Ford flathead 8 BA block that has been magna fluxed. 4" Mercury crank turned .030 mains and .040 rods New Johnson style adjustable lifters New cam bearings, valve guides, keepers, valves, springs, retainers, valve guides, valve guide retainers, valve guide o rings, rear main seal retainer, 8 connecting rods New Bob Drake water pumps Edelbrock finned aluminum heads that have been surfaced Edelbrock 2x2 aluminum intake with 2-Stromberg 97 carbs with air cleaners and linkage Billet electronic distributor with coil and plug wires. Rare aluminum timing cover, new timing gear, lower crank pulley, oil pan with dip stick, oil pump with pick up, rear cam gear and cover, crank oil slinger, stock distributor, flywheel, bell housing, original oil filter, exhaust road tube and two exhaust manifolds. All of the hard to find parts are here. Save yourself a lot of time and money! $2695 obo
