Projects Finally I get my Flathead powered T Roadster
Discussion in 'Traditional Hot Rods' started by mctim64, Dec 4, 2014.
  1. Thank you! Love to see different angles on the car. :)
  2. LBCD
    LBCD
    Yes Sir! Not only does it look great it sounded great too and pretty quick too boot!
    mctim64 and loudbang like this.
  3. Frames
    Frames
    My chassis are prettier than your chassis and someone told me the cars aren't too bad looking either. Both 27's have 201 QC's, tube frames, and bod GOODSGUYS   PACKARD 018.JPG GOODGUYS----10--25--14-- 007.jpg ies pulled out 2" at the firewall bottom for foot room.
  4.
    flatheadpete, Jet96, Stogy and 5 others like this.
  5. I'm sticking with Tim's T and overall racing 'Crew'! LOL
    Stogy, Blue One, loudbang and 2 others like this.
  6. Awesome photos. The cars are nice too.[emoji6]
  7. Thanks Dale. :D
    Stogy, Blue One and loudbang like this.
  8. loudbang
    Congratulations on the good coverage. Well deserved.
    Stogy, mctim64 and Blue One like this.
  9. Here's a few shots from RPM Nationals this year. First two are of me and/or Mike Moore, the man who built my QC rear end.
    DSC_2288.JPG DSC_2397.JPG 75513454_10220937104124361_3102366040244355072_o.jpg DSC_2359.JPG DSC_2395.JPG
    Vic Walter, Jet96, Stogy and 10 others like this.
  10. So now the T has become a test bed. I'm building a Flathead for Ken of the Rolling Bones 575 coupe and to break it in I wanted to get an actual feel for how it runs. So..... I just installed it in my T. Get to drive it too. I will pull it on Tuesday, crate it and deliver to Ken at Bonneville. See you all at Speed Week. ;)
    JOYFLEA, TERPU, El Hueso and 9 others like this.
  11. Wish I was out there to help.
  12. Jet96
    Jet96
    from WY
    Dang, that soundtrack like Dave "Baby" Cortez...
  13. So, needed a little something better to beat Rich Roberts at RPM this year so I began work on a new 296ci Flatty for the 27 Roadster. I started with a rusty old 59 A-B block that was given to me by @Royalshifter last year after he couldn't sell it at the RPM swap meet last year. (you guys that passed on it, just wait till you see what you missed out on. lol!) Bored to 3 3/8" and stroked a stock Merc crank to 4 1/8".***** H-beam rods and Egge 3-ring cast pistons installed.
    117444910_10224128495947162_9096689390106554242_o.jpg 118019157_10224197486871892_8410711875272245867_o.jpg 118033090_10224197487951919_3105442189013241720_o.jpg 118015679_10224197486631886_1437350191549611506_o.jpg 117832489_10224197487471907_1638858171337215032_o.jpg
    Wife is calling me out to walk the dogs. I'll add more later. ;)
  14. Since the seats and ports were all rusty it was just natural to grind them out a little bigger and install larger 1.6" stainless valves. I installed a special "secret" reground camshaft and used stock hollow light weight lifters grinding the valve stems to get the correct lash.
    119061511_10224362739723110_4737147874513796156_o.jpg 119059887_10224362746563281_3716313040361839606_o.jpg 119217382_10224362747203297_2807673728739425472_n.jpg
    Vic Walter, Stogy, El Hueso and 8 others like this.
  15. Just 'cause I want to use as much off the shelf stuff that I have I cut down a stock flywheel from 34 lbs to 22 lbs. Should spin up pretty well.
    117973198_10224197425550359_8682774635580105481_o.jpg 117932190_10224197859601210_3847737219783766324_o.jpg
    Top it off with four new 81s on a Tony Baron intake and a set of polished Offy heads and we'll see just how she runs. ;)
    118472263_1779159938.jpg 118855683_1305693559.jpg 118959542_3155303297.jpg 119003775_10224349308307333_2487881854220085169_o.jpg
    Old motor in the foreground, still a good runner and will find a new home in my pending 31 coupe project. :)
  16. Aaron D.
    Aaron D.
    Should be faster now!!!
    biggeorge and loudbang like this.
  17. Mart
    Mart
    Nice lookin flatty there, Tim. may I ask, is the lightened flywheel drilled for a 9" clutch or a 10"?
  18. 10"
  19. Jethro
    Jethro
    That's 12 lbs of vintage metal chips.....gotta be able to use them for something
    you could almost make another flywheel!
  20. v8flat44
    v8flat44
    A young gun hear is building a glass 389 powered T roadster that i think is cool.
    BUT....it ain't near as cool as yours.......just awesome !!!!!!
    Stogy, loudbang and mctim64 like this.
  21. brEad
    brEad
    That is just bad a$$ right there! Well done!
    Stogy, mctim64 and loudbang like this.
  22. 97
    97
  23. Aaron D.
    Aaron D.
    Plenty of power there!!!! Awesome
  24. Mart
    Mart
    It's got good pick-up!
  25. loudbang
    Runs dam good for an obsolete engine :)
    Stogy, 97 and mctim64 like this.
