Features Model A roadster highboys on Model A frames
Discussion in 'Traditional Hot Rods' started by Chris, Jan 3, 2009.
  1. brEad
    brEad
    I find myself liking them more and more.
    48fordnut likes this.
  2. madfish
    madfish
    Whose car is this and what's the story with the windshield cover? That looks cool. Never seen that done before.
    Dannerr likes this.
  3. Speedy Canuck
    Speedy Canuck
    Trend?
    Might want to go look at some old hotrod magazines from the late 40s and 50s... :)
  4. ratamahata
    ratamahata
    from Argentina
  5. Deescott
    Deescott
  6. The aprons were left on because you have to lift the body to remove them, everything else unbolts.
    ratamahata likes this.
  7. POST PICTURES !!!! JW
    Dannerr likes this.
  8. Never2low
    Never2low
    Remember, alot of the prewar cars racing at the lakes, weren't trailer queens.
    They were driven on the street and subject to traffic/DOT laws.
    Removing the splash apron would mean the fenders couldn't easily be put back on.
    I recall Vic Edelbrock jr. talking about his dad driving up to the lake, after work on Fridays, unbolting the fenders, headlight bar and windshield, racing all weekend, then bolting everything back on and driving home.
    And before the peanut gallery chimes in, I know Vic Sr. had a Deuce, not an A, but the point remains.
    woodz, Kenny P, Jet96 and 1 other person like this.
  9. This has been done to Death now.........Back to posting Pictures. JW
    Jet96 and missysdad1 like this.
  10. Kenny P
    Kenny P
    Some more aprons for ya Deescott, :)
  11. Never2low
    Never2low
    ^^^^That is ****ing perfection, right there!^^^^
    Kenny P and 26 T Ford RPU like this.
  12. Lilred36
    Lilred36
    I'd like to know who owns this one as I'd like to talk to them about the side curtains.
    Sent from my XT1650 using The H.A.M.B. mobile app
  13. Try contacting Kris Elmer c/o Kindig It Designs, facbook him.JW
    Dannerr likes this.
  14. Lilred36
    Lilred36
    Thanks.
    26 T Ford RPU likes this.
  15. ratamahata
    ratamahata
    from Argentina
  16. flatout51
    flatout51
    Jet96, modelacrazy, Felix 40 and 8 others like this.
  17. 1928-1929 radiator cross-member mounts are about 1/4" higher than 1930-1931. So, early body/radiator on a later frame is easier than the other way around. A few shims will bring the early radiator up to later height.
    Maybe in this case, someone knew part of the story, and over-corrected, raising a radiator that didn't need it.
  18. Kenny P
    Kenny P
  19. wheeldog57
    wheeldog57
  20. A Boner
    A Boner
  21. blvdbill
    blvdbill
    Jet96, wheeldog57, woodz and 2 others like this.
  22. 351cmach
    351cmach
    from Ma
  23. v8flat44
    v8flat44
    31hotrodguy likes this.
  24. hotrodmano
    hotrodmano
    from Norway
    Just to keep this tread alive. heres acouple of more pics of mine...from inside. Boooring..I know :D
    75576584_920074781710043_4287093852147286016_n.jpg 71771170_1198451997009749_2150271468322160640_n.jpg
    modelacrazy, itsmee, Felix 40 and 9 others like this.
  25. 66Special
    66Special
  26. 62pan
    62pan
    66 special, Looks like your running a spring behind set up. Did you just lengthen the frame or is there a step also?
  27. 66Special
    66Special
    The frame has been lengthened and stepped. We cut the back off the original frame and then laid 3x2 tubing on top of the frame rails and ran it back so its only stepped the height of the frame rail.
  28. scoop
    scoop
    66 how far did you have to extend the frame to do the spring behind,and what spring did you use?
  29. mit311
    mit311
    16" Kelsey Hayes Rims
    Tires are bias ply firestones, 600-16 front 650-16 rear. I should have just gotten 4 600 or 4 650's so I could rotate them, but <shrug>
    351cmach likes this.
  30. bangerbob
    bangerbob
    19 inch Kelsey-hayes rear. 17 inch Kelsey-hayes for front. Put on in spring!! 20190901_131623.jpeg 20170118_073538.jpeg
    Sent from my SM-J337P using The H.A.M.B. mobile app
    brEad, Dannerr, 26 T Ford RPU and 2 others like this.
