Hot Rods Are people still using Corvair steering boxes?
Discussion in 'The Hokey Ass Message Board' started by 31Dodger, Oct 14, 2019.
  1. 31Dodger
    31Dodger
    Might be a dumb question, but are people still using Corvair steering boxes on their hot rods? Found a couple of them and didn't know if they were still useful. Thanks.
  2. HOTRODPRIMER
    HOTRODPRIMER
    The Vega box kinda replaced the Corvair & Mustang boxes, and there are aftermarket company's making copy's of the Vega.
    I don't think I would be apposed to using one again as long as it was still tight, finding replacement parts would be rare & expensive, HRP
    31Dodger and dana barlow like this.
  3. Pete Eastwood
    Pete Eastwood
    from california
    Yes they have value.
    Corvair boxes are really good for T Buckets .
  4. If you can find them...........
    31Dodger likes this.
  5. i use one in my 31 Chrysler coupe. it works great. the one that are worth money are the 63 box. its aluminum and has a short splined shaft. the splines and shaft are the same as a vega. any street rod shop will have a coupler. as far as parts availability the upper and lower bushing are readily available at any bearing shop. it would be a rare day that the screw goes bad. theres not much else in them other than some ball bearings. the steering ratio is slow making it ideal for a race car.
    stillrunners, Hemi Joel and 31Dodger like this.
  6. 31Dodger
    31Dodger
    These are the items I found.... Picture 11035.jpg Picture 11037.jpg Picture 11036.jpg
  7. 31Dodger
    31Dodger
    The guy who has them used to have a T bucket, so that makes sense.
  8. looks like you have enough to make one. those are the right ones in most installations a angled mount is needed to put the steering shaft parallel to the frame. don't throw out the pitman arm I use them. I drill them out and use a bolt with a heim joint.
  9. willys36
    willys36
    Benn running one on my Willys G***er/street rod for 25+ years. Factory stock for a Willys g***er like early hemi engine, 4-spd Hydro ******, 5" riser blocks on front end, Olds rear end and one piece tilt 'gl*** front end.
  10. absolutely. still have 4 aluminum ones, already reversed. CCR plans give full scale plans for mount.
    stillrunners and 31Dodger like this.
  11. DDDenny
    A friend built a T-bucket about 1970, he used a VW bus steering box.
  12. adam401
    adam401
    As a former VW guy a tight split bus box that hasnt been over adjusted is harder to find than a good F1. I can see how reversing one must have been a good option though. At the time they must have been cheap and plentiful and the size is right.
  13. 31Dodger
    31Dodger
    Thanks a bunch for the replies, folks! MUCH appreciated.
  14. AHotRod
    AHotRod
    I use a reversed Corvair box in my Coupe
  15. willys36
    willys36
    how-to. Put the oil seal in the top nut and a plug in the old seal hole. Way simple.
    racer-x and Hnstray like this.
  16. Thanks for the pics on reversing the box. What is the reason or advantage for doing this. I have used a few of these boxes in builds and never reversed them. 20170319_184554.jpg 20170319_184519.jpg
  17. Fordors
    Fordors
    A cross steer application like yours doesn’t need to be reversed, but if mounting the box on top of the frame rail for a side steer application reversing puts the pitman arm pointing down. The box is too low if it’s mounted under the frame for side steer, although if it was under the frame rail then the pitman would point up.
    Jibs and Atwater Mike like this.
  18. 31Dodger
    31Dodger
    So....I hate to ask this, but what should I pay for the three boxes?
  19. willys36
    willys36
    Prices are definitely going up due to availability but I wouldn't pay over $35 or $40 each. If you aren't into nostalgia, new Flaming River, etc., are more cost effective alternatives.
  20. 31Dodger
    31Dodger
    Don't really need them, I just want to get them out to someone who can use them.
  21. the prices vary quite a bit. i have seen them at swap meets for 50.00-150.00 each
  22. Mr48chev
    The boxes have always been considered for LIGHT WEIGHT cars like T buckets or a rear engine rod if you are building something wild. Willys36's g***er probably doesn't have much more weight on the front than most T buckets.
    The main thing on a T was that they were easily reversed and that the case polished up real nice when they were newer and not as pitted.
    I had one of the old VW bus boxes on my T in the 70's when someone wrote an article about it and I found one on the cowl of a hacked up bus on someone's yard and got it for about 5 bucks. We had to modify the pitman arm by welding the end of a Ford Pitman arm to it but V notched one and cut the other to an arrowhead shape to fit the notch and a certified welder did the welding. That would probably scare hell out of guys now though. I think that one had the sector shaft coming out from under the frame and the pitman arm aimed up.
  23. willys36
    willys36
    If you use the 'Vair gear, don't use the split shaft coupling that Chevy supplied. I did and one day driving the car the steering wheel quit talking to the gear. Limped home and found the splines had stripped inside the split coupling. I replaced it with one from Borgeson and all has been well since.
    I think this happened on the donor cars too.. Back in the day my brother had a Corvair and I remember them saying "the steering wheel came off in their hands" or something like that. I was too young to diagnose the problem. They had it fixed by the dealer but I reckon it was the same failure I experienced.
    Used to see them on ebay for reasonable prices but just looked and there were 3 or 4 unreversed stockers for $240. Same price as new gears. Blush is officially off the rose?
  24. They are also asking a million dollars for a piece of toast with the likeness of jesus on it. There are no shortages of corvair boxes. I have found them for less than 50.00. If you pay those prices for them you got screwed.
  25. jimmy six
    jimmy six
    Looks like bad Akerman from my view.
  26. if it's the ones in the picture, 50 bucks for all three is about right.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Things must be cheap where you live , around here I'd say between $50-$150 depending on condition ( for all 3)
  28. Atwater Mike
    Atwater Mike
    Customer had an "Andy's Instant T", very clean maroon Fad car type, SBF, C4, 8" ****. I did some ch***is welding, and squared up front axle caster/toe, and balanced fronts.
    Nephew drove it out onto the street, and came walking back. He was carrying the Bell wheel and mast, complete with stripped out split shaft coupling from the worm shaft.
    Another repair to Ray's T Bucket!
    willys36 likes this.
  29. willys36
    willys36
    Yep. I know that song!!!
    Atwater Mike likes this.
  30. wrenchbender
    wrenchbender
    I run one in my dragster it was already reversed when I got it and I then just made my own pitman arm it works perfect I have been looking for another for a future project but I’m not giving big bucks for one but if it’s in decent shape and not broken I would give $50 bucks for one they are around I just haven’t looked real hard either lol
