Projects 1932 Jalopy Roadster Build
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 20, 2019.
  1. KKrod
    KKrod
    deluxester, kidcampbell71 and Stogy like this.
  2. Mart
    Mart
    Yeah, lightbar looks good. Tying them together like that is a good idea, plus it acts as a grille guard. I didn't see the dog until it was mentioned above.
    deluxester likes this.
  3. deluxester
    deluxester
    Added a much needed fuse panel. Ignition/lights/aux/dash-not connected yet. Using cloth covered wire through out.
  4. deluxester
    deluxester
    And swapped out some jets. Stock 45’s in favor of 42’s, hoping to lean out a bit.
    Stogy and teach'm like this.
  5. deluxester
    deluxester
    And also wrapped up that light-bar.
  6. Mart
    Mart
    Interesting looking fuse panel. It looks like that design hasn't changed since the 20s. Is the idea that non fused items can be fed from the right hand side and fused items on the left?
    Hitchhiker and Stogy like this.
  7. deluxester
    deluxester
    Not positive. I found it in a pile of junk at my friend’s shop. It looks like you can ground the negative terminal and have a bus to run two leads (+ and -) for each non grounded device. It may not have been intended for a car or anything else with a metal ch***is is my guess. I just thought it looked cool.
    WC145, Stogy and Cyclone Kevin like this.
  8. roll of the dices
    roll of the dices
    Great work! Where the did you get the cloth covered wire. from? I am hoping to do the same for my roadster but have only found YnZs as source.
    Stogy and deluxester like this.
  9. deluxester
    deluxester
    Early Ford Store down the street from me. Some sections are repurposed from old wiring harnesses.
    Stogy and brEad like this.
  10. deluxester
    deluxester
    E499742F-7216-470B-872B-9EAFBF91DE96.jpeg Whipped up some anti-chatter rods. They thread right into the 8ba block with a locking nut.
    Stogy, brEad and kidcampbell71 like this.
  11. deluxester
    deluxester
    ...And had friend David Mejia help with the upholstery work. D4608D5A-6282-4E6E-8C36-863AF2AC06FB.jpeg
    WC145, oliver westlund, Tim and 7 others like this.
  12. deluxester
    deluxester
  13. deluxester
    deluxester
    The car did great at this last RPM Nationals event, and we were honored with the “Shifters Pick” award presented by the Shifters Car Club.
  14. deluxester
    deluxester
    But there was something amis throughout the day of racing... cylinder no. 8 to be precise. This wasn’t discovered however until I inspected the car a few weeks afterward.
    It turned out to be a damaged valve caused by some clearance issues with the way the heads were casted and machined (and me not checking each of the chambers before installing). This had happened once before using these heads, and I thought I corrected it sufficiently by removing some material on the head near and around the valve.
    WC145, Stogy and kidcampbell71 like this.
  15. deluxester
    deluxester
    I had Eric Vaughn of Vaughn’s Machine in Monrovia help correct the heads. Each chamber was clearanced by an additional .050 and each chamber now shares a relatively equal cc value. The face surface of each spark-plug hole and stud hole was machined to a perfect 90, and steel inserts were installed. These heads should be near perfect now!
    3EB84FDD-B6A6-4AC5-A563-A59060684814.jpeg 8FC64B19-2863-4BDE-96FF-26410D161DAC.jpeg
  16. deluxester
    deluxester
    Sharp edges and sparkplug holes were radius ground by hand to improve flow and minimize hot edges. 267A75B2-B1C9-4F94-B2DA-073FDD64E088.jpeg 0FA12506-38C3-47CC-87F9-15C72338254A.jpeg
    WC145, oliver westlund, Stogy and 3 others like this.
  17. deluxester
    deluxester
    I replaced all the valves with beautiful new stainless units, spiral ground and hardened tips. The valve seats were lapped and the lash was set once more. 58BE774B-2669-4DF1-AADC-B06A5BA180F2.jpeg AC3C192C-3314-4562-92BE-921A537779F3.jpeg
  18. deluxester
    deluxester
    Then had Stanyer & Edmondson “Goodyear” in Pasadena mount some fresh bias plys. They’ve been there Since 1922!
