Hot Rods What is this old hotrod coupe body?
Discussion in 'The Hokey Ass Message Board' started by corndog, Nov 2, 2019.
  1. corndog
    corndog
    from Indiana
    I need some help identifying this old hot rod coupe body. I am pretty sure it is a Mopar of some sort but hoping one of the Mopar experts on the HAMB can tell me what year and what model. It is a 5W body and looks to have had suicide doors. I dont coupe body (1).JPG coupe body (3).JPG coupe body (2).JPG own it, just ran across it. Too bad it is missing so many parts!! Thanks in advance for any help! C-dog
  2. RMR&C
    RMR&C
    from NW Montana
    My best guess is '33 Dodge...but would need to see the dash and a side view pic to narrow it down further.
  3. catdad49
    catdad49
    Looks like a '34 Plymouth/ Dodge, what's there seems really solid. What's the rest of the story?!
  4. corndog
    corndog
    from Indiana
    No dash and I couldnt get far enough back from the sides to get a profile. What you see is what is for sale.
  5. scotts52
    scotts52
    I agree with catdad. If it were a Dodge it would have firewall extensions. 33 Plymouth has the door posts slanted a little differently. The bodies are basically the same with Dodge otherwise. The model is based on the fenders and running boards. The shell is shared throughout the different models.
  6. oldiron 440
    oldiron 440
    Doors and deck lid?
  7. flamedabone
    flamedabone
    You are a wuss if you don't buy it.
    Doors and decklid might **** a little to find, but that is a nice little body.
    -Abone.
  8. 2deuces64
    2deuces64
    Look at the A pillars, If you can lay a straight edge up the pillar (inside the door opening) and it touches all the way up it is a 33 Dodge or Plymouth. If the straight edge has a gap at the base of the windshield post ( the posts are leaned back) it is a 34 body. Hope that make sense.
    Hamtown Al likes this.
  9. A Boner
    A Boner
    Whatever Mopar it is, they look good on a Deuce frame!
    nunattax, 29EHV8 and kidcampbell71 like this.
  10. 31Dodger
    31Dodger
    Looks to be a 1933 Dodge with the single cowl vent.
  11. 31Dodger
    31Dodger
    It is a 1933 Dodge Brothers with that single, exposed cowl vent.
  12. scotts52
    scotts52
    Not Dodge, it's a Plymouth. I have a Dodge. The cowl has what looks like cobbled on sheetmetal to extend the firewall out a few inches. Gives the occupant a couple more inches of legroom. Doors can be had easier than the deck lid. If you don't mind cutting truck doors down about an inch to fit, that's going to be easier than finding coupe doors. Deck lid is going to have to be home made or aftermarket fibergl***. Unless you have tons of patience. I've heard people with coupes say they've been looking for years to find an original.
  13. 31Dodger
    31Dodger
    33plymouth005.jpg Now that I look closer, the two door hinges would make it a Plymouth. Here is a similar body....everything matches. The indent just in front of the vent, the two hinges, the grooves on the sides/top of the cowl....
  14. corndog
    corndog
    from Indiana
    Dodger, so I am ***uming that the picture you posted of the coupe in yellow primer is a Plymouth?
    31Dodger likes this.
  15. verde742
    verde742
    Betcha ITS a Plymouth
  16. 31Dodger
    31Dodger
    Yes. With a different (Chevrolet) radiator shell.
  17. Looks like an abandoned project at an abandoned property . Meth head s****pers probably stole what they could carry on their mountain bike. I knew a guy who had quite a few projects at his remote farmhouse. He went to prison for a while and all the projects outside were stolen.
    nochop likes this.
  18. cornfield county
    cornfield county
    from Indiana
    Good luck finding doors for that coupe.
    nunattax likes this.
  19. jimgoetz
    jimgoetz
    34 Plymouth. That's what my avatar is.
    4274SPEED likes this.
  20. 31Dodger
    31Dodger
    Do you know the differences between the 1933 and 1934 Plymouth coupe bodies?
  21. Chaz
    Chaz
    They are a cool body style... They look chopped when they're stock 33 plymouth.jpg
  22. jimgoetz
    jimgoetz
    Not sure but I think the grill shell was different. Also the 34 had coil spring front end. I think this was the first year for that.
  23. paul55
    paul55
    from michigan
    Just ran across a driver's door for the body shown above. Found it on facebook.
    kidcampbell71 likes this.
  24. 31Dodger
    31Dodger
    That stuff I already knew. The hoods were different, too. I was mentioning the bodies. I see no differences.
  25. scotts52
    scotts52
    Grille is different between the 2 years. Also, the 33 cowl posts are more upright and leaned back more on the 34. There were several different models and thus different wheelbase but that difference was made up in the hood and running boards. Dodge also had a couple different wheelbases. The body shell is identical between the 33 Plymouth and Dodge except for the cowl extension on the Dodge. Same thing again in 34.
    Jimgoetz is right about the 34 having a coil IFS. Except for the base models which still had the solid front axle.
    Also, the front fenders are slightly different. Plymouth was smooth along the forward brow of the fender where as the Dodge has a little design to it. Almost anything can be interchanged as long as it all goes along with the correct wheelbase ch***is.
    jimgoetz likes this.
  26. 31Dodger
    31Dodger
    Thanks for the lesson! Always willing to learn more about MoPars.
  27. 56don
    56don
    There is one for sale in the hamb cl***ifieds now for 300 bucks
  28. stanlow69
    stanlow69
    I have heard 4-dr sedans have the same doors as of coupes. I have a couple on a parts car. And a couple parts cars. The trunk lid looks like it`s a rumble seat car. You can flip it around and use it as a trunk lid. Latch handle would be in the same spot. But the lid is a bit shorter. All 33 and 34`s Mopar coupes have suicide doors. And they are all 5 windows. Coupes that is. Did you buy it? How much is it? And where at.
    oliver westlund likes this.
  29. Dodge and Plymouth had very nice styling--friend of mine in high school had a '34 Plymouth with a Rocket 88 Olds engine and trans in it. They had more leg room than the same year Fords.
  30. scotts52
    scotts52
    I have heard that the 33/34 Dodge and Plymouth coupe were better than Ford or Chevy but they didn't make as many and the support wasn't there like with Ford so they got overlooked more.
