Projects What axle is this?
Discussion in 'Traditional Hot Rods' started by Fyresq, Nov 4, 2019.
  1. Fyresq
    Fyresq
    from Minden, NV
    I got this axle as part of a vehicle purchase but can’t figure out what it is and buddy’s have no idea either. Approx 58” WMS to WMS”, 5 on 4.5 bolt pattern with a removable 3rd.
  2. el Scotto
    el Scotto
    from Tracy, CA
    Are you sure you measured the bolt pattern correctly? It looks like an Oldsmobile rearend.
  3. Boneyard51
    Boneyard51
    Turn it over and let us see the other side. Might be out of a 55 or so Ford? With the 4.5 bolt pattern, leans toward Ford or MoPar. The u joint doesn’t really look like Ford, but it’s hard to see.
    Bones
  4. squirrel
    my guess would be 49-56 Ford car, but more pics would help.
    here's the one I'm thinking of...at least, the center section
    Hnstray likes this.
  5. el Scotto
    el Scotto
    from Tracy, CA
    The Mopar 8 3/4 doesn’t have a kick out for the ring gear, but I did forget about the 49-56 Ford rearend...
  6. Fyresq
    Fyresq
    from Minden, NV
  7. Boneyard51
    Boneyard51
    I’m gettin Hamb error, no pics.
    Bones
    Speed Gems likes this.
  8. dsiddons
    dsiddons
    from Indiana
    That’s a rear axle
    Texas Webb and Speed Gems like this.
  9. squirrel
    pics didn't work, try again?
  10. Chappy444
    Chappy444
    This is what my 51 ford rear looks like
    It dosent look the OP rear has as big a kick out for the ring gear... and it looks like there isnt a fill plug in the same place.
    I dont think it's a 49-55 ford
  11. squirrel
    Ford used two different rear end designs during those years. The Spicer rear is what you have, it was used in trucks, wagons, and Tbirds, from what I've seen. The other one with the removable center was used in normal passenger cars.
  12. Boden
    Boden
    That’s a 52-55 ford rear. Same exact rear in my 53. I can tell by the pinion yoke and the leaf pads. And the drums. Looks exactly like mine
  13. Boden
    Boden
    The rear in 49-51 fords are different as 52-55 fords
  14. Boden
    Boden
    52-55 49-51 is different
    squirrel likes this.
  15. Fyresq
    Fyresq
    from Minden, NV
  16. Fyresq
    Fyresq
    from Minden, NV
    Finally was able to get more pics on after 3rd different try and see they still ended up in a weird spot. Posting from an IPhone gets tricky on this forum it seems. Thanks for the replies, sounding like 52-55 Ford
  17. squirrel
    Huh...that's not what the Ford parts book says. But I'm not an expert.
    Hnstray likes this.
  18. seb fontana
    seb fontana
    from ct
    Just a note..The companion flange in the pic is called a "mechanics" flange, not very strong, tend to tear apart at the base of the "ears"..The "other" flange is a little better, uses typical u bolts, some what smaller than a 1310..
  19. dwollam
    dwollam
    Years ago I put a '54 center section (pumpkin) and axles in my '51 Ford Coupe rear end. Bolt in swap. the '54 has finer spline axles so ya have to do both but it is a bolt in deal.
    Dave
  20. 1946caddy
    1946caddy
    from washington
  21. squirrel
