Technical Best way to cover letters in grilles?
Discussion in 'The Hokey Ass Message Board' started by European Custom, Nov 19, 2019.
  1. European Custom
    European Custom
    Hi, i've a 46' buick eight grille in my 48' chevy business coupe (don't ask why :)) and i want to cover/hide the letters from it. What is the best way to do this? Filling with body filler (e. g. Bondo) and re-chrome?
  2. BJR
    BJR
    You can't chrome over bondo. You could fill and paint though. Is it pot metal or stamped steel? If steel you could fill with br*** or lead and re chrome.
  3. Hnstray
    Hnstray
    from Quincy, IL
    A good quality chrome shop would be the place to seek help.
    A method I ‘think’ could possibly work......the grille would first be stripped of chrome. Then copper plated. The letters filled with silver solder as it is compatible with the copper. The filled areas would be filed/sanded to an even surface, then copper plated again to cover the silver solder. The copper gets prepped for chroming and, voila’.........you have a non-denomination grille!
    Your chrome shop may have a better idea.....
    Ray
    swade41, BigO, john worden and 5 others like this.
  4. European Custom
    European Custom
    Thanks, good idea with copper and silver plating to fill the letters. I will try this.
  5. rusty rocket
    rusty rocket
    It could be stainless steel. A good fabricator could cut out the letters and replace with donor metal from another grill. Sand, polish and buff it back to shiney.
    BigO and 49ratfink like this.
  6. oldolds
    oldolds
  7. European Custom
    European Custom
    A donor Grille is hard to get here in europe, and i would guess that the copper and silver plating approach could be less expensive compared to buy a donor grille.
    Not so cheap as duct tape for sure :)
  8. lothiandon1940
    lothiandon1940
    I think the answer is to drop a Nailhead between the fenders and leave the grille alone.:D;)
  9. atomickustom
    atomickustom
    I believe any filling method will leave trace marks that will always show.
    Better bet is to cover the bar or cut it out & replace it.
    We aren't seeing the whole car - how would it look to mold the top bar into the body or hood & paint it body color?
  10. Hnstray
    Hnstray
    from Quincy, IL
    Regarding the 'ghost letters'...I thought about that and it is a possibility, but not necessarily a foregone conclusion. Depends on the person doing the work. Also, you mention covering the bar. I also thought about after I had posted, but did not edit the post...been busy this morning. However, using a copper or br*** sheet stock, one might form a nice shape that 'caps' the letters and if silver soldered around it's perimeter, the solder would make a nice fillet. Two pieces total....one per side.
    Installing a Buick engine, as suggested by @lothiandon1940 above is a really good idea!
    Ray
    lothiandon1940 likes this.
  11. goldmountain
    goldmountain
    Just leave it alone. Only old guys would notice it isn't a Buick.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  12. lothiandon1940
    lothiandon1940
    ........So true.:)
    Hnstray likes this.
  13. Bert Kollar
    Bert Kollar
    I doubt it is stainless steel
  14. john worden
    john worden
    from iowa
    Silver solder not silver plate.
  15. Jay71
    Jay71
    Hammer, dolly, elbow grease.
  16. Leave it and keep 'em confused! I had a "Fridgidare" badge on an old beater, I lost count of the number of people who said "I didn't know they made CARS as well!".
  17. I had a mate with a M***ey Ferguson decal on his Harley Superglide.............andyd
    BigO likes this.
  18. chopolds
    chopolds
    from howell, nj
    Copper plate, then solder ( any solder will do, even "body lead") then copper again and chrome. Not necessary to use expensive silver solder.
