Projects 1955 Chevy 4 door gasser build
Discussion in 'Traditional Hot Rods' started by Danbeverage55chevy, Oct 26, 2019.
  1. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Hey everyone. First build thread and first g***er build. I’m coming from the Toyota rock crawling world. Always wanted a 55 since I saw 2 lane black top and American graffiti. So I decided to take a break from rock crawling and build my dream rod.
    SPECS:
    1955 Chevy 4 door 210
    Corvette 327 64-5??
    283 powerpak heads
    Unknown cam
    Hedmen long tubes,
    2.5 pipe to h pipe
    Flow master super 10s
    Exit in front of rear tires
    Saginaw 343 trans hurst “Indy” shifter on floor
    Ford 9” 3:08 gears
    Drums front and rear
    Recently took off the worn out Holley and installed a new 600 cfm Holley and eps manifold
    100% woke this car up. I have the original Edelbrock torker manifold
    I have big plans for this build! Always seeking knowledge
    Torkwrench, TimCT, Butch M and 5 others like this.
  2. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Did some body work on it. Started patching the fire wall and body where the trim was attached [​IMG][​IMG][​IMG]
  3. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Picked up a metal flake wheel from so cal speed shop and also got a great deal on these long tubes from “ in rust we trust” swap meet in Sacramento [​IMG][​IMG][​IMG]
  4. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Driving through my neighborhood today I noticed a garage sale and picked these up for a steal! Started cleaning them up and noticed no breather holes in either one. Probably hanging them on the garage wall for now. [​IMG][​IMG]
  5. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    I’ll post updates as I have them. Almost daily! Thanks for reading. Plans are to solid axle if. Possibly do a g***er IFS style front end. Not sure yet. Seeking knowledge on both. Also brakes! Drums are scary on this ride!
    VANDENPLAS likes this.
  6. low budget
    low budget
    from Central Ky
    Good enough for me, Never saw too many 55s I didnt like!
    Keep up the good work!
    ( I like 4 doors too, but Im sure you will be interested in seeing the 2 door conversion threads on here)
  7. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    I’ve already been searching. That’s what finally got me to create a account and start a build thread
  8. swade41
    swade41
    from Buffalo,NY
    Nice start and good score on those 327 M/T's, don't drill them for breathers because there's plenty out there already with oil fill / breather holes.
  9. Should be a fun project. You do realize there's a big difference between 64 and 65 327 /250's right?
    BTW, you're probably using too much heat /weld on those holes. Yes ,you can straighten it out but you're making more work for yourself. ;)
    Danbeverage55chevy likes this.
  10. 56sedandelivery
    56sedandelivery
    Those M/T valve covers are the staggered pattern mounting, even though they say "CHEV 327" inside of them. Depending on the year of your Power Pack heads, they could either be staggered or straight across mounting pattern. Judging by the valve covers on the engine, I'm guessing they're the straight across pattern. Who knows why M/T made them staggered pattern for the "Chev 327" (327 came out in 62, the change of staggered to straight pattern occurred in 1959 1/2)? Actually a little more rare than straight across pattern M/T valve covers, so leave them as they are. One of our members here, and over on ChevyTalk.Org, is "2Loose". He built a 4 door, Model 150, with a blown Oldsmobile engine and a 5 speed transmission, along with a 9 inch rear end; check it out. I am Butch/56sedandelivery.
  11. wvenfield
    wvenfield
    All kinds of options to swap to disc brakes if you want to. Drum brakes shouldn't be scary though unless you drive like on a road course all the time.
  12. chevy57dude
    chevy57dude
    If you plan to get disc brake kit, be sure to ask questions. Some companies use metric parts. Not a bad thing, but I just like SAE wrenches on my car. Cool project. Ah, yes, another 'vette engine.
    Are you planning a 2 door conversion?
