Carb tuning question simple....my plugs are a little white
Discussion in 'The Hokey Ass Message Board' started by caffeine, Jun 24, 2006.
  1. caffeine
    caffeine
    from Central NJ
    plugs are a little white and its running a little hot...just want it perfect before i deliver it to its new owner. (and it happens to be a 475 mile trip) haha
    its a stock single barrel carb on a 170 inline ford 6.......the adjustment screw is about two turns out from all the way in.
    the only problem ive ever had with it was it backfiring a little bit say going up a hill at high speeds on the way back from York PA..and my manifold was glowing hot.........i just wanna make sure its perfect before handing it over.
    silly that its only 1 screw....but well..im an idiot.
    -Rob:D
  2. Flatman
    Flatman
    Sounds like your timing might be a bit too advanced...
    Flatman
  3. caffeine
    caffeine
    from Central NJ
    na, timing is fine, i figured it out, just a little turn and everythign looks good. ill let ya know tonight, have to drive it a good 475 miles to its new HAMB owner.
    -Rob
  4. caffeine
    caffeine
    from Central NJ
    also they were pretty new platinum plugs so the white look was a little decieving.
  5. CptKaos
    CptKaos
    the idle mixture screw isnt gonna help alot unless you intend to idle it 475 miles
    Larry
  6. LOL yeah
    Man richen the mix a bit before that feller has some holes in the pistons of his new ride.
    At the very least choke it up a bit to make it more rich.
  7. ray
    ray
    from colorado
    yup, just cause there's only one adjustment screw doesn't mean that's the only adjustment you can make! is it a holley 1bbl? if so pull the float bowl and rejet it, it takes standard holley jets found at any decent parts store. i'd make sure everything else is right too, timing etc, i'm running an inline ford 6, and have a wideband o2 sensor, i've run it real lean, and it will fall on it's face before it makes the manifold hot enough to glow.
  8. scottybaccus
    scottybaccus
    Remember to get plug readings at cruise rpm and wide open throttle, too. Jetting is a package deal. Just because you get it right at cruise doesn't mean it is safe at WOT.
    Start ith the top end by running it flat out on an open road for about 15 to 30 seconds. (yes that's a long time at that speed. BE CAREFUL!) Cut the engine off and put it in neutral simultaneously without dropping the rpm, coast to the side and pull a plug. Then you'll see what's really happening. Once that is dialed in, repeat the process at cruise rpm. I bet you are very close. Then set the idle mixture.
