Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. Wardog
    Wardog
    I clamped my headlights on for a look today.
    I reworked the exhaust mounts ( and didn’t take a photo) then put it back on the ground.
    18EAB068-777E-4B2C-A5BE-DDCE5F008926.jpeg 10F70378-339D-4AFD-BC04-BAB4F73BF830.jpeg
  2. oldschool59
    oldschool59
    This is an awesome build, the right hand drive part throws me ,keep thinking the pics are backwards. What head lights are those ? They are exactly what I have been looking for for my 31.
  3. Coming along nicely mate, look forward to more progress!
    Wardog likes this.
  4. Wardog
    Wardog
    Yeah we are right hand drive down under. I have no idea what the lights are from. The stands have GMC cast into them. A friend gifted them to me, after a friend from Bakersfield gifted them to him.
  5. Coming along nicely mate, look forward to more progress pix !
  6. Wardog
    Wardog
    I mentioned that I reworked the exhaust brackets the other day. Today I finished them off.
    You can see in this photo as well that I have reworked the front left brake line and the way is sits on the cross member.
    The left side bracket was made to clear the brake line and the right was made to be symmetrical with the left. The angle of the rod makes it hide a bit, they should be hard to spot with the body on.
    The bolt on angle brackets are made to pick up on factory holes already in the cross member.
  7. Elvis100
    Elvis100
  8. Wardog
    Wardog
    I bought a vintique grille and insert.
    6D863835-CA2B-4426-9D43-4ED563029D2F.jpeg F4434CD4-9DEE-48CE-B20C-3F0F03A9C036.jpeg
    But I’m worried these headlights might look a tad large. Especially the depth of the buckets. I don’t know how well they fit into my mid 40’s style I’ve been trying to run with.
  9. Stogy
    Stogy
    @Wardog perhaps when you have the
    Body and Hood it will help balance things out. I guess OD is same as most Guides but the depths vary...
  10. Wardog
    Wardog
    @Stogy yes they are a 7” headlight. They might stand out less when black. In photos they don’t look bad but when I stand next to it they look long.
    1947knuck and Stogy like this.
  11. Stogy
    Stogy
    I have seen deeper guides used but they are certainly less common than the shallower Guides...
  12. alchemy
    alchemy
    Your headlights stick out too far. Bring them in at least an inch, maybe two, per side.
    I personally prefer the shorter bucket Guide/BLC lights, but the longer ones aren't "untraditional".
    Stogy and Wardog like this.
  13. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I agree, they need to be closer to the grille shell and maybe a little lower. I understand not wanting to modify your brackets. Maybe when everything is painted and you add a hood it will all come together? I have 680's on my deuce highboy pu but mine have chrome rims which helps them to look better along the insert with polished rim.
  14. Wardog
    Wardog
    @alchemy @krylon32 thanks for the replies. I agree, I think they at least need to be bought in towards the grille and probably lower. I think it might be better to make some custom brackets than modify the stock ones. They look a bit heavy duty from the front. These have chrome rims but are covered in paint at the moment. I'm not planning on running a hood that's why I'm questioning the depth of the buckets.
    I probably should sort out a radiator and mount the grille properly first.
    1947knuck, chryslerfan55 and Stogy like this.
  15. grdra1
    grdra1
    Awesome build, exhaust brackets are way cool along with rest of build, I feel headlights in a little but height is ok, I would put the body on before deciding on final position of lights. Just my two bobs worth. Glen
  16. Wardog
    Wardog
    Hey Glen. Thanks mate. I know everything would be easier to line up with the body on but I’m trying to keep my coupe driving as long as I can.
    Completely backwards I know but I guess I’ll figure it out or I’ll have to make that move.
  17. Wardog
    Wardog
    Feeling a bit snookered with setting the grille and headlights up I decided to keep productive elsewhere. I stripped and painted the frame this weekend. I’ve decided to wait until the body is on to set the radiator/grille height. I’ve also decided not to run the GMC guide style headlights and am now looking for some King Bee’s. The first 3 photos were taken by my son who was a great help this weekend. I also had a visit from @yblock32 who helped me move it back inside.
