Technical ***October 2019 Banger Thread Scary Banger Noises***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 30, 2019.
  1. V4F
    V4F
    from middle ca.
    a little late , but awesome "T"
    winduptoy likes this.
  2. brjnelson
    brjnelson
    Yes it is
    Come on Larry show the guys more of the T you bought
    from Gary in MN
  3. lake_harley
    lake_harley
    Ha Ha! I was on a motorcycle trip to visit my sister in Martinez, CA when PG&E was powering down to keep from setting fires a couple weeks ago. Craziest thing I'd ever heard of, although I guess it made sense too. I filled my motorcycle with gas before the power got shut off just to make sure I could get out of the affected area when I got ready to leave.
    Lynn
  4. wheeltramp brian
    wheeltramp brian
    Hey guys I've got a nice running 31 cabriolet and was wondering how much pep it would give it if I swap the head to a 5.5 compression one? Worth it or not?
  5. wheeltramp brian
    wheeltramp brian
  6. MrModelT
    MrModelT
    You need to ride in my T then before you re-word that statement... ;) :D
    Dannerr, Lil'Alb, fourd and 5 others like this.
  7. V4F
    V4F
    from middle ca.
    isn't that the car jay leno wanted ??
  8. Jiminy
    Jiminy
    Retson the Racer and Crazydaddyo like this.
  9. Binger
    Binger
    from wyoming
    Dannerr likes this.
  10. Got the car sitting right on the new tires.
    Intake manifold is coming next week!
    Looking to do a simple 6v positive ground fuel pump, anyone have any recommendations?
    Dannerr likes this.
  11. 5280A2
    5280A2
    I would recommend Airtex E8902. Six volt pump that can be wired either positive or negative ground and pumps at 2.5-4.5 psi so it can be used without a regulator unless you experience flooding, depending on your carb(s). Can be purchased online direct.
    Dannerr and stillrunners like this.
  12. Crazydaddyo
    Crazydaddyo
    62pan likes this.
  13. winduptoy
    winduptoy
    358 degrees, that's hot. I'm thinking your ECU should have shut your engine down by now unless that is an EGT sensor.
    I'd go for a ride
    Jet96 and brjnelson like this.
  14. JT1930
    JT1930
    Has anyone seen one of these? What’s the deal with it. I’m thinking model T head. 734C8DA8-3CCE-44F6-B13E-FB6249C16BA3.jpeg 723FE488-8984-4939-9DD5-CA85D0EAF4F0.jpeg
    Dannerr and Jet96 like this.
  15. ratamahata
    ratamahata
    from Argentina
  16. studebakerjoe
    studebakerjoe
  17. JT1930
    JT1930
  18. studebakerjoe
    studebakerjoe
    JT if you don't use it I'd be interested in it.
  19. Freemoe
    Freemoe
    from Fowler, CA
    I just bought a 30 Model A coupe but am having an issue with starting. We timed it with a timing wrench but the first attempt must have been wrong as it backfired. The second attempt at timing worked but it was running rough. After though the car seems not to be getting any spark. What are some simple steps to figure out what might be going on? I have some Model A books that I'll be going through to start with the basics.
  20. V4F
    V4F
    from middle ca.
    *** at one time I tried to buy it from you , that's when you told me jay wanted it . at that point I figured I could not out bid jay …………… bummer
  21. V4F
    V4F
    from middle ca.
    I be interested also ……………….. steve
  22. Just purchased one! I plan on running a filter before it. I'll be fine right?
    walls likes this.
  23. MrModelT
    MrModelT
    Yes it is. He made that comment twice....so you know he meant it.
    Dannerr likes this.
  24. 5280A2
    5280A2
    If your tank is clean you should be okay without an inline filter. All I am using is the pencil filter that fits into the shutoff valve on the bottom of the tank to keep sediment out of the gas line. I have not seen any sediment in my carbs nor had any problems with the pump or regulator. I am using the Holley low pressure regulator on my car even though the pump pressure is advertised to be 2.5-4.5 psi.
  25. stillrunners
    stillrunners
    from dallas
    Not much happening but we still intact....and waiting on the great pumpkin to arrive........
    Jet96 likes this.
  26. jim1932
    jim1932
    So banger people. Finishing a B motor for my 32 coupe. My nature is rebelling against ford green. What color? Winfield red? Yellow?
  27. denis4x4
    denis4x4
    from Colorado
    ROCKER77 likes this.
  29. V4F
    V4F
    from middle ca.
    yes im sure he did . that's why I quit trying . my pockets are shallow unlike his ……. still a very nice car !!!!!!!!!
  30. jim1932
    jim1932
    yes but photo is a black block with red head.... black block is definately in consideration.... as the head is likely to be green....
    Dannerr, Dustyp489 and barrnone50 like this.
