Technical Welding drilled axle ??
Discussion in 'Traditional Hot Rods' started by 303racer, Nov 12, 2019.
  1. 303racer
    303racer
    Hey fellas , I have a partial drilled axle , and was wondering if it’s gojng to be a problem with heat to mig ( I don’t own a tig) the holes closed ?
    ( prefer undrilled)
    I shouldn’t need to make a jig should I ?
    I just want to be sure I don’t ****** it up. Thanks
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    Welding those wouldn't leave me with a great feeling of security, always wondering if it compromised the integrity of the axle. They're small, so how about filling them in with some epoxy, smooth and paint?
    DIYGUY likes this.
  3. 38Chevy454
    38Chevy454
    I ***ume that's an original axle? If so it is forged steel and you can weld the holes closed without any problems.
  4. 303racer
    303racer
    It is indeed original
    gimpyshotrods likes this.
  5. 6sally6
    6sally6
    I would suggest to pre-heat the axle before welding. When finished welding wrap in fire proof cloth and let cool sloooowly.......just to be safe.
    6sally6
  6. Thread the hole with fine thread.Cut a section from a bolt,or all thread of the correct size. ,and run it in.Leave it a bit low, in front and fill with lead ,or loc***e,and use bondo to level.
    X38 and The37Kid like this.
  7. seb fontana
    seb fontana
    from ct
    What?
    Hnstray and kidcampbell71 like this.
  8. Plug them.Hide the plug. No weld no heat worries.
  9. adam401
    adam401
    More than the holes in your axle your real problem is that your already getting real measurable snow at your house haha
    Tim, raven, 303racer and 1 other person like this.
  10. Torana68
    Torana68
    from Australia
    Lot of work to smooth that out after welding, so my first choice would be swap or sell and get another, second choice epoxy fill .
    X-cpe and kidcampbell71 like this.
  11. southcross2631
    southcross2631
    I cut my F-1 axle in two pieces narrowed it and stick welded it back together . I wouldn't get to concerned about welding up some holes.
    Try and trade someone for an undrilled axle and save a lot of time and effort. A DSCF3572.JPG guy gave me mine and it had a brand new disc brake conversion. He was going to a Mustang 11 front end.
    Should be plenty of them around
    kidcampbell71 and gimpyshotrods like this.
  12. raven
    raven
    I have an Non-drilled axle I would trade you.
    r
    kidcampbell71 likes this.
  13. 303racer
    303racer
    Shipping costs are very high
    And I bought this local , I have others that need straighted and could send out. ( again shipping cost )
    But this one is straight, And was the main reason for wanting to use
  14. Fordors
    Fordors
    Those holes are pretty small I don’t see any problems with welding. Weld it, grind the welds with some finesse so you don’t make things too ugly and finish any lows or pin holes with your favorite filler.
  15. Budget36
    Budget36
    I'd drill slugs, insert, weld, grind flush. But I live on the edge...;)
    X38 likes this.
  16. jaw22w
    jaw22w
    from Indiana
    I would check it for straight after welding. Weld equally on both sides.
  17. If you can’t mix those small holes closed and leave an almost flush weld pool behind(****** all cleanup needed) then get someone who can. Shouldn’t be a drama.
    fiftyv8 and Desoto291Hemi like this.
  18. 303racer
    303racer
    Ok judging from the responses it’s half mixed emotions
    Thanks for weighing in fellas
  19. krylon32
    krylon32
    from Nebraska
    I've welded holes that small in forged axles before. I preheat the area and tig weld with mild steel wire to minimize any porosity. I back the hole with a piece of br*** when welding. Let it cool naturally, don't rush it.
  20. error404
    error404
    from CA
    I'd use lock***e on the threads, and then just leave the cutoff bolt as flush as I can, and don't try to fill them in. Instead of holes, you'd now have "beauty accents" :D
    If you used stainless bolts, they would probably stay shiny. Might actually look good. Kinda like wood work with inlays of different colors/types of wood. Could even use br***, bronze, or copper if you wanted to add a bit of color.
  21. oldolds
    oldolds
    Thread them, short ****on head Allen bolts from both sides. Nice accent that would drive most people nuts as to why they were there
  22. thunderbirdesq
    thunderbirdesq
    Having done this several times in much more extreme cases (1” holes all the way across) in your case, I’d just hold a block of br*** or copper behind the holes, crank your mig up, and weld them closed. Should only take a few minutes to carefully dress them to invisibility with a die grinder or small flap disc.
    303racer, -Brent- and Maicobreako like this.
  23. Mr48chev
    Well the guy who actually does it for a living gave you the right answer from my viewpoint and that is pre heat it, weld it up and let it cool. I'd be finding some bolts that were the correct diameter to fill the holes and cut some plugs to fill the hole and do a lot less welding.
    I don't know where some of these other guys get their half baked ideas but I don't want them around my car with any tools.
    6-bangertim likes this.
  24. birdman1
    birdman1
    We welded on over the road truck frames for many years, no problems. I used to weld 3/4 ton pickup hubs on car spindles to get a full floating hub on the right front. When is the last time you saw a straight axle break???
