Projects Kicking the T bucket build
Discussion in 'The Hokey Ass Message Board' started by raven, Oct 8, 2019.
  1. alchemy
    alchemy
    Does it use side mounts at the bellhousing? If not, what keeps the engine from spinning out of its center mounts?
    Thor1, Just Gary and upspirate like this.
  2. raven
    raven
    When I’m done, it’ll have front, mid and rear mounts.
    Just haven’t finished them up, that’s why I said the pictures were a teaser. [emoji16]
    r
    Thor1, Stogy, loudbang and 1 other person like this.
  3. Tim
    Tim
    from KCMO
    I’ve seen a lot of them with side “torque arms” that more or less rest against the top of the frame rail but are not bolted on. I think @cactus1 roadster has a similar set up on his olds
    Thor1, loudbang and pitman like this.
  4. pitman
    pitman
    Parallel tail and pinion, w/3° 'misalign' or offset helps keep ujoints happy.
    Thor1, raven, loudbang and 1 other person like this.
  5. alanp561
    alanp561
    A car named "
    Praying Mantis" would probably be off topic since it has religious connations, right?
    Thor1, loudbang and Roothawg like this.
  6. pitman
    pitman
    Hmmm..."Velocepedia?" Fast-a-foot?
    Thor1 and alanp561 like this.
  7. raven
    raven
    Hmmmm, my wife suggested Venus Flytrap, you catching all the girls....
    r
    Thor1, Tim, loudbang and 2 others like this.
  8. raven
    raven
    Working on the mid-mounts after shoving the engine forward about 4 inches.
    r
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Thor1, Tall t 26, bchctybob and 6 others like this.
  9. raven
    raven
    And another test fit of the body.
    r
  10. Corn Fed
    Corn Fed
    I'm digging it! You so need to finish it for yourself.
    Thor1, pitman and loudbang like this.
  11. raven
    raven
    Trouble maker...
    r
    Thor1 and loudbang like this.
  12. Rocky
    Rocky
    Classified Editor
    394/slant-pan hydro........Jesus! That thing will be an animal!
    Thor1, Tim and loudbang like this.
  13. GuyW
    GuyW
    I ran a 371 Olds with 2-4s, headers and a hydro in a '34 Chevy truck (frame rails twice the size of these) and beat on it regularly. That Olds will twist that frame unmercifully if it isn't boxed and x-membered...
    loudbang, cactus1 and kidcampbell71 like this.
  14. raven
    raven
    As I have stated earlier in the thread. I’m no stranger to combinations as this. It will be stout enough for this motor when I am done.
    Don’t believe everything you hear, it can be done.
    r
    Thor1, pitman, bchctybob and 4 others like this.
  15. Would love to see some pics of this if you have any??? (We can start a convo so as not to muddy @raven ’s thread?)
  16. bowie
    bowie
    That’s shaping up to be a wicked *** bucket! The Olds sure looks like the fabled ****** race engine. Lookn’ forward to hearing her rev!
  17. raven
    raven
    It is ******’s motor and also am anxious to hear it run.
    r
  18. raven
    raven
    Started building the rear transmission cross member. It ties the front mounts for the ladder bars together adding strength to the frame behind the transmission. I’ll build a bolt in piece for the transmission tail, so that the transmission will be able to be removed without much trouble (won’t need to pull the motor).
    The cross member is open at the bottom for access to the front ladder bar bolts.
    r
    bchctybob, Thor1, tb33anda3rd and 7 others like this.
  19. raven
    raven
    Oh the ‘tabs’ at the rear are where my driveshaft hoop with mount.
    r
    Thor1, bchctybob, OFT and 1 other person like this.
  20. OFT
    OFT
  21. Tim
    Tim
    from KCMO
    Anything new?
  22. raven
    raven
    There has been progress but shortly after my last update all my drivers broke for some reason or another. One was an easy fix. The other, well let’s just say from now on my wife will be paying better attention to the temp gauge when she’s driving. Still trying to recover from that expense...
    r
  23. Tim
    Tim
    from KCMO
    Ouch. Sorry to hear that
  24. Wavetrain75
    Wavetrain75
    If you have ever cleaned your barn and found enough parts to build a car, you might be a redneck.
    Thor1, Just Gary, brEad and 3 others like this.
  25. raven
    raven
    Just might be...
    r
    Thor1, brEad and loudbang like this.
  26. Tall t 26
    Tall t 26
    Awesome work going on! Coming together.
    Great pics. Keep em coming.
    Thanks for sharing this build.
  27. justabeater37
    justabeater37
    Are you back on this yet?
  28. raven
    raven
    Slowly getting back into this project. Got this driveshaft loop in today.
    I’m questioning my windshield stantions...
    They don’t seem to line up with the body like I think they should.
    Question, does the original T dash sit at an angle or straight up and down? Mine seems to fit better at an angle but that leaves a gap at the bottom. Also, any way I try the stantions, they just don’t fit right.
    r
  29. raven
    raven
    Steering box is mounted.
    Still trying to figure out how to mount the body.
    r
    Tim, bchctybob, chryslerfan55 and 2 others like this.
  30. captainjunk#2
    captainjunk#2
    very nice build from parts in the barn ,im enjoying your progress
