Technical To drill or not to drill.
Discussion in 'Traditional Hot Rods' started by reekie6, Oct 17, 2019.
  1. Fortunateson
    Fortunateson
    Never drill any axle as it weakens them. Think about it, you're at the red light and launch hard and the axles can't handle the torque grenading. Now your differential will be ******ed and the whole experience.... Oh your talking about the front axle! Never mind.
  2. southcross2631
    southcross2631
    How do you weekend an axle ? As Trump would say drill baby drill ! My front axle is cut in two narrowed and drilled. Put in a 40 ton press and bent for alignment and never failed. I wouldn't worry about drilling a few holes in it. DSCF3461.JPG
    dirty old man likes this.
  3. Fortunateson
    Fortunateson
    Well that was embarr***ing. Fixed it, thanks.
  4. solidaxle
    solidaxle
    from Upstate,NY
    Maybe the question should be, has anyone experienced a failure with a drilled front axle?
    nunattax, Cosmo49 and ERguitar like this.
  5. rob-redm
    rob-redm
    fan of both drilled and non drilled.. but I'll go with non drilled, chromed and the insert painted to match.
  6. Boneyard51
    Boneyard51
    Most of the time, when you remove metal, it weakens the item! How much? Depends! Drilling an axle right takes some skill and time and possibly some money. That being said, if I wasn’t sure if I liked it....... I wouldn’t do it!
    On the flip side.... if I really liked the look..... I would do it!
    Each to his own!
    Bones
    deathrowdave likes this.
  7. woodiewagon46
    woodiewagon46
    from New York
    The structural strength of an "I" beam axle, is just that, an "I" beam. when you drill it, especially with holes that are large, you compromise the strength drastically. Yes, I know that people have been doing it for years, but facts are facts. I vote to not drill it, looking cool is one thing, safety is another.
  8. error404
    error404
    from CA
    strength aside, personally I like the look of no holes, on most components. I don't mind sheet metal with dimple died holes in a tasteful way, but I'm not sure how HAMB friendly dimple died parts are.
  9. Fortunateson
    Fortunateson
    I'd like an engineer to chime in. I believe that a hole being round would not have stress points due to th elack of corners and therefore if not excessive would not be overly weakened. But as I said a structural engineer should comment.
    gimpyshotrods likes this.
  10. willys36
    willys36
    48 yr Mechanical Engineering grad & practicing eng'r. Beam axles are I-beam section members. That shape derives all its strength from the top (in compression) and bottom (in tension) flanges. The web between only has to keep the top and bottom flanges from deforming, adds virtually no bending strength. Thus just about any drilling pattern has no detrimental effect on axle strength. Some guys take that to an extreme and cut long slots removing a lot of web. This does endanger the top and bottom flanges collapsing but if just drilling, not to worry. Just keep the holes in the web and don't remove any flange.
    Had these for 28 yrs on my daily driver, zero problems.
    Hnstray, Blues4U, Jet96 and 12 others like this.
  11. kidcampbell71
    kidcampbell71
    The ends on mine, are drilled. I didn't want it all holed up. I like it, like this. 117Harv's work. Best polisher on the HAMB. I only polish knobs. :) Well ... one anyway. :D
    Top is polished, and drilled. Bottom is finished polished ... Gibbs oiled.
    Cosmo49, nunattax, charleyw and 5 others like this.
  12. 40Standard
    40Standard
    from Indy
    on a 32-34 highboy
    chromed & drilled
  13. Nostrebor
    Nostrebor
    @willys36 has it... the web is like a lattice on a truss. It keeps the flanges in alignment so they don't deform under compression/tension. We do large structural members with blockouts in the web all the time, or castellated steel beams that follow the same principal.
    If you wanted to get all technical about it you could do a load ****ysis on the section to determine where to put the holes, but holes are well within the realm of design.
    olscrounger likes this.
  14. The37Kid
    The37Kid
    I'm guessing the holes were drilled after the polish work. Bob
  15. Blue One
    Blue One
    from Alberta
    I drilled my forged axle, I like the look and it will be plenty strong being forged steel to begin with.
    The drilled axles I’d be most concerned about would be the cast axles like Magnum for instance.
  16. The37Kid
    The37Kid
    OK, For the historical record who had the FIRST drilled front axle and when? Photos would be nice to see. Bob
  17. flamedabone
    flamedabone
    You are not supposed to chrome them either, but....
    -Abone.
    -Brent-, Tim, clem and 8 others like this.
  18. error404
    error404
    from CA
    I'm absolutely not an engineer! haha!
    But if a piece of flat bar has holes in it, surely that would make it easier to bend (on edge, the "hard way"), than if it didn't have holes? Or no?
    That's essentially the "web" of the I beam, right? Flat bar bends easy on the flat sides, and difficult to bend on edge "the hard way". The top and bottom of an I beam would bend easilly (with downward or upward force) if the web weren't there?
    Or is it the case that these I beam axles are stout enough that the holes don't degrade enough to make a difference during normal use?
