Technical Little help with SBC blower
Discussion in 'The Hokey Ass Message Board' started by Barn Hunter, Nov 4, 2019.
  1. Barn Hunter
    Barn Hunter
    I just got a car delivered today with a SBC (pictured). I've never owned a blower motor before and if you can tell me what I've got, I'd appreciate it. It was supposedly raced in the mid 70's...not with the big boys, but for fun. Been sitting for many years. Thanks! 20191104_172038 (2).jpg 20191104_172048 (2).jpg 20191104_172113 (2).jpg
  2. Hombre
    Hombre
    Well it looks like a old 371 GMC blower with the long drive. Interesting and still out there if you are inclined to look.
  3. mgtstumpy
    mgtstumpy
    Wow, you don't see many of those mini blowers compared to the more common 4-71. Double Cragar V-drive and drive snout on an original SBC [Cragar] blower intake. Rare to me! What's the list on the Holley 4b? Does it run?
  4. Fordors
    Fordors
    From the looks of the choke plate that is a three barrel. Holley made them in 950 and 1050 flow ratings.
    Deuces, Barn Hunter and Hombre like this.
  5. chevy57dude
    chevy57dude
    Cragar blower drives are as traditional as it can get! Choke tower milled off the DP?
  6. DDDenny
    What they said.
  7. 26Troadster
    26Troadster
    single vac sec carb on a blower, that is a first for me as well as the blower. i love the hamb, you never know what you'll see.
  8. squirrel
    wow, that's an oldie! And even has a generator, still.
    What are your plans for the car, or the engine? without knowing more about the car it's hard to make any suggestions, but hopefully it'll get out in the public so folks can see it....
  9. Just Gary
    Just Gary
    Also, those are backward slash M\T valve covers, not M/T. o_O
  10. Barn Hunter
    Barn Hunter
    It does not run. It has been sitting for probably 30 if not more years. Here's a pic of the Holley. 20191105_100729 (2).jpg 20191105_101351 (2).jpg
    Deuces, kidcampbell71 and loudbang like this.
  11. Barn Hunter
    Barn Hunter
    Sorry...this is new to me. What's the DP?
    chevy57dude likes this.
  12. Barn Hunter
    Barn Hunter
    Hi Jim.
    It will definitely get out into the public. I've got to keep it under wraps for now....working on final paperwork. The block is a V0703JTB. Heads are 340292. I can see valve guides but just got it yesterday and haven't gotten into it.
  13. Barn Hunter
    Barn Hunter
    Well that's cool. Didn't notice that before. Does that date them to a period?
    chevy57dude, Just Gary and loudbang like this.
  14. 1ton
    1ton
    throttle linkage does not seem to have a lot of movement and whats with that little cable on the top of the carb
    loudbang, Barn Hunter and squirrel like this.
  15. squirrel
    DP=double pumper. The three barrel Holley is a neat carb, don't see them much these days. Notice the vacuum secondary vacuum ***embly is larger than on "normal" vacuum secondary Holleys.
  16. Barn Hunter
    Barn Hunter
    Top. Sorry these pics aren't clear, it's in the back of the garage for now. 20191105_101148 (2).jpg
  17. saltflats
    saltflats
    from Missouri
    That is a 1050 Holley 3 barrel.
  18. Barn Hunter
    Barn Hunter
    Thanks!
    Deuces and loudbang like this.
  19. 1ton
    1ton
    Old school cool
  20. Fordors
    Fordors
    The small cable is the link between the choke plate and the mechanical choke linkage seen on the side of the carb.
    And as @saltflats said it’s a 1050, the secondary down tubes with no venturi boosters give the extra 100 CFM .
    Deuces and Barn Hunter like this.
  21. alchemy
    alchemy
    Is that engine in an early Vette?
  22. squirrel
    the JTB suffix sounds kind of weird....I'd sure like to see the stamping on the block, and maybe know what the block casting number is.
    Deuces, loudbang and Barn Hunter like this.
  23. Barn Hunter
    Barn Hunter
    Sorry, that's TJB...I believe a 73 truck block
  24. Barn Hunter
    Barn Hunter
    Hmmm.... might be.
  25. squirrel
    I suspected it might have the letters transposed.
    Barn Hunter likes this.
  26. Jim
    I have never played with a vac secondary carb on a blower seems like you would have to have one helluva spring in the vac pod or it would be all in whenever the blower was ****ing. I guess on a race motor that would not be a bad idea.
    Barn Hunter and loudbang like this.
  27. squirrel
    Air is air....I doubt it would ever open the secondary all the way, judging from the size of the blower.
    But I could be wrong.
    ottoman and Barn Hunter like this.
  28. el Scotto
    el Scotto
    from Tracy, CA
    That is wickedly cool looking!!!
  29. I would not try to start it until you fixed and replaced a few things.
    The power valves, secondary diaphragm, you have a fuel leak at the carb line fitting. Make sure the distributor advance is freed up. Lots of rare pieces.
    Deuces, Barn Hunter and loudbang like this.
  30. DDDenny
    Never had a three barrel but I'd sure be nervous about that little crimp end on that choke cable coming loose and going through the blower.
