Technical 32 Tudor Firewall Body Connection
Discussion in 'Traditional Hot Rods' started by 32 Dave, Nov 2, 2019.
  1. 32 Dave
    32 Dave
    I’m getting ready to dis***emble my 32 Ford Tudor so it can be painted and I have a question about the firewall.
    I haven’t taken anything apart yet but looking at the firewall I don’t see anything that looks like a connection between the firewall and the body. I think the firewall is a Brookville, it’s a repop for sure. Does the body just sit on the firewall with a rubber seal/gasket with the frame bolts holding the body down. I know there are two curved struts under the dash connecting it to the firewall but I don’t see anything holding the body and firewall together.
    Thought I’d check with you’all before I dig in.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The center bolt of cowl to frame is what pulls body down onto gasket you describe above. So yes, no other fasteners.
    lurker mick likes this.
  3. 32 Dave
    32 Dave
    Great, thanks
  4. sloppy jalopies
    sloppy jalopies
    not a '32 guy but doesn't the rear hood hinge retainer bolt through the cowl and into the firewall ?
  5. 32 Dave
    32 Dave
    Just the firewall
  6. krylon32
    krylon32
    from Nebraska
    Besides the body pull down brackets at the bottom of the cowl the rear hood hinge bracket has 4 bolts, 2 front bolts that bolt to the firewall and the 2 rear bolts go thru the firewall lip on the body and thru the firewall.
    Johnny Gee and Fordors like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Listen to the man that has built plenty of Deuces. HRP
  8. Fordors
    Fordors
    @krylon32 is correct, the rear bolts are 1/4-20’s and I’m pretty sure the fronts are 12-24 thread.
  9. Photos to illustrate above comments. First the hood bracket from the top and then then from the bottom.
    Charlie Stephens
  10. 32 Dave
    32 Dave
    As usual you guys are spot on, 100% correct. Thanks for the input