    I'm sure I'm over simplifying it, hah! I would love to take some engineering cl***es, I usually just throw way thicker metal at things because I don't know how much is actually needed for sufficient strength, haha
  19. If Henry Ford could have saved 50 cents worth of metal on every axle he made, he would have figured out a way to do it.
    Montana1 likes this.
  20. willys36
    willys36
    Again the top and bottom flanges take all the stress. As long as they don't deform, the web is not needed at all for strength purposes. That idea is impossible without the presence of something holding them in place. enter the web on an I-beam, the x-pieces on a truss (steel bridge, wooden roof truss, etc.) If you want to investigate the math, find a text book that describes calculating the strength of various shapes by first determining the moment of inertia. The bigger the area of a shape component, the farther away it is from the center of m***, the stronger the composite shape is. The web of an I-beam is right at the center of m*** and has little area so not much bending strength in any direction. The flanges have relatively large areas and are spaced far away from the center of m*** so have lots of relative strength. The web's job is to keep them steady via the center of m***. Holes have zero impact on them doing that job.
    Envision what each component of an I-beam is doing when trying to bend it. The top flange is being shoved, trying to compress it. The bottom flange is being pulled. Neither has much bending stress so the shape is very strong since steel has very high tensile (pulling/compressing)strength. The web is being slightly bent but is insignificant compared to the push/pull of the flanges.
    Hnstray, jaw22w, Nostrebor and 2 others like this.
  21. kidcampbell71
    kidcampbell71
    @flamedabone ... HOLY **** !! I love it.
    So supposedly, you CAN chrome steel and remove molecular issues from the process, by baking the chromed parts for a time frame, immediately after the chroming process. Like within, hours.
    I can't tell you the looks the chrome guys give you, after saying as such. o_O I haven't found anyone yet, as "educated". I'm some sort of whack job to those guys.
  22. willys36
    willys36
    Another misunderstood process. Hydrogen embrittlement is real but only happens on high strength steels over 140,000psi yield strength or Rockwell hardness of 32HRC. This is in the range of grade 8 bolts and stronger. Weaker steel alloys do not suffer from this and that includes axles, frames, etc. those can be chromed and welded with no hydrogen embrittlement problems.
  23. 41rodderz
    41rodderz
    from Oregon
    I have to agree. That axle is sleek and slick. Nice change up on the hole(s) placement.:cool:
    kidcampbell71 and KoolKat-57 like this.
  24. 41rodderz
    41rodderz
    from Oregon
    Let me throw this out there. Think about those running wire wheels. Thin spokes with lots of air in between. I suspect the outer ring acts just like the top/bottom of an I beam.
    Eldonius likes this.
  25. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Yeah it's got holes in it! They match the shock mounts.
    KK
  26. goldmountain
    goldmountain
    I like mine drilled but hate seeing drilled axles with that big gap in the middle saying Super Bell. There needs to be a hole right dead center.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  27. BJR
    BJR
    All the comparison of a drilled axle to a truss goes out the window the minute you put twist into the equation. A dropped axle twists with braking force due to the lever action of the drop. Trusses don't have twist factored into their load bearing. Holes weaken any I beam axle unless it doesn't twist.
    41woodie likes this.
  28. gene-koning
    gene-koning
    OK, so as this debate continues on, I keep envisioning that Ford axle with all those full circle twists in it. So,how many twists are in it? 20, maybe more, maybe less? I'm sure someone could post up a picture and maybe we can count the number of twists, but lets go with the 20 full circle twists (which is probably a lot less then counting might show), just because we need a number so we can understand.
    So we take a fresh Ford axle, and drill holes in it, then we twist it in circles. I can see where the holes are going to weaken the axle as it twists. The question is, how much did we weaken it with the holes? Lets say we lost 50% of the axles strength when we drilled the holes. Would that mean the axle MAY fail after 10 full circle twists? Remember, the original one didn't fail after all 20 twists.
    I'm not seeing a life threatening event going on here. I can't imagine an event where the axle will see the twisting force that axle went through in a normal axles life span, which has carried on for many years.
    Hot rodders have been drilling holes in axles for many years. It would be interesting to find out exactly how many have failed in all those years. I suspect that number is pretty low.
    We tend to do a lot of unsafe things with our hot rods, I believe drilling holes in axles is probably one of the less unsafe thing we do.
    That said, if your not sure you will like the look, I can tell you without any doubt, its a lot easier to remove the metal with a drill then it would be to put the metal back in the holes, if you don't like the look. Gene
    Hnstray likes this.
  29. 41 GMC K-18
    41 GMC K-18
  30. Montana1
    Montana1
    If you plan to use hair-pins or split bones, the I-beam becomes a torsion bar. Enter twist.
    If you drill holes in the web of an I-beam, the vertical yield point actually goes up, until it twists - just like in a monocoque ***embly. Think Indy cars or Aircraft. Then it folds like a house of cards.
    Also, take note that NO ONE drills holes in their I-beam connecting rods to strengthen them, lighten them, or to make them look cool...
    But then, what do I know, I'm just a painter... ;)
    nunattax likes this.
