Technical cant idenitify my 48 Merc flathead engine
Discussion in 'Traditional Hot Rods' started by johnrfray, Nov 13, 2019.
  1. TAG ON BLOCK and the heads also upload_2019-11-13_18-23-45.png upload_2019-11-13_18-25-45.png upload_2019-11-13_18-23-45.png upload_2019-11-13_18-25-45.png
  2. flatford39
    flatford39
    Well the cylinders are 080 over, the mains are 030 over and the rods are 020 over. That's a rebuilding tag.
  3. HEADS ?
  4. Cliff Ramsdell
    Cliff Ramsdell
    Put a magnet to the head. I think that casting is aluminum.
    Cliff Ramsdell
  5. Steel cast
  6. Ebbsspeed
    Ebbsspeed
    Ford Barn has some info here:
    https://www.fordbarn.com/forum/showthread.php?p=975582
    Here's the pertinent info from that thread:
    Canada used 3 heads for '46-8, there's a C59A that is about like our 59a, presumably 1946 use, and for '47-8 a C7RA-A iron head exactly equivalent to USA 59AB, and the C7RA-B aluminum one with slightly higher compression.
    stillrunners likes this.
