Hot Rods Clutch Chatter
Discussion in 'The Hokey Ass Message Board' started by Pewsplace, Oct 29, 2019.
  1. Pewsplace
    Pewsplace
    I have a 46 Ford woodie wagon with a 283 SBC hooked to the stock transmission. This set up has no anti-chatter rods. I am experiencing moderate clutch chatter in low gear when I take off. Does anyone have any ideas on how to correct this problem? I have been told that the Hurst mount is the problem but I have run this set up previously on other cars with no chatter. Would side motor mounts eliminate the problem? Any suggestions? Thanks!
  2. Pewsplace
    Pewsplace
    The stock steering is also very difficult to turn in a static position on my 46 Ford Woodie. Would a Saginaw 525 box help the steering effort or should I go to the 605 p/s box?
  3. missysdad1
    missysdad1
    Hurst used to make and sell anti-chatter devices which worked with their saddle mounts. They were angle-shaped and attached with the motor mount bolt. Look in the old mags for more info. They were advertised there. Good luck!
    Pewsplace likes this.
  4. alchemy
    alchemy
    Can you make a simple bracket at the bellhousing to mount the chatter rods to?
    Pewsplace and olscrounger like this.
  5. seb fontana
    seb fontana
    from ct
    Do the 605 p/s box.
  6. Nailhead Jason
    Nailhead Jason
    My 39 has little clutch chatter when reversing, especially up a slight incline (my driveway) . I'm planning on making brackets off the bellhousing bolts go attach to the original arms (283 hooked to the 39 trans)
    Pewsplace and lothiandon1940 like this.
  7. Pete Eastwood
    Pete Eastwood
    from california
    Put anti chatter rods in it, you'll have to make the brackets for the bellhousing end, & modify the stock rods .
  8. dana barlow
    dana barlow
    from Miami Fla.
    A few common chatter things; warped disk,bad flywheel/with burn cracks,bad trans mount,wrong drive shaft angles,motor mounts are now soft.
    Steering hard;box adjusted too tight,Tiny steering wheel been added,less then car came with,front rims are wrong off set an or tires too wide,running tire psi too low/thinking its a better ride,Steering pitman arm is longer then what came with car.
    Other things can be wrong,but there's a fast lists.
  9. missysdad1
    missysdad1
    Here ya' go...
    Prolly can't find 'em nowdays but shouldn't be too hard to fabricate.
    Good luck!
  10. 19Fordy
    19Fordy
    Check the condition of the rubber biscuits on your transmission mounts. When these are worn or loose you'll get chatter. Same with front mounts on engine.
    Here's an aftermarket kit that was made for 40-48 Fords. IMG_5839 (Small)best.jpg
    Bolts to bellhousing and hooks to X member. They come up on Ebay once in a while.
    I remember seeing a posting on Fordbarn of a sketch showing how to make anti chatter rod kit. Go to Fordbarn and do a SEARCH on Anti chatter Rods. Here's a start.
    https://www.fordbarn.com/forum/showthread.php?t=254926&highlight=anti+chatter+rods
    Pewsplace and kadillackid like this.
  11. Pewsplace
    Pewsplace
    Thanks for all the tips. I will try to make some rods to see if that helps. All parts seem to be brand new with low miles, so the rods should do the trick.
    lothiandon1940 likes this.
