Projects 29 ford roadster fix
Discussion in 'Traditional Hot Rods' started by Flop, Oct 29, 2019.
  1. Flop
    Flop
    [​IMG][​IMG]
    Lots of subframe work to make it right
    tb33anda3rd, Stogy, warbird1 and 11 others like this.
  2. lothiandon1940
    lothiandon1940
    This is going to be good folks.
  3. Flop
    Flop
    [​IMG]m
    Tacked in the patch I made
    Done
    Next side
    tb33anda3rd, Stogy, 51box and 8 others like this.
  4. Flop
    Flop
    tb33anda3rd, Stogy, RICH B and 10 others like this.
  5. brady1929
    brady1929
    Oooooo, I love model a roadsters. This is going to be great.
    Flop likes this.
  6. Incredible!
    not that I recommend it, but you could chew on a wad or aluminum foil and spit out a perfect panel !
    Your metal fabrication skills are perfection !
    A gentleman a****st peasants with your welder !
    Hats off and a cold beer !!
    rusty valley, Stogy, Flop and 2 others like this.
  7. hotrodjack33
    hotrodjack33
    Where'd the welds go???? Now THAT'S metal fabbin'
    Flop and lothiandon1940 like this.
  8. A Boner
    A Boner
    Go Flop, go!
    Flop likes this.
  9. Barn Hunter
    Barn Hunter
    Gotta watch this...always a learning experience!
    Flop likes this.
  10. Flop
    Flop
    Thanks folks !
    Test piece I made up
    Tim, barrnone50, tb33anda3rd and 9 others like this.
  11. Nice work as usual! The new shop looks great!
  12. do you find that you get more or less distortion when welding patches in with straight cuts and 90* corners or with rounded more free form edges? I can see it is easier to make it fit good with straight edges but I have had good luck with rounded patches.
    Stogy likes this.
  13. Flop
    Flop
    Done it all the ways and all seem to be pretty close to the same results .
    Stogy and 46international like this.
  14. thanks for the response, At times I have a hard time controlling warping at an hard 90* corner. But was surprised at how well it turned out when I did a round patch. I guess that is where skills come into play.
  15. Stogy
    Stogy
    Hope all is well with you and those close to you...Just giving you a buzz to see how your doing...I think this was the last project you were up to here...they are all an inspiration every darn one of them...;)
    rusty valley likes this.
  16. sloppy jalopies
    sloppy jalopies
    ditto...
    Stogy likes this.
