Projects Southeast TN 51 shoebox build.
Discussion in 'Traditional Customs' started by Kage, Nov 6, 2018.
  1. Kage
    Kage
    from Delano, TN
    That’s a nice stand....normally I would have built my own stand. But with dealing with a house being built, my daily driver is in the shop, and my back up vehicle is now down for a complete brake overhaul....i haven’t had much free time.
  2. dan c
    dan c
    that oil pan looks like just the ticket!
    loudbang and Kage like this.
  3. Kage
    Kage
    from Delano, TN
    I’ve not had a chance to work on the 51 lately. But my good friend Dan Cain hooked me up with this set of valve cover adapters his dad (Ted Cain) made back in the day. They will allow me to mount Y-block Ford/Mercury valve covers to my SBF. Now I need to decide which set to run. I have the Ford stamped cover (pictured below), a set of the Mercury stamped cover, and a smooth set. I also have access to a thunderbird set. Im also considering an aftermarket set with slanted fins.....so many options.
    F6F4A14C-16A2-4219-9156-B4B02DE39FFE.jpeg C8324532-BB07-46AF-BBE9-AEB9FA646C9B.jpeg D4EF371B-7F97-4CE1-B7F3-AABB58B81736.jpeg EE9F3F82-8CE8-4A9E-BCA7-CA5153308519.jpeg
  4. ERguitar
    ERguitar
    That's slick.
  5. Finnrodder
    Finnrodder
    from Finland
    Cool adapters!
    Those will confuse the **** out of people
    Kage and loudbang like this.
  6. harley jim
    harley jim
    Just found this thread. Looks good. I love a good sheet metal repair thread.
    Sent from my smart*** phone when it wants toThe H.A.M.B. mobile app
  7. Kage
    Kage
    from Delano, TN
    I will check out your thread.
  8. Kage
    Kage
    from Delano, TN
    Finally moving to the new house...but my new shop has yet to be built. Currently trying to get everything moved out of my little prefab 12x24 building empty so I can get it moved to the new house.
  9. Kage
    Kage
    from Delano, TN
    No work progress on the 51...but I did get her moved to the new house...she is in here temporary home in the 2 car garage. Unfortunately the misses won’t let me work on the 51 in the new garage. Just more motivation to get my little shop building moved up here and to get started on building my new shop.
    I also have my dads roll cage in my garage. It is for his 1st gen. Bronco. I have to clean up his welds and make them look “Pretty” before the cage gets powder coated.
    27DBFA3C-9EAF-4D13-BD2C-C7D5A550D404.jpeg C0B04C49-BA4E-4AED-8D2A-95366D17200C.jpeg
    bobss396 and loudbang like this.
  10. harley jim
    harley jim
    Have you got someone to powder coat that cage.
  11. Kage
    Kage
    from Delano, TN
    Yes I do. I use Freddie Hafley at Souther Powder coating in Ocoee TN.
  12. harley jim
    harley jim
    Ok, I know Freddie, I was going to suggest my neighbor he dose a nice job
    I have some fender skirts and some other shoebox parts if you are looking for anything let me know I may have it.
  13. Kage
    Kage
    from Delano, TN
    Well....Since the 51 in the garage of the new house....and I have to walk by it every day...I can’t help but want to work on it. So I started laying out the new floor pan for the p***enger side.
    I got the basic pattern laid out. I’ll get it cut out later this week and start bead rolling it.
    The p***enger side quarter is pretty banged up but the metal is solid (except for the drilled holes). I think I’m going to cut out the panel and use the English wheel to smooth it out....worst case...if that doesn’t work I’ll buy a replacement panel from shoebox central. ....just in case I have to use a replacement panel....does anyone know how high above the wheel opening this panel goes.
  14. Finnrodder
    Finnrodder
    from Finland
    I have an extra EMS quarter patch panel, because the company where i bought it, sent a drivers side and i wanted the p***engers side. They sent the right one and let me keep the wrong one, because it would be too expensive to send it back to US. Thats great customer service, cant blame them.
    Anyway, its slightly over 4" with the lip for lapwelder guys.
    I cut off the lapwelding lip from the panel i used, i dont do lapwelding on spots like this. If you planish the lip straight before welding it, then there's an extra inch for the job.
  15. Kage
    Kage
    from Delano, TN
    Thanks for the information Finnrodder. That helps out a lot. I think I’m only going 2” above the wheel well so I should be good.
