Projects 1940 Chevy Sedan SEGA Gasser Build
Discussion in 'Traditional Hot Rods' started by CPT_Kill_Roy, Jul 10, 2019.
  1. CPT_Kill_Roy
    CPT_Kill_Roy
    A bit more progress, getting ready to pull the original motor out.
    mgtstumpy and Shadow Creek like this.
  2. 34Phil
    34Phil
    Olds 12 bolt rear is like 10 bolt inside except no c clips. P*** on it.
  3. RatRoy
    RatRoy
  4. CPT_Kill_Roy
    CPT_Kill_Roy
  5. CPT_Kill_Roy
    CPT_Kill_Roy
    Interesting, thanks for the info. A member on here has a 9” from his 1939 he’s going to sell me. I’m thinking the 9” will handle the 500HP 454 we plan to run.
    swade41 likes this.
  6. low budget
    low budget
    from Central Ky
    I like these old chevys best with a 60s/70s vibe not necessarily a g***er with the lettering etc but a darker copper color maybe, sitting up a bit with wide slots in the back and skinnys in the front would definitely do it for me:cool:
    More style here http://georgekl***.net/g***ers.html
  7. CPT_Kill_Roy
    CPT_Kill_Roy
    Cool photo! I’m not going to get too crazy with the front end lift. It looks like the leaf springs from my Cj Willy’s will fit the front of my Sedan. The springs are basically the same size.
  8. mgtstumpy
    mgtstumpy
    40 vert with a 409, they do fit nicely ;)
    brEad, CPT_Kill_Roy and Rich B. like this.
  9. keith27T
    keith27T
    Nice I'm following.>>>>>>>>
  10. CPT_Kill_Roy
    CPT_Kill_Roy
  11. CPT_Kill_Roy
    CPT_Kill_Roy
    Any one use Camaro leaf springs when they swap in a 10/12 bolt rear axle on these early Chevys?
  12. indianbullet
    indianbullet
    from Ca
    Looking good, following for sure..
  13. rusty1
    rusty1
    Camaro/Nova leafs are a bit long for these Chevs,..I'd use originals or Ch***is Engineering
  14. CPT_Kill_Roy
    CPT_Kill_Roy
    Thanks that helps save me time with measurements. I can use my originals. I’d either use off the shelf sliders and caltracks or build my own.
  15. Shadow Creek
    Shadow Creek
    X2 what rusty1 said. I set up a pair of Camaro springs on my 39 sedan frame just to see if they would work, probably could have made it work but would have had to relocate the fuel tank, redo the rear crossmember, and a few other things. I’ve got a TCI Kit, which is basically the same as the Ch***is Engineering and I’m very happy with it so far. Here’s a pic from when it was first mocked up
    CPT_Kill_Roy likes this.
  16. CPT_Kill_Roy
    CPT_Kill_Roy
    How wide are those springs? I’m thinking my original springs are only
    1 3/4” wide, same as the front.
  17. low budget
    low budget
    from Central Ky
    Just saw this one belonging to @NWRustyJunk on here in the, What did you do today thread.
    swade41, NWRustyJunk and CPT_Kill_Roy like this.
  18. Shadow Creek
    Shadow Creek
    They are 2 1/2” springs. If you do decide to order this setup just be aware all the hardware is for a 3” axle tube. The axle I’m using is 3 1/4” so had to order different u-bolts and plates. I simply adjusted the axle saddles with a flap wheel to fit on the bigger axle. It’s all still just mocked up for now and I haven’t put the body back on yet so I don’t have any road time with it, but I was very happy with how it all mounted onto the frame.
  19. CPT_Kill_Roy
    CPT_Kill_Roy
    low budget likes this.
  20. zjerry
    zjerry
    I used Ch***is Engineering for my 1940 chevy with a 1974 nova rear end & I have a 1974 nova front sub frame 64632775_1525139070955048_6842799250980470784_n.jpg
    CPT_Kill_Roy and low budget like this.
  21. CPT_Kill_Roy
    CPT_Kill_Roy
    I’m going to sell some parts off the car that we don’t need. The front bumper and the sun visor seem to be worth the most based on what’s available on eBay.
  22. CPT_Kill_Roy
    CPT_Kill_Roy
    Pulled the old rear axle out and the Mustang 9” is going in for mock up.
    brEad, swade41 and chryslerfan55 like this.
  23. CPT_Kill_Roy
    CPT_Kill_Roy
    With some help I got the 9” axel placed. Looks like some addition fab work will be needed to get it centered in the wheel well opening.
  24. CPT_Kill_Roy
    CPT_Kill_Roy
    Pulled the old motor and trans out tonight, plenty of space for a big block. Adjustments.JPG IMG_3362.JPG IMG_3363.JPG
  25. southcross2631
    southcross2631
    Looks like a fun project . I remember helping my brother with his 37. He used a Nova clip and it drove great.
    You have to lose the visor to give it the G***er vibe. W motor would be cool. 348's can be made to run.
  26. CPT_Kill_Roy
    CPT_Kill_Roy
    Yep, Visor is getting taken off and sold. The front bumper too.
    All my spare parts are getting hauled to a cl***ic car junk yard... rip
  27. southcross2631
    southcross2631
    The only hang up I see is that the steering box may get in the way of a W motor.
  28. CPT_Kill_Roy
    CPT_Kill_Roy
    I decided against the W motor. I looked at several and for the price I’d never be able to get the power out of it.
  29. CPT_Kill_Roy
    CPT_Kill_Roy
    Here’s where we’re at with the build.
    The motors out and were cleaning stuff up.
    Ford 9” is under it for mock up.
    We found a Big block Chevy and trans for it. Nearly free.
    As soon as I get motor mounts sorted out we’re starting mock up.
    Engine has flat top pistons and 718 heads. 2 bolt main
    Not sure if it’s a forged crank or not.
    Pistons are .30
    Any one have a link for bbc headers that fit these fat fender cars?
    Or do tri5 headers work?
  30. CPT_Kill_Roy
    CPT_Kill_Roy
