Technical Water pump failing and 235 I.D. help!!!!
Discussion in 'The Hokey Ass Message Board' started by ALMAdeVENTA, Oct 14, 2019.
  1. ALMAdeVENTA
    ALMAdeVENTA
    Ok, if you seen my last post you know the story of my 51 overheating, got her all cleaned up and put back together, I was going to a car show this weekend and water pump started spraying coolant all over, no overheating this time "whew". Its the 2nd pump in 4 months from napa. It has the adapter plate between pump and block, I put it together like this (block - silicone gasket maker - blue gasket material - silicone gasket maker - adapter plate - silicone gasket maker - blue gasket material - silicone gasket maker - water pump) Am I overkilling it somewhere??? Fan belt is 5/8" wasn't over tight.......any ideas.
    Engine is a 235
    Block stamp goes like this
    CON 3 F189 F619A 3764476
    if I'm reading correctly block was used 1958-1962, this one was built Jun 18 1959 originally was on a 3 speed but she has a power glide now. Any help on this would be awesome!!!
  2. ALMAdeVENTA
    ALMAdeVENTA
  3. 6inarow
    6inarow
    Not sure but it looks like you have an early 235 water pump and adapter and a later 235 block. The later 235s had a different combo for balancer and pump pulley diameter. Looks to me like part of the problem is that the pump is being spun way too fast.
  4. ALMAdeVENTA
    ALMAdeVENTA
    Yes, pumps ive been buying are for a 51 235, how would i slow the spin? Larger pulley??
  5. 302GMC
    302GMC
    from Idaho
    I'd use a '55 up pump with a shortened shaft & skip all the glue ….
    ALMAdeVENTA, 6inarow and 54EARL like this.
  6. indianbullet
    indianbullet
    from Ca
    ALMAdeVENTA and 6inarow like this.
