Technical Front axle width
Discussion in 'Traditional Hot Rods' started by Tractors & T's, Nov 4, 2019.
  1. Tractors & T's
    Tractors & T's
    from Baxter MN
    From Model A's through the 40's was there a lot of difference in the width of the front axle? My drop axles are about 46" center to center on the king pins. My stock Model A's are about 50". I don't have anything newer than Model A that is stock to compare to.
  2. lake_harley
    lake_harley
    kadillackid and irishsteve like this.
  3. 1946caddy
    1946caddy
    from washington
  4. Tractors & T's
    Tractors & T's
    from Baxter MN
    That's what I was wondering. Thanks
  5. bltbalsam
    bltbalsam
    Ron Pope in Kodak, Tn. will make you a tube axle any width you want. He also makes all sorts of suspension parts as well. He is the MAN ! 865-932-7541
  6. krylon32
    krylon32
    from Nebraska
    I've had several deuce heavy axles dropped by Anson Axles and what he calls a 4.5 inch total drop reduces the kingpin width from 50.5 down to 48.
