Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. WB69
    WB69
    from Kansas
    Went deer hunting.....
    Truckdoctor Andy likes this.
  2. Stephen Barrett
    Stephen Barrett
    That car is bad ***.
  3. e1956v
    e1956v
    Alliance Vendor
    Not to the exact day, it was the 11th of Sept so a couple of months off. It's interesting that where you live it reads November 9th cause that's my birthday.
    Hopefully my dad is looking down and saying
    " well at least he didn't run the business in to the damn ground" That would be his backwards way of telling me "Good job son".
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
  4. LOU WELLS
    LOU WELLS
    from IDAHO
    I Cut A 1940/41 Ford Sedan Delivery Rear LH Tail Light Bracket And Flipped It To Make A Rare RH Bracket... 73103120_2748940998459847_3553602386763186176_n.jpg
    chriseakin, Lil32, swade41 and 2 others like this.
  5. lothiandon1940
    lothiandon1940
    .....Remarkable story about the speedometer and your Dad. Love it.
    LAROKE, e1956v and Hamtown Al like this.
  6. The37Kid
    The37Kid
    Back from the local Sunday flea market, got some things to photograph and flip. Next is some garage cleanup time, feed the wood stove, maybe some '22 Bob Tail time later on. Bob
  7. T. Turtle
    T. Turtle
    Used the good weather we had here in Lower Austria to test the changes made to the front suspension (Shelby drop, Opentracker camber kit, shortened coils and black Bilsteins from Mike Maier) - after having done the alignment using basic tools and lots of f&%$ing about with the adjustment shims:mad:
    All in all the car now turns into corners a LOT better and stays planted without any body roll. Need to improve straight line slack but I think I know what the issue is.
    In between I had some proper Austrian food:)
    20190727_161159.jpg 20191110_113238.jpg 20191110_150805.jpg 20191110_150731.jpg 20191110_162542.jpg 20191109_180153.jpg
  8. 62rebel
    62rebel
    Spent the afternoon getting the bumper off the left front tire. Yeah I am sore as hell but just sitting feels just as bad as doing something. Would rather have spent the time working on the parts I bought for the Galaxie.
  9. Pretty day today 65 degrees.Went to Williford Ar and loaded up a outdoor wood furnace on my 20 ft tilt top Trailer. I bought the stove at a Auction a couple of weeks ago for $25. Also unloaded the load of firewood from my 66 GMC that I went and got yesterday. wood stove 001.JPG wood stove 002.JPG wood stove 004.JPG
  10. Black_Sheep
    Black_Sheep
    I took what will most likely be the final cruise of the season. The roads are dry but there appeared to be a lot of salt residue at intersections.
  11. Took a week,
    Got the poop pipe and water line into my new shop.
    trollst, lumpy 63 and das858 like this.
  12. clem
    clem
    I was also intrigued to see that it needed repairs 6 years after Dodge produced it, yet presumably went 65 years after your father repaired it........
    e1956v likes this.
  13. Hank37
    Hank37
    Went to a reunion of old friends who hung around Miller's Mobil gas station when we were in our teens. That's me with hand on table . 75594494_742855586233048_3416752698509230080_n.jpg
    chubbie, 40two, chriseakin and 9 others like this.
  14. Fitnessguy
    Fitnessguy
    Never take the time to print any pics of the cars I’ve taken so decided to go big! 24x30 print and then I made the frame. Used the original nails from the old wood off the coupe to nail the metal corner pieces. Think she looks good even if I do say so myself!
    [​IMG][​IMG]
    das858, 500caddy, chriseakin and 13 others like this.
  15. swade41
    swade41
    from Buffalo,NY
    Yesterday I went to Jan-Cen's open house, local long time engine builders and drag racers, Mike was 2018 Pro Mod champs and came in 3rd this year with the new car. They specialize in building their own design CNC blowers used in all kinds of motorsports from boats to tractor pulling to drag cars, great time catching up with everyone there.
    Then I came home and started moving drywall, wood and general **** to try and get the Henry J in the enclosed section of the garage. I ran out of steam and got pretty tired, this disease kicks my *** physically, so today I continued that task, still not finished but I did make a good dent in it and burned a lot of wood from the old walls and such.
    Here's my buddy Tom (fuel altered owner/driver) goofing around posing with some of the blowers at the open house and an inside look of one of their injector hats. 20191109_134112.jpg 20191109_134123.jpg
  16. indianbullet
    indianbullet
    from Ca
    Spent the last few days trying to teach myself how to Tig weld..
  17. I tried to take advantage of what may be the last nice day this year to rake some leaves and get some work done on an OT project car. The sooner it gets done, the sooner I can put a Model T in its place!
  18. LAROKE
    LAROKE
    Worked on my '37 rebuild. Put the dissembled tie rod end back together on the steering arm then cleaned, masked and painted it, along with the steering arm and brake bracket. Sunday, when the paint was dry, I put the new shock absorber on. This five minute job turned into a two-Budweiser degree of difficulty task. The shock bushings were tight on the pivots and wouldn't go any farther than three-quarters of the way on. I rethought things when I hit my thumb with a twelve pound sledge. The great mechanic in the sky gave me a mulligan and it was a glancing blow that barely broke the skin. I tried several things that didn't work, that I'd rather not discuss, when I found a socket that fit over the protruding portion of the bushing and seated against the metal portion of the shock eye. That did the trick. I was able to pound on the socket and seat both ends of the shock. Some fiddling with the new stainless steel washers and hex nuts and I was done.
  19. lothiandon1940
    lothiandon1940
    ....................Always seems to work that way for me as well.:(
    LAROKE likes this.
  20. HarryT
    HarryT
    Changed oil and filter in the Avatar yesterday. Will take it for the final ride of the season today.
    Jim
  21. HotRod33
    HotRod33
    IMG_20191110_143055.jpg IMG_20191110_143045.jpg . Stated a body cart... Still have a little work to do. Had an old rack that I cut down and modifying
    chriseakin and osage orange like this.
  22. saltflats
    saltflats
    from Missouri
    I call snow day today so Thought I should make some progress on this project. :)
    Now that that I have the front spring back in I can remove the poor old 6 and make room for something more exciting. :)
  23. charleyw
    charleyw
  24. swade41
    swade41
    from Buffalo,NY
  25. saltflats
    saltflats
    from Missouri
    2 four 409 4 speed. :)
  26. chriseakin
    chriseakin
    Nov. 11 is Remembrance Day here. Up at 6:30 to do physio exercises. Wife got up at 7:30 and made us fried eggs and toast for breakfast, then she drove me downtown so I could take photos of the parade and both of us went to the Remembrance Day service at the Legion after. We had one veteran of WWII at the service - recently turned 100, but still gets around, though in a wheel chair most of the time. We got 8 about inches of snow this past week, but the town managed to get the roads mostly plowed for the parade. Remembrance Day Parade 8.JPG
  27. 500caddy
    500caddy
    Spent last week at Sema 2 days drive to and 2 days home resting today
  28. harley jim
    harley jim
    I love me some 2 four 409
    Had one in a 31 chevy coupe w/ muncie 4 speed. What a sound
    Sent from my LG-LS777 using Tapatalk
  29. Lil'Alb
    Lil'Alb
    from brier, wa
    Painted the 59ab ford green for my 34 pickup.
  30. Turnipseed
    Turnipseed
    Drove the T-Bucket in our county's Veteran's Day Parade. Lots of school kids lined the route. They laughed and giggled when I blew the Aoogah horn. A great day to honor our veterans. parade pic.jpg