  16. dan c
    dan c
    somewhere, luke doolin is smiling!
  17. Kage
    Kage
    from Delano, TN
    I got the bead ran on the p***enger side floor pan. I still have to add a bend on the left side to connect to the trans tunnel.
    And I also still need to trim some of the old floor.
    Finnrodder likes this.
  18. Kage
    Kage
    from Delano, TN
    I finally got back to work on the 51. I removed the door, then welded in a support brace and started removing the rotted inner and outer rocker panel.
    80EDC47E-6C59-437A-81E0-9376F8BAC4E2.jpeg AC4A687D-8F5A-4B9C-AB6D-8280A3773EEE.jpeg
    Next will be to clean up the body mounts and start test fitting the new rocker panels
  19. Kage
    Kage
    from Delano, TN
    Started test fitting the rocker panel this morning. It’s fitting nicely. I have to get the inner rocker fitting correctly then I’ll get everything welded up. 5328D685-0B89-496C-9E15-F48C85ED7604.jpeg
    brEad, loudbang and harley jim like this.
  20. harley jim
    harley jim
    Looking good kage
    Sent from my LG-LS777 using Tapatalk
  21. Kage
    Kage
    from Delano, TN
    Finished test fitting the inner and outer rocker. Now it was time to prep the 2 to be welded together.
    1st I primed the inside of each panel after I had taped off the edges that would be welded together.
    8B871252-9186-40A9-9701-11C02C951358.jpeg 8D5293F9-1348-4433-BEEC-5A1C3823F4C4.jpeg
    next i sprayed a rubberized undercoating on the inside of each part
    0AE79614-6D20-4734-A931-0DB4DE643FB4.jpeg F13ED762-5293-44A3-B204-69E0762A0150.jpeg C23518C9-86FB-4CE0-9A1F-DF7F91F9FE0E.jpeg
    parts welded together
    B22A1000-338F-469A-AC41-A866F94CD705.jpeg 73719404-CADF-49DC-A7C4-AD73B878C383.jpeg
    and finally welded into its new home.
    brEad and loudbang like this.
  22. Finnrodder
    Finnrodder
    from Finland
    Nice progress!
    Just a suggestion, make a test fit how the door fits before you complete the welding
  23. harley jim
    harley jim
    Good progress on your floors.
    I dug out some of the parts and am making some progress. Found a new set of aluminum covers for those new rockers you just installed.
  24. road zombi
    road zombi
    good work Kage, it´s fine to see you´re projekt in progress
  25. Kage
    Kage
    from Delano, TN
    Was able to get a little work done on the floor pan this morning before work. Started off by locating the original body mount spacer on the new floor pan and welding it in place.
    Next was lining up the floor pan and tacking it in. It is looking pretty good...in my opinion...especially for a novice metal fabricator. Lol
    brEad, loudbang and Finnrodder like this.
  26. Kage
    Kage
    from Delano, TN
    Just Scored a set of 52-54 ford fender well lips to grapht on to my shoebox for $3.
    Someone had drug in an old 4dr to the local s**** yard. Unfortunately there wasn’t a lot left worth saving on it
    But these fender lips should look great graphed on to my 51
  27. Finnrodder
    Finnrodder
    from Finland
    Thats a cool score for 3 bucks!
    Never happens in here..
  28. Kage
    Kage
    from Delano, TN
    I made friends with the owner of the local s**** as soon as he took over the yard....it really pays to have friends in the right places lol. But the key is to make sure it’s not a one way friendship ship...if he ever calls or needs a haircut after hours or on a day I’m normally closed I make sure to come in.
  29. Kage
    Kage
    from Delano, TN
    Got some time in on the 51 today. Did a small patch on the end of the p***enger quarter panel.
    E0F204DB-3601-414B-8877-76B633B9847D.jpeg 7EFEA44E-3429-45D9-9F3F-89BC77F40AFF.jpeg DB5FB2D9-13FD-4441-96F6-D63603D46529.jpeg
    I also got some work done on the rear trunk pan. Ill get some pics up of the progress on it tomorrow.
    I’m also hitting up a local swap meet tomorrow...hopefully I’ll score some cool stuff.
    chryslerfan55 and Finnrodder like this.
  30. harley jim
    harley jim
    Where is the swap meet tomorrow
    Sent from my SM-A102U using Tapatalk
