Projects My Traditionally inspired ‘40 Chrysler
Discussion in 'Traditional Customs' started by sodakmini, Nov 2, 2019.
  1. sodakmini
    sodakmini
    I suppose I should finally start a thread on this thing. I did a ton of research, knew I wanted a 40s car. Fell in love with 40 Plymouths, then stumbled across this on the list. Me and my son made a overnight 10 hr each way trip to Topeka KS in August of ‘17 and yanked it home. Was a 100% original untouched survivor, exactly what I wanted. With the upmost important factory overdrive (I wanted to drive this thing anywhere). Long story short it was a super clean untouched car. 1940 Chrysler Windsor club coupe. 241 flat 6 factory O/D, 3 on the tree. First pics are of the sellers listing.
    T.L., jakespeed63, 504640 and 29 others like this.
  2. sodakmini
    sodakmini
    When we got it home, we enjoyed it for a few months. The previous owner had a few cars. This one had been sitting for a bit. He admittedly hadn’t washed it in 10 years. Every scratch and blemish had dirt caked into it. I scrubbed it with every high dollar whatever, but it wouldn’t clean up. So me and a buddy to the polisher to it. Essentially wet sanded it with a light scotch brite and the a 3 step cleaner/polisher. Lost some paint. But a far better looking car in my opinion. Here are some before and afters. IMG_6713.JPG IMG_6715.JPG IMG_6716.JPG IMG_6717.JPG IMG_6720.JPG IMG_6718.JPG IMG_6722.JPG
  3. sodakmini
    sodakmini
    I really wanted a late 40s custom taildragger. So next was the stance. Started with 3” posies rear leafs and 2” blocks. Here is the stock nosebleed to the after. IMG_6735.JPG IMG_6737.JPG IMG_6781.JPG .
    Put a number of miles on that. Since then we have moved from Pierre SD. To the Black Hills of SD. After getting settled in I took to it again.
  4. sodakmini
    sodakmini
    Last winter I blew apart the front end. Cleaned and painted everything but the steering. Redid the drive line. Swapped the 2” rear block for a 3”. And put some Aerostar springs up front. Ended up knocking an additional half coil off the front springs. 35D59423-DA71-4237-9216-A8E4FB91EC57.jpg FFAF3D55-FA85-4404-953E-710894483279.jpg .
    IMG_8046.JPG I’m really unsure where all my suspension pictures went to. But I’m sure you’ve seen painted control arms and such before.
    I also blasted the stock faded wheels and sprayed them in a vintage white. Added some full 2 piece caps
  5. sodakmini
    sodakmini
    I also sucked in the front bumper 2.5” and got rid of the fogs and eye brows.
    6949089D-40F9-48CE-A6AE-506D38B79749.jpg A2CDA5F2-D14E-457F-A6D8-1A4844AE7CE7.jpg
  6. sodakmini
    sodakmini
    This current winters project is dealing with a leaking head gasket. So in turn I have blown it apart. Took another .23 off the head so it’s at a total of .38. Me and a good buddy split a stock exhaust manifold. And as I was removing the stock intake I found out there was a hidden 13th nut. Oops. I also bought a complete engine gasket kit to re seal the ol girl. IMG_8585.JPG 7675333C-C18D-4D9A-BD66-A6EEB3B251B4.jpg IMG_8385.JPG IMG_8386.JPG IMG_8388.JPG IMG_8425.JPG IMG_8431.JPG IMG_8603.JPG IMG_8582.JPG 445C8645-5441-4F2A-A3B3-1229F099E566.jpg . So now I’m pained with finding or fixing the stock intake. Or.... maybe a dual??
  7. Awesome car,...good luck with it.
    sodakmini likes this.
  8. 'Mo
    'Mo
  9. Roothawg
    Roothawg
    I really like where this is going.
    UNSHINED 2 and sodakmini like this.
  10. sodakmini
    sodakmini
    Interesting is right. The runner Seems awfully small. I had a line on a neat triple. But I think it will be to much.
