Technical Parking light repair 54 belair
Discussion in 'The Hokey Ass Message Board' started by monteg0, Oct 31, 2019.
  1. monteg0
    monteg0
    I hadn't had any luck sourcing the turn signal buckets for my 54 210, save for some sketchy ebay chinese repops for $50 each so I decided to see if I could rig something together, and stumbled on something really, really easy. hopefully this helps someone else out.
    I had a ton of rust in mine, and I just wasnt getting good contact.
    I took a pair of pliers, and gently popped the socket out of the housing, and then roughed up the areas the bucket needed for ground. it slightly deformed when I removed the old socked, so I also gently tapped the hole flat again
    after measuring, I headed down to the local O'Reillys, and found a universal replacement that matched the 3/4" hole for $2.99
    I bent the little tabs in so the socket would slide in, and then used the holes in this old trailer bumper to told it steady while I drifted the tabs out with a hammer and a screwdriver.
    [​IMG] [​IMG]
    so far pretty happy. I did have to make some wire splices, I used the original wires coming from the distribution box, and just made sure I had the two wires connected right with wirenuts before I made a permanent connection, only because I'm an electrician by trade and kind of ocd about colors matching on wiring if at all possible. all in all, took about 5-10 minutes a side. like I said, hopefully someone finds this helpful!
  2. Jalopy Joker
    Jalopy Joker
    did good - next time clean housing more and spray area where bulb goes with silver
    indyjps likes this.
  3. monteg0
    monteg0
    thanks! I would have prepped and painted them up all pretty, but it was barely above freezing today and I get yelled at when I spray indoors :D
    '51 Norm likes this.
  4. 302GMC
    302GMC
    from Idaho
    Those will last about a year before the ground becomes less & less reliable. Pull the wire & plastic out, & braze or solder them to the bucket & they'll last … white paint will produce a better background.
  5. monteg0
    monteg0
    it does look like the original paint was white.
    solder isnt a bad idea, but I think I'll just see how it goes for now, since I'll be pulling them next spring to paint anyway
  6. BJR
    BJR
    Surprisingly one of the car magazines did a test with different backgrounds in the reflectors of tail light housings. Painting them white reflected more light than silver paint or aluminum foil.
  7. monteg0
    monteg0
    that makes sense.
  8. monteg0
    monteg0
    3 year update, car lives outside 100% of the time, and they're still working fine.
    Chucky, 302GMC and PhilA like this.
  9. fastcar1953
    fastcar1953
    Cool, thanks for the update.
    monteg0 likes this.
  10. PhilA
    PhilA
    I had a bit of fun trying to polish up and nickel plate mine, but overall the light output from lights like these relies mostly upon accurate location of the bulb in relation to the lens rather than the light thrown forward from the reflector.
    White paint works just as well, amd is a lot easier.
    Someone repaired one of mine by welding(!) a new holder in place, which offset the bulb a quarter inch or so. That causes the light to be split and thrown away from central.
    Phil
  11. Way to go, glad that worked for you. With some of the new products the metal is so weak once you bend them they break. Tried to bend some around pot metal housings and all the tabs broke.
    On sheet metal a little thinner it looks like it worked.
    monteg0 likes this.
