Projects 1946 Ford 1/2 Ton... Attempt
Discussion in 'Traditional Hot Rods' started by greaseSlinger57, Oct 4, 2019.
  1. greaseSlinger57
    greaseSlinger57
    Okay... I’m bad with technology. More or less impatient with it. I have patience for a photo or two sometimes more so to get the full update might take some time. Anyhow, here is an attempt at building a 1946 1/2 ton Ford with a ‘72 8.2 500 Cadillac and TH400 Trans. Here she goes.
  2. greaseSlinger57
    greaseSlinger57
    [​IMG][​IMG][​IMG]
    UNSHINED 2, j-jock, Tim and 1 other person like this.
  3. Budget36
    Budget36
    You Go, had a '42...still have a soft spot for them;)
    greaseSlinger57 likes this.
  4. F-ONE
    F-ONE
    from Alabama
    I love those Jailbars.
  5. greaseSlinger57
    greaseSlinger57
    [​IMG][​IMG][​IMG]
    Tim likes this.
  6. greaseSlinger57
    greaseSlinger57
    Empty cabs also serve as storage for baby blankets and things that I’m too lazy to bring in the house.
    alanp561 likes this.
  7. greaseSlinger57
    greaseSlinger57
    [​IMG] [​IMG][​IMG][​IMG][​IMG][​IMG]
    Not the best. not the worst.
    alanp561, swade41 and j-jock like this.
  8. Budget36
    Budget36
  9. Budget36
    Budget36
    /Shoot, was trying to edit out your pics and just quiote your text...Hey, if you're happy with it, do it...best of luck!
  10. greaseSlinger57
    greaseSlinger57
    Cut and welded on thick sheet metal to make new running boards. Fibergl*** on the edges. Seam seal bottom. Primer and ch***is black under sides of all panels. Hopefully she’ll look okay when it’s all said and done. This my wife and mine first complete rebuild. [emoji51]
    Budget36, hfh, Tim and 1 other person like this.
  11. greaseSlinger57
    greaseSlinger57
    [​IMG][​IMG]
  12. greaseSlinger57
    greaseSlinger57
    Both lower front cab corners completely separated and all the way across the floor as well. As a result is a beautiful door gap that sags on both sides! Cut the floor out and port-o-power the cab together so the doors can actually open and close!
  13. greaseSlinger57
    greaseSlinger57
  14. greaseSlinger57
    greaseSlinger57
    [​IMG][​IMG][​IMG]
    Step 38 of 5,389....
    Remove 2” thick body filler from both cab corners and both doors. Cut out Swiss cheese and weld em up. Just touching the tip of the iceberg here so it’ll take me some time to get us caught up to current date [emoji1305]
    Surfcityrocker and s55mercury66 like this.
  15. greaseSlinger57
    greaseSlinger57
    Here’s a few more pics of the tear down and metal work beginning steps. I’m too impatient to load anymore today [emoji38] maybe in a little while
    j-jock likes this.
  16. 41rodderz
    41rodderz
    from Oregon
    Props for getting an oldie back on the road. Wow , you apparently have great taste in picking a wife. Pretty special to have a partner that gets involved with you.:cool:
  17. greaseSlinger57
    greaseSlinger57
    [​IMG][​IMG]
    I’m kind of jumping all over the place here as I find pictures. Wire wheel and ch***is black the frame and set in motor and ******! And don’t worry I have since flipped the axle around so it will steer correctly! Good times [emoji1360]
  18. greaseSlinger57
    greaseSlinger57
    I have found It’s a lot more work than it might appear to be haha and She’s pretty awesome in wanting to help at all! she’s more motivated than I am to do it most times haha
    Frankie47 likes this.
  19. greaseSlinger57
    greaseSlinger57
    My wife’s fender on the right mine on the left. Hers is better [emoji51]
  20. greaseSlinger57
    greaseSlinger57
    [​IMG][​IMG]
    High build primer round 1!
  21. greaseSlinger57
    greaseSlinger57
    Whole truck was sandblasted and epoxied before I bought it so tear down and body work was that much easier. Body work on cab front fenders. Primer and paint! WOO! White is cheap so I went with that [emoji51]
  22. greaseSlinger57
    greaseSlinger57
    Clear coated the wood cab mounts before mounting! It’s beginning to resemble a vehicle of some-kind! YAY
  23. Bandit Billy
    Bandit Billy
    ^^^^^Great picture for the family album.
  24. greaseSlinger57
    greaseSlinger57
  25. greaseSlinger57
    greaseSlinger57
  26. Beautiful work. I can't wait to see more of the progress.
    Bob
    loudbang and greaseSlinger57 like this.
  27. swade41
    swade41
    from Buffalo,NY
    Looks good, I like that torque monster up front.
    greaseSlinger57 and loudbang like this.
  28. greaseSlinger57
    greaseSlinger57
    My wife did all soundproofing she is the coolest!
    I'm trying to find more build pictures between different phones and computers so we'll see what I come up with haha
  29. greaseSlinger57
    greaseSlinger57
    Okay again jumping around here on the build
    Kind of weird that the 70 year old door pins wouldn’t just slide out with the tap of a hammer but.... sliced out above and below the cab hinge to remove pin. Drill through door hinge and cab hinge so I could have a door that opens and closes! Good times that was
    [​IMG][​IMG][​IMG]
    And the 70 year old Phillips head bolt wouldn’t come out either. so weird....[emoji1]
    Drilled out and made new backing plates and slotted the cab holes slightly so there is door gap adjustment! All the little silly things.
    Frankie47 and loudbang like this.
  30. greaseSlinger57
    greaseSlinger57
    Here’s a couple more pics. Rim and tire combo and the only pick find of the floor and old seats right now! I’m sure I’ll come across a better one.
    [​IMG][​IMG]
