CHEAP and Great Alternative Coil Springs '49 thru '59 Ford and Merc
Discussion in 'The Hokey Ass Message Board' started by Fairlane Dave, Apr 26, 2008.
  1. bobss396
    bobss396
    Couple of shots with the CC850 springs... too low for my car.
  2. ThatMerc64
    ThatMerc64
    I am looking to pick up a '54 4 door Monterey. Just so I understand, its the Aerostare springs in the front and 3 inch blocks on the leaf springs? I haven't actually seen the suspension on one of these yet ha. Just doing some research. Thanks
  3. jimmy six
    jimmy six
  4. Crisman Strunk
    Crisman Strunk
    My Dad has had a 51 Ford Custom for over a decade now but problems with his hip makes it hard for him to work the clutch so I have possession of it right now. He has kept everything pretty much stock but I've talked him into letting me customize it a bit as long as I don't get too radical. ;) I was looking at lowering it when I came across this thread. I've read through it all and have a little information overload. To make sure I've gotten stuff straight:
    I'm going to use coil springs from a 90 Aerostar with Monroe PN 5821 shocks up front. I'm wanting to use lowering blocks for the back. I was thinking about a 3" lowering block but suspect it might be best to see how much the front setup lowers it before deciding as I want the car to be level. If that works out, what shocks have you guys used for the back?
    Also, the steel wheels currently on it are 15 X 7s so I was going to put 15 X 7 Torque Thrusts on it. I was debating what size tires would work with those wheels after lowering it or will I need smaller size wheels?
    Great community. I've read a lot of threads here over the years but never joined.
  5. hans mercman
    hans mercman
    from Texas
    55 Merc w/Aerostar springs. Havent touched the back yet. Shes sitting real low im almost scared to drop the rear its hard enough to clear the angle of the driveway already
    The second pic is about 6 months after new springs, think it dropped another inch from top photo to bottom
    don colaps and AChopped1950ford like this.
  6. John Macchia
    John Macchia
    I have a 1950 mercury with a 350 Chevy engine. I installed the Aerostar coils and the Monroe shocks, the stance is great! On a smooth road it’s great but on a slightly bumpy road the car is real bouncey Any suggestions?
  7. hans mercman
    hans mercman
    from Texas
    Was it bouncy before the spring/shock swap? bouncy usually means shocks...but sounds like you installed brand new ones?
  8. Kato Kings
    Kato Kings
    from Minnesota
    Anyone know if the aerostar springs will work on a 57 lincoln capri?
  9. Com4tablynumb
    Com4tablynumb
    from Kodak, TN
    Ive got Aerostars upfront and I lowered the rear on my 54’ this weekend with 2” blocks on really sagged springs, which I believe has equated to about 3 1/2”-4" from stock. Now I’ve got horrible noises at takeoff and under load. I only drove it around the block.....I live in the mountains, and when coming uphill it was horrible unless I let off the gas. It actually was hitting the end of one of the back seat, center seatbelt bolts on the first attempt. I ground that down and sprayed fresh black paint on the tunnel and drive shaft and tried again. Its not hitting anymore...just horrible popping like noise under load. I think its that my driveline angle is on the brink of binding the u joint at rest. So, under torque (load) the axle wraps on the soft springs and raised height (further out from the fulcrum now) and the u joint is in a bind, or its hitting the tunnel and I'm not seeing it. I also wonder if strapping the leaf spring pack would lessen the axle wrap, if it is the case.I would measure the angles to correct, but obviously the pinion and trans angles havent changed, they are only further from each other in al***ude causing the drive shaft to be at a more extreme angle. Wish I had a GoPro camera that I could put under the car! lol. My Wife told me "You made it look cooler and undriveable for now....good job, Babe" Anyway, here’s some pics....cause we all love pics. Any shared experience with a healthy drop would be appreciated. I'll be jacking with it again this weekend. front now.jpg rear now.jpg
    don colaps and deluxester like this.
  10. dmoz
    dmoz
    from Texas
    I'm taking the plunge..going with the aerostars on my 1950 Merc...had to dis***emble everything to get it cleaned up..it appears this thing was buried a sand dune for some time.. the aerostars are about 3-4" shorter than the stock coils.. IMG_20201006_162504_423.jpeg
    Sent from my SM-G950U using The H.A.M.B. mobile app
    Toms Dogs and deluxester like this.
  11. Spooky
    Spooky
    Howza folks!
    Well, would these ford on a 61-66 Lincoln?
  12. jimmy six
    jimmy six
    If you can measure the OD of the stock spring and the OD of a wire coil that way I could tell you if they are the same as an AeroStar. …… Length and car weight your on your own.
