Projects Who’s running 16” Steelies on their hotrod??
Discussion in 'Traditional Hot Rods' started by hotrod fozzie, Oct 13, 2019.
  1. hotrod fozzie
    hotrod fozzie
    Ok I have a question is anyone running 16” original steel ford wheels on there hotrod? I am looking at a set but not sure if they will be the right thing for my 1927 T roadster? Would I want 16’s on all four corners or just out back?? They are off a 1947 ford .
    Stogy likes this.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
  3. don colaps
    don colaps
    Why would you not? It seems like a good idea.
    Skickat från min iPhone med H.A.M.B.
    Stogy likes this.
  4. hotrod fozzie
    hotrod fozzie
    anyone got any pictures of some on a roadster just curious what they look like?
  5. flatford39
    flatford39
  6. scrap metal 48
    scrap metal 48
  7. hotrod fozzie
    hotrod fozzie
    these are the wheels i am looking at supposed to be orginal 48 ford wheels
    tinsled, Stogy and classiccarjack like this.
  8. hotrod fozzie
    hotrod fozzie
    looks awesome !! 16' all way around??
  9. scrap metal 48
    scrap metal 48
    Yes.. 4.50/16 front, 7.00/16 rear....
    clem and lothiandon1940 like this.
  10. 55styleliner
    55styleliner
    1940 Ford 16s front and back. 7.00x16 on the rear, 5.00x16 on the front
    catdad49, tinsled, alanp561 and 11 others like this.
  11. keith27T
    keith27T
    Me[​IMG]
    catdad49, tinsled, don colaps and 3 others like this.
  12. keith27T
    keith27T
  13. harpo1313
    harpo1313
    from wareham,ma
    If its a good deal , snap them up , they look nice.
    Stogy likes this.
  14. ric
    ric
  15. Inked Monkey
    Inked Monkey
  16. choptop40
    choptop40
    Got 16 s on my 40 Buick IMG_0777.jpg ...yeah , cant get anymore traditional....
    tinsled and Stogy like this.
  17. xix32
    xix32
    If you are building a post WW2 style car, It's gotta be those.
  18. ct1932ford
    ct1932ford
    40 Ford 16 x 4 rear 16 x 3-1/2 V8 60's front IMG_6249.JPG
    catdad49, tinsled, alanp561 and 7 others like this.
  19. adam401
    adam401
    The T has 40 Ford 16" up front and GM 16's in back. The coupe has 41 Lincoln rims in back and 38-40 Lincoln rims up front. Both 16"
  20. 50DropTop
    50DropTop
    Like @s**** metal 48, I’m running wide 5 16s all the way around. 5.50s in front, 700 rear.
    4044480C-07A4-41F0-8E55-1C15332F6230.jpeg 2D9BB944-49CD-4196-A59B-10C9578A193D.jpeg
  21. Aaron D.
    Aaron D.
    4" 40 Ford fronts, 4-1/2" Fords in the back.
  22. dwollam
    dwollam
    My avatar has '40 16's on the front and the slightly wider '48 16's on the rear.
    Dave
    catdad49, tinsled, Jet96 and 9 others like this.
  23. hotrodjack33
    hotrodjack33
    Here's a great (cheap) trick for running 16" steel rims on your rod with a Ford 4.5 bolt pattern. I used a set of 1940 Dodge 16' rims on my Sedan Delivery when I first built it (HAMBer Hamtown Al now owns it). 30's-40's Mopar rims use a 4.5 bolt pattern same as later model Ford 8', 9' rears & Mustang II's and bolt right up. The Mopar rims use "clips" to hold the hubcaps on, so I simply cut the guts out of the Mopar and Ford hubcaps and mounted the Mopar guts into the Ford caps.
    Finally got sick of the adventurous driving with bias ply tires and went to radials... sold them to a buddy of mine and they are still on his '32 5 window (600-16 & 750-16)
  24. Stogy
    Stogy
    Fall Bliss 16" Steelies
  25. 26 T Ford RPU
    26 T Ford RPU
  26. burl
    burl
    from Minnesota
    16 front and back on this beater.Lincolns on the front and ford on the back colorado.jpg
    catdad49, alanp561, Stogy and 2 others like this.
  27. I know it's been probably asked before, but any later rims available with 4.5" BP, and 16" diameter?
  28. Cliff Ramsdell
    Cliff Ramsdell
    I also run a set. 16x4 fronts with 425/450’s and 16x5 rears with 7.50’s. Hub caps and trim rings round it out.
    Cliff Ramsdell
    605FF0B3-C6A4-4527-AB55-DD17FB553D3F.jpeg 7230AE8A-A27C-461B-B3CE-2BB46445F3E6.jpeg F0706328-4C34-4EC4-8FE1-16EEF7912FF7.jpeg
    catdad49, tinsled, Jet96 and 5 others like this.
  29. wbrw32
    wbrw32
    "There " hot rod,or "their" hot rod?
  30. jazz1
    jazz1
    I would if I came across a set. My truck arrived with 15” although stock is 16”
