My 235 Harper intake showed up today!
Discussion in 'The Hokey Ass Message Board' started by FormerFueler, Aug 22, 2011.
  1. flyingpiston53
    flyingpiston53
    from bristol ri
    The modular idea maybe right because I had to machine the ports to accept an insert that would hold the locating rings from the stock intake like I said before I put a good amount of effort into this setup but if i can't get it to run good I might just go with the offy and the rochesters
  2. Six Ball
    Six Ball
    from Nevada
    Here are some more Harper 3X2 pictures. Not mine just posting the pictures for all to see.
    100_2595.JPG 100_2597.JPG 100_2598.JPG 100_2599.JPG 100_2603.JPG 100_2602.JPG 100_2601.JPG 100_2600.JPG 100_2604.JPG
  3. Atwater Mike
    Atwater Mike
    That's SOME linkage geometry there...let alone splitting the throttle shafts in those Strombergs!
    Not 'new' to it, as I had years of Porsche, and split carburetor shafts were the manner in which Solex 2 bbl carbs were synced. Still, the practice of doing it is unusual, so the curious onlookers at the drags, etc., would be sure to ask about it...
  4. Budget36
    Budget36
    What do you guys mean by "splitting the throttle shafts"?
  5. Six Ball
    Six Ball
    from Nevada
    The throttle shaft on each carb was cut in the middle so each 1/2 of the 2 bbl worked independently. One side of each hooked together made the primaries the other side was the secondaries that came on progressively. This evened out fuel delivery on inline engines rather than using a center carb in the middle of the engine as primaries and carbs one the ends as secondaries. Each carb fed an intake port and a large runner was not needed, just the small tube to even out the vacuum. The other choice is all 3 all the time, not really the best street choice.
    Tow Truck Tom and Budget36 like this.
  6. Six Ball
    Six Ball
    from Nevada
    I see my last post here was about 1 1/2 years ago, but today I got a package in the mail from an old high school buddy. Old- we graduated in 1963. In the package was a Harper 3X2 set up with 3 Ford carbs. I haven't checked it out closely but at least one carb has a split shaft. Not all linkage is there but the most critical piece on the center carb is there. I'll get a better look at it tomorrow and try and post some pictures. My friend said it is for a 270 GMC and that is why he sent it to me. This is only the 3rd one of these I have actually handled. I'd love to get it on my pickup.
  7. lumpy 63
    lumpy 63
    Holy crap! someone had some sleepless nights concocting the throttle linkageo_O
  8. Fortunateson
    Fortunateson
    So that's what Toad asked that guy at the liquor store to buy for him....
    Hollywood-East, 6inarow and 302GMC like this.
  9. Six Ball
    Six Ball
    from Nevada
    Yep, Old Harper, good stuff! I'd like to go to that store and get the rest of the linkage. It is pretty complicated but the original pieces were very well made. Another guy I know is making his own and doing a pretty good job.
    kidcampbell71 likes this.
  10. Six Ball
    Six Ball
    from Nevada
    Here are some pictures of the one I have. The main linkage that hooks the gas pedal from the car is different. It only links to one side of the carbs and there is no set screw for the idle adjustment. It connects to the outside so it couldn't run the split shafts as the inside set has the accelerator pumps. I did find the middle carb linkage that allow all three to work together. It was loose in the box. So I do have most of what I need to copy but will have to build and modify the middle part. Compare to the set in the post a few back.
    . 191011_0001.jpg 191011_0003.jpg 191011_0009.jpg 191011_0011.jpg 191011_0010.jpg
    Pat, Shadow Creek and kidcampbell71 like this.
  11. jalopy45
    jalopy45
    some more linkage pictures 77rrrrrrrrrryyyyy - Copy.jpg 100_2598.JPG 100_2602.JPG 100_2603.JPG 100_2604.JPG
    Pat and Shadow Creek like this.
  12. jalopy45
    jalopy45
  13. Six Ball
    Six Ball
    from Nevada
    Thanks Gary, the first picture looks like mine. The second setup is more involved at the middle carb. That is where all the magic lives.
  14. Eddie
    Eddie
    from Georgia
    Those pictures posted by Six Ball were provided and shared by me a few years ago. I still have that setup and can take additional pics. if needed. Sorry but, no, I will not send any of the parts to anyone for re-casting. I hope you understand why. BTW, this can be bought with a 261 engine. Also have another 261 with blower. Check out my other ads in for sale section. There are some errors in that ad, will try to edit later. Eddie 478-967-3362 or 706-835-5990
  15. Six Ball
    Six Ball
    from Nevada
    Thanks Eddie!
