Features 1937 to 1942 Willys Picture Thread
Discussion in 'The Hokey Ass Message Board' started by Hot Rod Willys, Jan 15, 2011.
  1. 65pacecar
    65pacecar
    from KY, AZ
  2. loudbang
  3. loudbang
  4. chopolds
    chopolds
    from howell, nj
    Looks like there's a few Willys experts over here. Got a question! Prepping a 41 Street Beast Willys (yeah...groan!) for a friend. It has ONE single hardware store type hinge in the middle of the hood, to the top of the cowl. Not much in the way of adjustment, and it needs some! Same as the doors and trunk, but they were easier to modify and adjust. Is it possible to work with this hinge set up? Or is there an alternative hinge to install on the car, like a factory pair? I guess I'll have to make up a crossmember on hood too, for side hinges to bolt to, as well.
  5. Pictured below is a cowl section from a '1938 or later Willys...they all had the piano type hinges after the 1937 hinge on each side set up. The hinge on each side set up in '37 had a pocket for the hinge in the firewall, and often it held water and the hinge rusted...ended up not being able to easily open the hood. I took this piece out of a '38 cowl, in case I found a '37 , so as to convert to the type that the later hoods would mount to.. You are right...there was very little adjustment available with this set up...however I encountered fewer problems with hood alignment than other hinge set ups on a steel bodied Willys , (eg. door hinges, trunk hinges, etc) Not sure about gl*** cars. Almost anything is possible, but I would have to see what you are dealing with to make a judgement. There is a shock absorber set up out there that might work (try Willys Replacement Parts out of California (Mike Nordahl...owner.) g-willys IMG_20190321_100659014 (1).jpg
  6. 65pacecar
    65pacecar
    from KY, AZ
    [​IMG][​IMG][​IMG][​IMG]
  7. loudbang
  8. loudbang
  9. NHRANUT
    NHRANUT
    from Western PA
    loudbang and Bowtie Coupe like this.
  10. loudbang
  11. 65pacecar
    65pacecar
    from KY, AZ
  12. loudbang
  13. loudbang
  14. loudbang
  15. 1934coupe
    1934coupe
    A 40 standard with all the right parts. Great looking Willys.
    Pat
  16. 65pacecar
    65pacecar
    from KY, AZ
  17. 65pacecar
    65pacecar
    from KY, AZ
    Bakersfield
  18. 65pacecar
    65pacecar
    from KY, AZ
  19. loudbang
  20. loudbang
  21. loudbang
  22. loudbang
  23. 1940Willys
    1940Willys
    From Chrr 2019 The Grove two Steel Coupes The second one s***ched from a sedan DSCN7346.JPG DSCN7347.JPG DSCN7617.JPG DSCN7619.JPG DSCN7626.JPG
  24. rusty1
    rusty1
  25. loudbang
    loner2, EVL401, exterminator and 8 others like this.
  26. loudbang
  27. 1934coupe
    1934coupe
    Really cool 40 std. also LB, I'll bet it was like all steel Willys a stocker, note the rear view mirror in the windshield.
    Pat
    Bowtie Coupe, porkshop and loudbang like this.
  28. loudbang
    posted by hemidav in the vintage thread
  29. loudbang
  30. loudbang
    Current Moonlighter
