Technical ***November 2019 Banger Thread. Really? Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 31, 2019.
  1. stillrunners
    stillrunners
    from dallas
    Hope all is well with youse guys !
    winduptoy likes this.
  2. Near 20 degrees Friday night. Shutting down in East Central BRRmont.
  3. David Mazza
    David Mazza
  4. Finally, she sees the light of day, runs like a bat out of hell. I still have quite a bit of work to do, but things are going well. THy%TsceQ4eOO8h+UAY44g.jpg
  5. railcarmover
    railcarmover
    Took a fastener cl*** when I worked for CAT,Going in I thought it would be a waste of time..it wasnt.Proper torque and fastener support is critical,quality hard washers are your friend.
    Dannerr, JT1930, Jet96 and 1 other person like this.
  6. railcarmover
    railcarmover
    It runs good due to balance,single stromberg flows 170 CFM,engine flows about 170 CFM..nice work
    Old Dawg likes this.
  7. burl
    burl
    from Minnesota
    Took the beater for a spin to the butcher shop yesterday.May be the last ride before it starts to snow here.Time to pull the banger for a rebuild. db.jpg
    TheBookman, Lil'Alb, draider and 14 others like this.
  8. V4F
    V4F
    from middle ca.
    what is the body ? …………. thanks
  9. burl
    burl
    from Minnesota
    1928 dodge brothers
    Boden likes this.
  10. Fabber McGee
    Fabber McGee
    Nothing in the world takes a beating like a Caterpillar bouncing around on a rock pile or frozen clods. I doubt anyone in the world knows more about fasteners and metallurgy. If you need good hardware spend your money at a Cat dealer.
    Cat mostly, or completely stopped using lock washers in favor of hard washers 30 years ago. Reason being, if a lock washer breaks it will soon fall out and leave you with a bolt that is immediately an 1/8 inch or more from being tight.
    Old Dawg and Jet96 like this.
  11. Russ B
    Russ B
    yes
  12. V4F
    V4F
    from middle ca.
    1928 dodge ……….. like the 3 window ……… thanks
  13. kweb1936
    kweb1936
    from salem il.
    Slowly working on mine [​IMG]
    barrnone50, Lil'Alb, Dannerr and 8 others like this.
  14. Dustyp489
    Dustyp489
    Nice coupe,
    kweb1936 likes this.
  15. railcarmover
    railcarmover
    Proper torque places the fastener in tension,negating the need for mechanical locking hardware.Hard washer insures a steady base for torquing the fastener..anerobic sealants (loc***e) is effective as well..between the coffee and donuts this is what I retained..
    Old Dawg and Fabber McGee like this.
  16. fur biscuit
    fur biscuit
    That is a ***y image!! The mood lighting is key for accentuating the curves!!
  17. fur biscuit
    fur biscuit
    Been slowly acquiring more bits, the gas tank arrived (finally), picked up a pile of model A brake arms and stuff for building remote linkages. Found a guy in Houston with a bunch of T stuff for sale, so scored a TT brake cross shaft. Weather has broken, so time to get into the garage and start cleaning...then, just maybe...I can procrastinate some more.
  18. Yup! The photo was taken in a warm Spring evening by a Vintage Auto Racing ***ociation (VARA) photog/member Brad Eells a couple of years ago at ****onwillow Raceway. The event was VARA's "British Extravaganza". VARA has each year been so gracious to give us a "PreWar"/Historic Group race. Despite a well laid out track and good compatible company, it's always difficult to get enough participants with truly vintage "PreWar" cars to attend. For decades the folks from NorCal, with the exception of the late Peter Giddings (and one other) have dained not to bless us with their presence.
    Stay dry Doug!
  19. V4F
    V4F
    from middle ca.
    how much out of top ? …………….. looks good
  20. klawockvet
    klawockvet
    Anybody out there want to go back to a stock height windshield in a 29-29 Roadster? I looking for a 2" or 2+ chop. I have a good stock frame, gl*** and stanchions.
  21. kweb1936
    kweb1936
    from salem il.
    4 inches
  22. V4F
    V4F
    from middle ca.
    *** wow , that's a bunch ………………...
  23. walls
    walls
    Is this a B timing cover?
    And can I use this with a B distributor to time the A engine? CF7EBC56-A89A-429B-937C-12A144EFBABF.jpeg
  24. walls
    walls
    Dannerr likes this.
  25. Colonial Coupe
    Colonial Coupe
    Set it to the trailing edge of the rotor blade
  26. ghalperin
    ghalperin
    Racks for the Banger.
    Colonial Coupe, MJW, Dannerr and 4 others like this.
  27. jim1932
    jim1932
    hoping to finally get all this junk in my car this winter. New motor supposed to be done this month.... {stuff is just mocked up on this one to work on linkage).
    BigO, Shutter Speed, JT1930 and 9 others like this.
  28. poshdbs
    poshdbs
    Whilst waiting for the B motor to come home I've been mocking this up for the top of it. If anyone has any pointers where to get a choke v-clamp (SR B) from that would help me loads. This has been a long long time in the making! 75412235_10218425347492198_1248107622087786496_n.jpg
    BigO, Dannerr, waxhead and 2 others like this.
  29. lake_harley
    lake_harley
    jim1932....That engine looks GREAT! I guess it's quite typical to do some contrasting color to make things "pop", but the silver paint on the block, pan, etc. with the aluminum and chrome/ceramic coated parts looks fantastic. It has a rich, sophisticated look to it. Thumbs up!
    Lynn
    barrnone50 and poshdbs like this.