  11. sodakmini
    sodakmini
    So I have been on the hunt for an affordable 2nd carter carb. Was watching for a few weeks. My buddy kept telling me to be patient, something would come along. He sends me a picture the other day and somehow had the perfect one in the back of one of his cabinets. So I sent them with a local old fella and he rebuilt both of them for me. Did some swapping and proper jetting on them to set me up right. Soooo... I now need an intake. Back when I lived in Pierre one of my neighbors walked over one day to check out my car. Long story short. The ol boy had a stock dodge truck flat 6 dual intake. Someone had cut both heat risers off of it at some point thru it’s life. So I’m making arrangements to head back home and pick that up. Lot easier to explain to the wife after I “forgot” the 13th nut on the stock intake removal. Hehe. Hopefully some pictures will come soon.
  12. rusty rocket
    rusty rocket
    Kool stuff
  13. 302GMC
    302GMC
    from Idaho
    That's only a balance tube between the stubs - no problem. Please tell us what you picked for mufflers - hoping to hear something like 22'' Porter steelpacks ...
    You do nice work !
    UNSHINED 2, Stogy and sodakmini like this.
  14. sodakmini
    sodakmini
    Well. My end game is a couple porters. But... they are a little more than cherry bombs. Sooo. She’s going to be straight piped. I’m sure that will last 11 minutes and then I will scrounge up some money and buy some porters.
  15. What a GREAT car!
    Hnstray, 'Mo and sodakmini like this.
  16. Terraizer
    Terraizer
    awesome car and build
  17. goldmountain
    goldmountain
    Really like your car. The modifications look like they are well thought out.
    L7 and sodakmini like this.
  18. 'Mo
    'Mo
    I've got custom, straight-through 16" Porters on my Fleetline (no dia. reduction inside canister :eek:), so basically they are echo cans. Save your money, and use MC baffles inside the tailpipes. They come in various lengths and diameters. THEN... wrap them with fiberglas matt or cloth, to fine tune the volume you desire. (This is where the muffling really becomes effective. ;))
    Are skirts in the cards?
    williebill, chryslerfan55 and Stogy like this.
  19. sodakmini
    sodakmini
    Hey I like that idea. Thanks. And yes there will be a custom set of skirts on it by spring.
  20. Bigmac48
    Bigmac48
    from Dundalk Md
    Love it , nice job
  21. BadgeZ28
    BadgeZ28
    from Oregon
    My father would be drooling all over it if he was still alive. He had a 41 Chrysler he finally let go after it sat for years in the 1960's. He had taken two intakes and exhausts and made dual carbs/exhaust for it. He street raced it a couple times. I was just a kid and don't remember the details but he locked it in one gear for racing if I remember correctly. Enjoy yours.
    chryslerfan55, sodakmini and 'Mo like this.
  22. sodakmini
    sodakmini
    Very kool! Thank you.
  23. Looks like a 'shine hauler, loaded up and ready to make a "delivery"! :cool:
    chryslerfan55 and sodakmini like this.
  24. 296moon
    296moon
    from england
    Not a lover of 40s plymouth, BUT this ones really neat!........................
  25. scrap metal 48
    scrap metal 48
    Like what you have done with your 40.....
  26. partsdawg
    partsdawg
    from Minnesota
    Tastefully done
  27. Bmac40Ply
    Bmac40Ply
    Nice looking ride! If you ever want the front end lower, relocating the spring perch to the bottom of the control arm drops it nicely.
    scotty t and chryslerfan55 like this.
  28. 'Mo
    'Mo
    I took a couple of ideas to the Photoshop thread, and @themoose worked his magic.
    Later on, molding the rear fenders and hididen gas filler would be the cheese.
    T.L., Elcohaulic, Okie Pete and 7 others like this.
  29. sodakmini
    sodakmini
    Looks good! Bit more 50s than I plan, but maybe sometime in the future.
  30. tubman
    tubman
    Boy, I don't know about " molding the rear fenders and hidden gas filler"; I think it's just about perfect as it is. I was reluctant to open this thread at first, because I though "who cares about those cars?". WOW! Was I wrong. I really like how this is turning out! I think what you are considering may just be overdoing it.