  13. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    I was all about doing the 2 door conversion, but then realized it’s all the same view out of the windshield. I’m just enjoying it for now. Learning as I go. Thanks for the positive input everyone. Very glad I made a build thread. I always have a ton of questions.
  14. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Also, I’ve SPENT hours trying to identify my block. I can find nothing except it was a flint built block, June 11th built from what I gather. Any help on this would be appreciated [​IMG]
    lothiandon1940 likes this.
  15. lothiandon1940
    lothiandon1940
    .......Squirrel will know.:)
  16. Budget36
    Budget36
    Yes he will, let's page him;)
    @squirrel
  17. traffic61
    traffic61
    from Owasso, OK
    “I was all about doing the 2 door conversion, but then realized it’s all the same view out of the windshield. I’m just enjoying it for now. Learning as I go. Thanks for the positive input everyone. Very glad I made a build thread. I always have a ton of questions.”
    I like your at***ude! Keep up the good work.
  18. squirrel
    Look at the back of the block, on top, just in front of the bellhousing. Should be another couple of number sequences, one will be 7 or 8 digits, the other will be a letter followed by 2, 3, or 4 digits. Let us know what they are, then we can figure out for sure what the engine started life as.
    of course that won't tell us what's inside it now...
    Also, don't be disappointed if it turns out it's a 283, not a 327.
  19. Fordors
    Fordors
    The GF suffix shows your block to be a 283, if it has no side mounts cast on the block it is a ‘57, if the mounts are there it is a ‘64 or ‘65.
  20. squirrel
    I don't see GF for 64, only for 65-67 283. And 56 265, and 57 283 with Turboglide and FI (which is totally unlikely). But I'm looking in old Chevrolet parts books, so who knows.
  21. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Then motor is pressed back in the firewall pretty hard. It does have castings in the side for motor mounts. I’ll head outside and use a mirror and flashlight to try and get a better idea. Thanks for the replies
  22. squirrel
    It's most likely a 65-67 283 from a full size Chevy. The specific year doesn't really matter much, as far as what the engine started as, there were very few changes over those years.
    btw when you buy a car or an engine, the seller can tell you anything. If you want to know what it really is, you have to find a way to determine that for yourself. Or else ***ume that it's the least desirable version, rather than the most desirable.
  23. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    Thanks for the insight, I was hoping the guy was telling the truth. Looked like a 327 to me. Came with the car I didn’t pay any extra for it. No harm no foul. Whatever it is it runs awsome has a nasty cam in it and loves 6200 shifts! I need to find a Muncie 4 speed. M20-m22 and re gear that 9” to a 3:70-3:90. I drive it around town and to work sometimes
    Old wolf likes this.
  24. squirrel
    The thing about Chevy engines is they all look the same, mostly :)
    As long as you're having fun, that's what counts.
  25. Danbeverage55chevy
    Danbeverage55chevy
    from Concord
    I don’t get hung up on this kinda stuff to much. I saw a add online for cars and coffee today in my town (concord ca) so I figured I’d check it out. No muscle. Air bagged Honda’s, scions, new challengers with straight pipes. I did see a Datsun truck with a ford 302 swap. Wish I took some more pics. We have 80 mph wind today and I was trying to keep the hat on my head and dust out of my eyes
  26. DDDenny
    Hope you are saving up for that M-22!
  27. rustydusty
    rustydusty
    Welcome to the HAMB. Ya gotta avoid posting pictures of off topic cars though. Looks like you have a great start to a cool hot rod!
  28. yep its a 283 I can tell from the larger rib next to the pad with the stamped numbers. the 67 283 did not have that larger rib it resembles a 327 block so you have a 66 or older 283. Yep 308 is too tall rear gears. a 411 would be good.
  29. I thought they were 3.00 ratio commonly available.. Early trucks had a 3.07 and 3.10 I think.
    Not that matters much if the o/p is a little off..but could be off by a mile too ;)
  30. Also , Saginaws were 3.11 or 3.50 first gear Again, no big deal..283? 327? No problem.