    ECE17AAD-39C1-409D-8B54-FEC812D1AADF.jpeg 7863556E-4E8A-48F4-8135-C721EFB9CF5C.jpeg B6BD37B8-6D5A-47F7-9FA2-E9D156B7E9B3.jpeg
  19. alchemy
    alchemy
    Where'd the valves come from? Are they the exact length to the grooves, or require shimming?
  20. Fogger
    Fogger
    You definitely got the right guy to work on your heads. Eric is a master machinist and a great source of information. I bought the wheels on my 3W from him in '85. He has done me right with his aluminum wheels and their repairs. Your roadster looks terrific.
  21. flyn schlosser
    flyn schlosser
    from Elko,NV
  22. Stogy and deluxester like this.
  23. HellsHotRods
    HellsHotRods
    I think you stopped by after RPM nationals and had the compression checked, that's when we found out the one side had 2 cylinders with zero compression. Eric sure cleaned up those heads!!
  24. deluxester
    deluxester
    I purchased from H&H since they were local. No grinding required as I used adjustable lifters. It was explained to me that they use these valves on all their builds.
    Stogy likes this.
  25. alchemy
    alchemy
    They've got a couple 1.5" valves on their website. Does yours have a part number on the box? A Manley number?
    Stogy likes this.
  26. deluxester
    deluxester
    The box they gave me was a plain cardboard box they’d found to toss them all into. That said, I believe these are the standard “1.5 budget-performance” as I have stock seats and the profile is not the “pro-flo” undercut design. Hope this helps! 9CEF2D43-67F6-42BC-A81A-0789AEF7CDDE.jpeg
    oliver westlund and Stogy like this.
  27. deluxester
    deluxester
    Its been awhile since my last post, so I thought I’d bring my build thread to current. Since January, I’ve been slowly removing layers of old paint with hours of rubbing and wet sanding. The result was a good chunk of og ford black/burgandy with bits of factory primer poking through. Here are a few photos I took to record the process.
    A2A09D5F-3F17-43C3-8F0A-7ABAF06B72B0.jpeg 9DE373A3-539A-4CB9-B908-199EB9A4DECC.jpeg 7B6F1F07-F62C-4371-BD83-823F861C3276.jpeg 4F99A5EA-914E-4CE4-B39C-E710AAEFA965.jpeg
  28. deluxester
    deluxester
    B25205DF-5882-45DA-B73F-FA88D4D09BE8.jpeg 9CE99BAA-4E80-4B0F-8342-E92A30EDBBD5.jpeg 8A7EA48B-14AE-4A24-BB02-58A4B0EDEB2C.jpeg Original Ford lacquer paint along the lower edges was nonexistent, along with spotty areas where the paint was scuffed too deep or gouged out to bare metal. I decided to fill these areas in with black lacquer, before blending into the surviving areas with patina solution and misting touches of rustoleum maroon. The aim was to preserve as much of the original patina and to include the old chips, scratches, and even some evidence of the removed paint layers. Feathered and blended afterward for a uniform appearance.
    I also started on a top using the original irons.
  29. deluxester
    deluxester
    The top was shortened by 3” and some of the original wood was not salvageable so I made replacements. 4F43E49F-1DA5-4239-A25F-F912F0FDE3C0.jpeg 5A2C00E5-A107-4FA1-8A07-889E08164876.jpeg 9FAD3F79-31C9-4902-8FA0-89CA5C3B8528.jpeg 3AB7EFAF-5892-4384-86C0-8281B858DF0D.jpeg F0D90222-B86C-42FA-B9D0-0BCCB743903B.jpeg 4567F106-AD03-472D-A371-EF33704E942D.jpeg
    WC145, oliver westlund, Tim and 9 others like this.
  30. deluxester
    deluxester
    I shortened another set of stanchions to match the 3” chopped top. 840A6F4F-3E65-4AA3-B017-EDA9B9C4282B.jpeg D9A35D17-C636-40AD-AE2C-54E97257454F.jpeg