    There are also urethane end spacers that fit off Toyota pickups. I have a 1/4” On one side and a 3/8” on the other to make mine level.
    MO_JUNK likes this.
  13. rubbershox
    rubbershox
    I love to read these information. but i would like to aone me thing about cars and their suspension system. it will be great if the suspension system of the car is good. Thormoplastic Rubber material will be best option of suspension system. Rubber Bump stop will be a good option
    miker98038 likes this.
  14. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    All, following the earlier comments in this thread, I installed Aerostar springs in the front of my 57’ 300 sedan in the spring of 2019. I rebuilt the entire front suspension with stock replacement parts. The rear springs are original and need new bushings. The rear looks high in these pictures but it is the slope of my driveway. I like to not see the top of the tire-no open space above it. One inch of my front tire is up in the well and no rubbing on turns or angles. Rear 235x75x15, front 225x75x15. 351windsor with aC-4. Thanks for all of the input on this thread. It drives and rides excellent. B2443AFC-D19C-4ECE-B841-A73EBFB057E7.jpeg 6A51CD36-C34A-4810-B14E-707245E04918.jpeg
  15. jimmy six
    jimmy six
    Perfect rake for 50’s cars. I’m not a fan of level low…all Fordswill sag in the rear over time. They are a long spring.
    don colaps and MO_JUNK like this.
  16. Squablow
    Squablow
    Fairlane Dave, the guy who actually figured out that this would work, hasn't been here in almost 10 years. I wonder if he realizes how many cars he helped to customize by sharing this one post with all of us. Impressive.
    I'm also thinking about buying a set of these for my Merc project now, even though I don't need them right at this moment, considering the Aerostar is well over 30 years old at this point and it's hard to say how long those springs are going to be available yet.
    MO_JUNK and leon bee like this.
  17. Dan1982
    Dan1982
    Hey guys!
    About to do this swap wondering if anyone needed an alignment after?
    Thanks!
  18. jimmy six
    jimmy six
    I had mine aligned after installing the AeroStars and yes it needed it. That was 4-5 years ago. Fine since.
  19. guthriesmith
    guthriesmith
    X2 on the need to align afterwards. I installed mine probably 10 years ago now and still no issues other than the need to rebuild my front end...but, that is just because it never has been.
    MO_JUNK and jimmy six like this.
  20. bobss396
    bobss396
    I aligned mine after cutting the OG springs and putting them back in. The car rides very straight and turns well considering no PS.
  21. Fairlane Dave
    Fairlane Dave
    Wow! I haven't logged in to the HAMB in at least a decade for some reason. I was doing a Google search about my Custom 300 suspension and this thread was one of the results that came back. It's really cool to see how many people have been able to use this cheap and easy mod that I shared back in 2008. I ended up putting air bags on my car about 7 years ago and I absolutely hated them. I used a universal RideTech kit and it just kills any hope of a turning radius. I finally realized it was killing my joy of driving the car, so I just took the bags off the front and reinstalled a new set of Aerostar springs and a new set of shocks. I left the bags on the rear because it's convenient for when I have a trunk full of luggage or back seat p***engers. Now, I can finally stop doing the dreaded 18 point freaking U-turn that the bags caused! Cheers, everyone.
    BigRRR, Toms Dogs, MO_JUNK and 4 others like this.
  22. Squablow
    Squablow
    You're responsible for the lowering of literally hundreds of 50's Fords from that one post. **** like this is the reason I bother to post little updates about how certain stuff went together or what fit, just because on the internet, it can help countless others. Good to hear from you again.
    51 mercules and Gator McKinley like this.
  23. bennydajet
    bennydajet
    Another satisfied customer!
    Some previous owner lowered my 50 Ford by heating the springs. I installed the Aerostar springs simply to gain some drivability. I wasn't expecting to lower the car any but it actually sits about 3/4" lower with the new springs installed.
    BigRRR, bobss396 and Toms Dogs like this.
  25. JSmitty75
    JSmitty75
    Just wanted to add mine to the thread as well so that Fairlane Dave knows he is still affecting peoples lives! And the stance of their cars.... is it hundreds of us that have used this method by now...? Thousands?? Crazy.
    I used Aerostars upfront with the Gabriel shocks and 3" blocks in the back.
    She came down about 1.5" in the front.. hoping for a bit more after she settles a bit... (anyone have input on this? How much have yours settled if any?)
    Heres some pix..... To the new guy thinking about doing this.... DO IT!
    Before
    Halfway.. 3" blocks in the back.
    All done: Aerostars and Gabriel shocks