    0B25FAAD-483B-4616-A7C7-34C651D68A7B.jpeg 99944B5F-61A1-4BDA-A00F-4956A8619793.jpeg 735675A0-494C-4E1D-87F0-BC88B3A98B14.jpeg E7F33304-9755-4D0E-8350-B5CF6F4628B0.jpeg E107A6E4-8910-48A1-B993-35FB021536FA.jpeg A5D93988-C6E0-4880-A1FC-3DEC832473B9.jpeg
  18. Wardog
    Wardog
    One of the jobs I wanted to do when the engine came out next was the clutch arm. The stock 32 arm is 4.75” centres and the one I had was only 3”. Today I extended it 1.5” to 4.5”
    D674088D-4157-4EA7-BF40-A84953CB6358.jpeg 42838CAC-2E5C-4B60-83EE-9EAA4AC02C52.jpeg 6A86F581-399A-41D6-B423-0874D0AD00CC.jpeg 8E59A1C6-48FA-458A-BFFA-FBA4A7D943D1.jpeg A24A621D-B41A-4E94-8BD9-76A20AF2DB92.jpeg 5932C115-BBED-404E-990E-BE3FDCD31302.jpeg 82BEC7C8-89B8-4D09-9601-E31B963E4FF1.jpeg
  19. Beanscoot
    Beanscoot
    Nice! Especially the edge on view.
    Wardog likes this.
  20. Aaron D.
    Aaron D.
    Great attention to detail! Looks fantastic.
    Wardog likes this.
  21. Wardog
    Wardog
    As I was leaving the shed tonight I took this photo as I turned off the last of the lights.
  22. Wardog
    Wardog
    I got the engine and trans back together and in the frame on Sunday. I’ve been getting it back together so far this week.
    A849757B-BA46-4DD9-94E9-D0CF435ACC17.jpeg A7FA98E6-CC28-41E8-811D-9A24E8F09E0F.jpeg 553BCD86-B3B3-4E90-B91F-56037C7CB70C.jpeg B4964680-ADCA-491E-98BE-C957ED7FCD48.jpeg
  23. Wardog
    Wardog
    Not a lot of progress lately. I’ve been sealing up shock absorbers this week. Last weekend at the “ Boogaloo Campout “ I got my steering wheel back. I’m very happy with the result.
    53F71735-6359-418D-93E4-29E8177079FE.jpeg 05475B09-46C8-4BDD-BEB4-0F13274CB151.jpeg
  24. Stogy
    Stogy
    Go Wardog Go!!...;)
    I am all for homebuilt but get a decent painting mask...I want to be watching you build Vintage Hotrods for a very long time...
    Not *****en just a concern and keep the little ones especially away from that stuff...some of this old car stuff is nasty dangerous such as NOS brake shoes for instance...since our hobby revolves around old we have to be vigilant...that epoxy paint, it ain't old but it's nasty stuff...
    Just Gary and chryslerfan55 like this.
  25. Wardog
    Wardog
    @Stogy thanks for the encouragement and you are right I need a decent mask.
    Fairlane500, chryslerfan55 and Stogy like this.
  26. Wardog
    Wardog
    77BDDBDD-C6F3-4383-B77A-763EC3E3C073.jpeg 0A25A311-3CDD-487C-A7CA-C942EBC8D9B6.jpeg 5CC6F673-5303-42C2-8DBD-7CC73BCDDB62.jpeg 2C0644F6-4861-4A0E-9098-06E39091DCE5.jpeg 11E5EAE5-9F85-4C4A-A1CA-D5712B41B7BC.jpeg
    I got a bunch of stuff ***embled this weekend. I reinforced my master cylinder mount, installed the new M/C and finished it all off. I flushed the lines with brake cleaner, all the connections and clamps are now tight.
  27. Wardog
    Wardog
    My King Bee’s turned up today. So naturally I quickly mocked them up for a look. CE1E767C-4223-4032-ABDB-460BF873D68F.jpeg 955A1127-B967-4A90-9AAC-7034AB932B30.jpeg 9BC636C5-FF01-406F-A0F1-E698A640BCA1.jpeg 03838FF9-E355-4AE0-9D2E-9D9B8C4D10BD.jpeg ACFB47C7-CCBD-4F4E-A6CF-DB788334A2BB.jpeg
    1947knuck, brEad, Fairlane500 and 4 others like this.
  28. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I like where your going with headlights.
  29. Wardog
    Wardog
    @krylon32 thank you. The headlight stands that came with them seem to be just right.
    1947knuck and chryslerfan55 like this.
  30. Nick Agius
    Nick Agius
