Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. Limey Kid
    Limey Kid
    Hood looks great. The finishing touch to the body.
    Cheers,
    Stewart.
  2. rusty rocket
    rusty rocket
    I bought a stainless steel radiator recovery tank the other day. It was way to blingy so I gave it a sand to make it a bit more industrial looking. The next problem was it was to big to fit on the track nose so I fabbed up a few brackets and mounted it on the motor. image.jpg image.jpg image.jpg
    Okie Pete, Tim, chryslerfan55 and 8 others like this.
  3. Nice job on the louvers! Like icing on a cake.
    Stogy likes this.
  4. plym_46
    plym_46
    from central NY
    Are you sure you want to run that fuel line that close to the exhaust manifold? Also there should be a sheet metal heat shield between the manifold and fuel pump. There is a template for a stock equivalent on the P 15 - D24 website either in the resource section or in the down loads area.
  5. rusty rocket
    rusty rocket
    I'll try it and see what happens. No hood sides and those killer louvers will dissipate all the heat.;)
    chryslerfan55 and rwrj like this.
  6. wizzard23
    wizzard23
    Mmmmmmmmmmmm mmmmmmm mmm louvers!
  7. rusty rocket
    rusty rocket
    Several folks had mentioned and I thought as well with the radiator sitting lower than the head I will get an airpocket in the cooling system. My thought was to get and inline radiator cap from speedway and install it in the top hose but I didnt have room to do that. I improvised by making a bung with a 1/4 pipe plug welded in the thermostat housing. Now I should be able to remove the plug and fill the top part of the system although it will be a slow process. image.jpg image.jpg
  8. Jet96
    Jet96
    from WY
    An old 1/4" brass ball valve would look cool there!
  9. rusty rocket
    rusty rocket
    Working in small baby steps. Today after work I got my brake light wired. I had a small l.e.d. light left over from a motorcycle build so I thought I would hide it under the clear parking lens. I know led’s aren’t traditional but maybe I won’t get run over. 009847BC-EC5B-491A-9313-17C3B79CF4C8.jpeg 95FC011F-74C4-4624-A9BC-6D9A8E6D2921.jpeg ECFB37CE-960B-42A9-B220-4FC028DFF8A9.jpeg
  10. Stogy
    Stogy
    :rolleyes:...Well that is just beyond Spiffy, Rusty...;)
    raven likes this.
  11. rwrj
    rwrj
    from SW Ga
    I like it. You've got that perfectly good lens sitting there, makes sense to put it to use.
    Stogy likes this.
  12. Texting and driving isn't traditional either so I think that more than cancels out LED bulbs and 3rd tail lights.
  13. Atwater Mike
    Atwater Mike
    Love the 'Third light' (er, 'second one'!) Being that the Art-Deco stamping of the parking-light fairing matches the stainless trim of the '46 'fender'...Consider nickel plating the fairing to match?
    ...and to echo @brEad, the little car does remind me of a '40s bumper car!
    Very inspiring story, I felt like I was right there!
    Clever use of angle, tubing, pipe (!) and rod. Inspired many on here, by the comments.
    How many are now imersed in One Man sprint types and gow jobs now? Show of hands, please?
  14. RodStRace
    RodStRace
    Love the thermostat fitting!
    With your strong fab work, I can see a funnel with a threaded end that screws into that, making fill ups and burping much easier.
    Stogy and chryslerfan55 like this.
  15. rusty rocket
    rusty rocket
    Hey thanks for the kind words it's been one hell of a fun project.
    chryslerfan55, patmanta and Stogy like this.
  16. rusty rocket
    rusty rocket
    I picked a color for the car! I originally was going to roll on Rustolium but I couldn’t get a shade I liked in there very limited color palette. I settled on a cheap Martin senior single stage. It is just a universal color but I’m going to call it It-L-Do maroon. I shot one photo in natural light and one with the sun shining in the window. 29D2EADD-C493-4A37-A7B1-E2335C3267AB.jpeg 7EA8673F-8816-4873-8372-20AF21D2F303.jpeg
  17. sodakmini
    sodakmini
    It will do...
    Greenblade, Stogy and brEad like this.
  18. rusty rocket
    rusty rocket
    It sure will. Getting so close to firing this thing up.
    Stogy, brEad and sodakmini like this.
  19. rusty rocket
    rusty rocket
    Made a bracket for the fuse panel and got it mounted up under the dash B0A74B93-55C5-4FB1-8800-E168A2868CC5.jpeg the other night also got the brake light switch wired and routed wires to the taillight through old cloth loom.
    chryslerfan55, 40two, Stogy and 3 others like this.
  20. rusty rocket
    rusty rocket
    Today I hope I got the last piece of my puzzle. I picked up an early dodge kick starter. My motor had a push button auto behind it but I used a 40 dodge pickup trans and flywheel I couldn’t get the auto trans starter to mesh with the standard flywheel so I’m hoping the old stomp starter will work. 21F19D06-BC41-4D60-B2C2-FA98AA1695C9.jpeg 3389F403-FC59-42EE-B2B2-D217CB235909.jpeg Plus the stomp starter is a lot smaller. Now to fab up a push button.
  21. plym_46
    plym_46
    from central NY
    The automatic probably has a thicker driveshaft flange to support the extra weight of the tq compared to the standard clutch setup. One person solved the problem by having the bell housing machined to allow for full engagement. If your earlier starter does not do the trick, you may have to consider that. He put a DeSoto engine that was set up for fluid drive in front of a standard using the 48 Plymouth bell housing.
  22. rusty rocket
    rusty rocket
    I bolted it all up this afternoon, hooked up the jumper cables,pushed the linkage and it engaged and started to roll the motor over. I think I'm golden!
    Hamtown Al, Stogy, brEad and 3 others like this.
  23. rusty rocket
    rusty rocket
    I’m going to try and use some Model A brake rod parts for my stomp starter linkage. I have a shift knob that I can thread to the top of the brake rod so I can push it down by hand rather than foot. 69B521B2-7127-4E5F-9D74-CD27C8D3037D.jpeg
  24. plym_46
    plym_46
    from central NY
    Will you be able to spring it or devise something to balk incidental or accidental engagement?
    Stogy likes this.
  25. rusty rocket
    rusty rocket
    Still thinking about how it will work, I'm thinking it will be up at the bottom of the dash so it shouldn't get pushed but I should think about some kind of lock out. Thanks for the suggestion.
    Stogy likes this.
  26. plym_46
    plym_46
    from central NY
    Maybe an offset at the engagement end and a twist T Handle at the top so it only engages when turned to a position meant to engage. Rudimentary theft deterent also.
    Then you could do away with keys. Battery isolator, hidden toggle for ignition, single position disguised starter actuator.
  27. rusty rocket
    rusty rocket
    This is what I came up with for the starter engagement. I don’t think it can get accidentally pushed. 51D8814B-B35B-4C10-BDD3-530779B4206B.jpeg FEFEA78F-67F4-4749-A833-327F1DE81DF4.jpeg 15EDF592-3BA8-4A97-AEDB-F29E35ADC60A.jpeg
  28. Nice! I will be doing something similar on mine if I ever get back to it...
    kidcampbell71 and Stogy like this.
  29. plym_46
    plym_46
    from central NY
    Man I don't know how you are resisting fireing it' up...
    Stogy likes this.
  30. rusty rocket
    rusty rocket
    Ha ha! Need to fill trans,rear end,motor and pull some wires(which I'm an absolute moron when it comes to wiring).
    Mid February is the local indoor car show in Rapid City my goal is to drive this turd pile into the show.
    chryslerfan55, raven, 40two and 4 others like this.
