts out to be flush with the outside of the frame. I’ll have less angle to the ladder bars in relation to the outside of the frame but as light as the car will be, it shouldn’t pose a problem. It will be more like the rear ladder bars on my 27 roadster and it’s worked exceptionally well over the years.
    Another issue is that I can’t use the fuel cell I had for this.
    It fits where I wanted to mount it towards the front of the turtle deck but the center of the rear end is in the way of the sump on the rear of the fuel cell.
    So I’ll be using a cylindrical tank instead.
    With the body sitting on the frame, I can start designing how I’m going to mount it on the frame.
    I hate the actual fibergl***ing so I am toying with the idea of building everything on the frame (floor, seats/mounts, dash hoop) and making the body just slip on over everything.
    There are a couple 60’s T buckets that were built like that although they were drag cars, but I’m thinking why not?
    There is one in particular I am referring to. It was a cover car with a chrome frame and the body was panel painted white with green metallic panels.
    r
    Thor1, tb33anda3rd, Tall t 26 and 7 others like this.
  16. F0B92F3A-EB71-4ED0-8B81-E91D01A55752.jpeg Gr***hopper?
    scott27, Thor1, tb33anda3rd and 7 others like this.
  17. alchemy
    alchemy
    As an homage to the Gr***hopper, you could name yours after an insect too. How about paint it orange and call it the Lady Bug?
    Thor1 likes this.
  18. sodas38
    sodas38
    Looking good Raven!
  19. Roothawg
    Roothawg
    Insect names on cars is gay...
    Thor1, Tman, iwanaflattie and 2 others like this.
  20. raven
    raven
    YES, that’s it!
    I love that car.
    r
  21. raven
    raven
    There will be nothing ‘lady-like’ about this car...
    r
  22. alchemy
    alchemy
    HAMB Drags Battle of the Insects!
    Thor1, Tman, Stogy and 1 other person like this.
  23. raven
    raven
    LOL
    r
  24. Rocky
    Rocky
    Classified Editor
    Grudge race between the "Fly" and the "Gr***hopper"! Runnin for pinks at MoKan!
    Thor1, Roothawg and loudbang like this.
  25. Tim
    Tim
    from KCMO
  26. upspirate
    upspirate
    No pan hard bar or watts link?
  27. Tim
    Tim
    from KCMO
    It’s literally tacked together dude give him a minute lmao
    gonzo and upspirate like this.
  28. raven
    raven
    It will have a panhard bar. I learned my lesson on my first roadster, tack everything first, then when you have caught all the gotchas, do a final weld. The body will be on and off several times during this build. That’s just the way it goes.
    r
    Thor1, gonzo, OFT and 2 others like this.
  29. raven
    raven
    Tim, thanks for that video.
    I want to do a roll bar like that, it mounts to the side of the frame.
    r
    Thor1, brEad and Tim like this.
  30. lake_harley
    lake_harley
    Interesting coilovers. The bottom looks like a homemade bracket to mount them, but the top (and they appear inverted) looks more like a regular coilover with the adjuster sleeve. Care to educate us?
    Lynn
