Hot Rods 28 Roadster 32 Frame Hemi Build Thread
Discussion in 'The Hokey Ass Message Board' started by 208custom, Nov 2, 2019.
  1. 208custom
    208custom
    I have had this car and a lot of ideas for it rattling around in my head for a while. I started collecting parts around 8 years ago and now it is finally moving forward and I figured I would share some of the progress here. As I write this the rolling ch***is is for the most part completed. I will try to continue to add updates as things move forward however progress will likely slow through the cold Wisconsin winter.
    First thing first, a plan.
    Here is the frame as I got it from my buddy Josh in Spokane. It had a hard life and was pulled out of a river bed near Spokane.
    After several more years collecting parts and getting things cleaned up it was time to head up to my friend Johnny’s (johnnyboy76 on here) shop, Weldco Custom Fabrication in Sparta Wisconsin and start building a roller. No way could I have built this ch***is without Johnny’s help!
    Blue One, Tim, kidcampbell71 and 3 others like this.
  2. 208custom
    208custom
    Everything unloaded in the shop.
    Rails in the table! Pretty easy to see how twisted they are now.
    Luckily Johnny happened to have a roadster body to use to get our dimensions set.
  3. 208custom
    208custom
    Shop foreman Hachi making sure we don’t **** anything up.
    Got the rear end and front end in place.
  4. 208custom
    208custom
    Johnny built this Flat front crossmemeber to get things low.
    Tapped some tube for the hairpins. Front suspension uses a V8-60 axle, 33-4 front spring, Old Bell Auto batwings and Round back spindles.
  5. 208custom
    208custom
    Stiffening things up by double walling/boxing the frame in.
    Got the engine and trans mocked into place, ready to figure out mounts. Using a 53 331 Chrysler Hemi backed by a 37 Packard trans.
  6. 208custom
    208custom
    Motor mounts cut out.
    Moving to the back. Used some later 40 Merc rear kick ups to bring the *** end down. The same frame donated its X member. 36 Rear end and bones with Model A spring and cross member.
    Blue One, alfin32, Tim and 3 others like this.
  7. 208custom
    208custom
    I cut out the parts to locate the front of the bones and Johnny welded everything up. Using Pete and Jakes adjustable rod ends.
    Lots of grinding and its starting to look like something.
    Chassis 37.jpg Chassis 38.jpg Chassis 39.jpg Chassis 40.jpg Chassis 41.jpg Chassis 42.jpg
  8. 208custom
    208custom
    Back home for some glamour shots. Got my Body placed on the frame and now it’s ready for many hours of body work. I will try to update as I move forward. Again, Could not have done this without Johnny’s help and experience, really happy with how it turned out so far.
    Chassis 43.JPG Chassis 44.jpg Chassis 45.jpg Chassis 46.jpg Chassis 47.JPG Chassis 48.JPG
  9. Rich B.
    Rich B.
    from Portage,IN
    What a great start, love the quality of workmanship!
    Rich
    kidcampbell71, 208custom and loudbang like this.
  10. bct
    bct
    happy to subscribe
  11. A Boner
    A Boner
    Wow, what a great start to a real Hot Rod!
    kidcampbell71, loudbang and 208custom like this.
  12. Tim
    Tim
    from KCMO
    Very cool! Looking forward to what’s to come
  13. brady1929
    brady1929
  14. 208custom
    208custom
    Thanks everybody, feels pretty good to finally start moving on this project.
    kidcampbell71 and loudbang like this.
  15. Rick Phillips
    Rick Phillips
    Some quick work by your friend, cool project.
  16. stillrunners
    stillrunners
    from dallas
    Nice work youse guys....carry on !
  17. Bugguts
    Bugguts
    Subscribed. Looking forward to more coolness!
  18. Lil'Alb
    Lil'Alb
    from brier, wa
    This is thing is going to rock! What kind of headers you thinking?
  19. continentaljohn
    continentaljohn
    Any update *****en build
    brady1929 and kidcampbell71 like this.
  20. 208custom
    208custom
    I am going to use the big truck hemi manifolds but smooth them out and have them chromed. They are oversized from the p***enger car version and dump out in to 2.5" pipe.
    Just many hours of trying to fix all the junk body panels I thought were a good idea to buy. Its slowly taking shape but I'm no sheet metal wizard.
    Went back up to my buddies and we adjusted the spindles for tie rod clearance. 3.jpg 4.JPG 6.jpg 7.jpg
    Tires are some cheap rollers I got ahold of, fronts will come down a size eventually.
    Thanks for the interest guys!
    bostonhemi, Blue One, alfin32 and 5 others like this.
  21. Tim
    Tim
    from KCMO
    I believe the proper pronunciation is “oh **** yeah”
    Looks awesome man
  22. 51box
    51box
    from MA
    Oh man that thing is mean looking! Nice work, keep the updates coming
    loudbang, 208custom and dirty old man like this.
  23. IronFord
    IronFord
    from NoDak
    How’s the roadster coming along?
  24. jimmy six
    jimmy six
    Are you going to leave the holes on the left rear corner of the panel under trunk/rumble seat showing it’s a true 28? A single tail light mounted to the body.
  25. 208custom
    208custom
    The Panel under the decklid is a repro part I got used off ebay so I do not think it has all the correct holes for 28. The whole body has been pieced together so realistically it is a little 1928 and a little 1929.
    chryslerfan55, jimmy six and loudbang like this.
  26. 208custom
    208custom
    I have still been plugging away on the body work. The quarter panels have been a headache. I bought both quarter panels on line sight unseen and its easy to tell why other gave up on them. Both had been cut out for pickup beds many years ago and the p***enger side looked like a bag full of walnuts and had a poorly done lower patch installed. RDSTR BODY 1.JPG RDSTR BODY 2.jpg RDSTR BODY 3.jpg RDSTR BODY 4.jpg
    chryslerfan55, alfin32 and loudbang like this.
  27. 208custom
    208custom
    The Subrails I had where pretty crusty and after setting on them on the frame I did not like the way things looked and flowed. Nice thing about starting with junk is you don't have to worry about hacking it up. There is not a lot of original subrail left at this point.
    RDSTR BODY 5.JPG RDSTR BODY 6.jpg RDSTR BODY 7.jpg RDSTR BODY 8.jpg RDSTR BODY 9.jpg RDSTR BODY 10.jpg RDSTR BODY 11.jpg RDSTR BODY 12.jpg
  28. 208custom
    208custom
    With Subrails somewhat in place I began bracing and squaring up the body. I also cut out some temporary wood floorboards to get an idea of what it will look like. Still a lot of welding and grinding to be done. RDSTR BODY 13.jpg RDSTR BODY 14.jpg RDSTR BODY 15.jpg RDSTR BODY 16.jpg RDSTR BODY 17.jpg RDSTR BODY 18.jpg RDSTR BODY 19.jpg RDSTR BODY 20.jpg
  29. 208custom
    208custom
    Here it is as of yesterday. Still a ton of body work to be done. Haven't starting fixing the doors yet and plenty of hammer and dolly work to do. The body will come apart and go back together many more times but at least it resembles a car RDSTR BODY 21.jpg RDSTR BODY 22.JPG RDSTR BODY 23.JPG RDSTR BODY 24.JPG
  30. continentaljohn
    continentaljohn
    Looks awesome and some killer fabrication
    208custom, Blue One and loudbang like this.
