Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. dumprat
    dumprat
    from b.c.
    IMG_1650.JPG And the shifter. Whittled out of some mysterious stainless On my little craftsman lathe, slower than I am used to but pretty relaxing for a Sunday morning drinking coffee and listening to some tunes. The taper doesn't really show in the pics. I will polish it later.
  2. dumprat
    dumprat
    from b.c.
    IMG_1669.JPG IMG_1670.JPG Still ****ing around with clutch linkage and all the other bits I need to have in the cab while maintaining room for me! I had to put a bunch more bend in the shifter and lower it a tad to keep my knuckles out of the dash. It's ergonomic as hell and visually weird which I think is great! I also got the e brake mount figured. I need to find some cheap rubber shifter boots or scrounge the wrecking yard for small leather ones.
  3. Lookin good Matt! Its getting there eh!
    I was in your area today and thought about msging you and coming by buy my kid had to be back for a xmas dinner.
    -Shiny
  4. dumprat
    dumprat
    from b.c.
    No worries.
    Picking away at the little tedious important stuff. Engine build and paint on the frame will be fun!
    29EHV8 and loudbang like this.
  5. Runnin shine
    Runnin shine
    dumprat, Jeff34 and loudbang like this.
  6. dumprat
    dumprat
    from b.c.
    I need to drill and tap the shifter for positive stops, but it feels *****in!
    Cam cores went to the grinder last week so once I get the convoluted mess of a clutch linkage figured out I am on to engine ***embly! Woo hoo!
  7. Six Ball
    Six Ball
    from Nevada
    It's been a long twisty road for you getting through the "evolution" of this but it has been educational for the rest of us.
  8. Langan
    Langan
    from Eagle ID.
    Just found your build, looks great. Thanks for posting. Its fun to follow a long.
  9. dumprat
    dumprat
    from b.c.
    IMG_1694.JPG Finally got to patching my really screwed up door. It needs beating and bashing but it's close. I should have put a full skin on it. I may one day in the future, it's not getting fancy paint so it will be easy to match. Thanks to @29Hiboy for wheeling the panel for me.
  10. dumprat
    dumprat
    from b.c.
    And I finally got my shrinker/stretcher mods done. I don't have room for a fancy stand with both machines mounted on it, and I only use it once every couple of years so I figured this made sense. It has multiplied leverage and the handle makes way more sense to me this way. And it's all made from cast off junk I had laying around the shop.
  11. Tim
    Tim
    from KCMO
    I can dig it, good idea
  12. Jethro
    Jethro
    Helicopter parts???
  13. dumprat
    dumprat
    from b.c.
    Nope. An old clevis, a rod end off a jeep sway bay disconnect, a couple of coupling nuts and some s**** plate
  14. Jethro
    Jethro
    Looks good, really increases the mechanical advantage.
  15. Lil'Alb
    Lil'Alb
    from brier, wa
    Whoa last time I looked at this thread this thing had a flathead 6, now a 330 Desoto? Score! Fills up that engine bay nicely. You're building an awesome hot rod, thanks for sharing.
    392
    Great build.
  17. manyolcars
    manyolcars
    I'm working on a 34 too but my cab is not as good as yours. :)
  18. manyolcars
    manyolcars
    What differences are there in length between a 34 and 35 pickup hood tops?
    The side panels have more curve at the bottom on 35 but what about the top?
  19. dumprat
    dumprat
    from b.c.
    35 truck is like 34 car
  20. 64krusty
    64krusty
    bring that door up when you get the 34 car stuff and I'll make it look good
  21. dumprat
    dumprat
    from b.c.
    @64krusty door still needs more beating. But I will take you up on that!
  22. dumprat
    dumprat
    from b.c.
    IMG_1719.JPG IMG_1721.JPG So a little side project to help my friend @29Hiboy .
    We have been rebuilding and setting up his two speed Halibrand champ quick change. It now has a DPI gold track and slip in 31 spline axles. We had to make a few tools and modify the adapters.
    Should be very cool on the road. Either 2.73 or 4.86 rear gears all shiftable from the drivers seat!
  23. patmanta
    patmanta
    from Woburn, MA
    HIS WHAT?
    I was today years old when I learned that existed and now I need one. That sounds amazing.
    BradinNC, loudbang, brEad and 3 others like this.
  24. dumprat
    dumprat
    from b.c.
    Ya it's a two speed halibrand 301 quick change. Has a shifter through the cover and a set of dog clutches to shift between gears. The gears need to be machined a little but it sure looks cool.
    BradinNC, loudbang, patmanta and 2 others like this.
  25. patmanta
    patmanta
    from Woburn, MA
    OK BUT HOW DO I GET ONE?
    ratrodrodder, loudbang and Stogy like this.
  26. dumprat
    dumprat
    from b.c.
    I suppose you could modify one. .
  27. patmanta
    patmanta
    from Woburn, MA
    Ok, so this is a homebrew? I have been looking and can't find any information or mention of this outside of your thread right here and I am thirsty for this knowledge! Looks like a few other guys are too.
    loudbang and Tim like this.
  28. loudbang
    check with @GearheadsQCE he should know what it is and maybe where you can get one.
    1947knuck and patmanta like this.
  29. kidcampbell71
    kidcampbell71
    ratrodrodder, loudbang and patmanta like this.
  30. dumprat
    dumprat
    from b.c.
    Sorry but it's not one of those. It's a Torrence calif. Halibrand 301 with an extension made for the spur case and the cover modified. It has a longer quill and pinion spline.
    Runnin shine, patmanta and loudbang like this.
