Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Rich B.
    Rich B.
    from Portage,IN
    In that second pic the shrinker marks are visible to achieve the needed curve
    in the panel. I meant to add this pic of the bead roller. I use step dies to form the curved
    body line.
  2. Rich B.
    Rich B.
    from Portage,IN
    patch11.JPG patch10.JPG patch9.JPG patch8.JPG patch11.JPG More follow up pics.
  3. Rich B.
    Rich B.
    from Portage,IN
  4. Rich B.
    Rich B.
    from Portage,IN
    This car has been finished, an sold.
    Had to post a couple pic of Butch's ride. He is HAMB member. After
    many years, and miles he sold it this past year, and has 2 projects
    going now. He's the guy with the white beard.
    kidcampbell71, scotty t and loudbang like this.
  5. Stan Back
    Stan Back
    Speaking of doors (were we?) -- 30 years ago when we built the sedan in my avatar, I'd replaced/repaired the door bottoms. Now, after many trips to the salt, it's apparent that it's advantageous to put drain holes in the bottom.
  6. GordonC
    GordonC
    Nice fab work!
    kidcampbell71, loudbang and Rich B. like this.
  7. Rich B.
    Rich B.
    from Portage,IN
    • Stan Back: 28 Mercury Toledo Salon ? I like your at***ude! Lol
    Glad to see you made it to the Salt, it was on my
    bucket list.
    Rich
  8. Greg Rogers
    Greg Rogers
    Excellent work! I read your whole thread and will follow along.
  9. Rich B.
    Rich B.
    from Portage,IN
    I'll try to get back to the regular programing.
    More 16 gauge, and 3/4" sq. tubing, I had to repair some original floor
    around shifter area. I don't know if I mentioned before , but the
    Muncie 4 speed I'm using has the tail shaft off of a early Nova. They
    have an xtra set of mounting holes 2" foreward which helps with
    gear shift placement. coupe198.JPG coupe199.JPG coupe200.JPG coupe201.JPG coupe202.JPG
    Vic Walter, brEad, D-Russ and 7 others like this.
  10. Rich B.
    Rich B.
    from Portage,IN
    Made a hammer form for the trans cover. It will take 3 pieces to do the job.
    Heres the tools I used to beat the snot out of it. The cheap muffler gun has a
    quick release collar,and a 'planishing head' available on e-bay. It helps make a tight
    definition around the edges.
    After initial planishing it's close, still needs a little work. coupe203.JPG coupe204.JPG coupe205.JPG
  11. Rich B.
    Rich B.
    from Portage,IN
    I always knew I was going to cut the piece off here, but the hammer form had to
    shaped to get the proper form in this area.
  12. Rich B.
    Rich B.
    from Portage,IN
    Had to use 3 pieces to fill that area in, but happy with it.
    Made a little tool to counter sink the mounting holes. coupe209.JPG coupe210.JPG
  13. Rich B.
    Rich B.
    from Portage,IN
    Found this on a trip to the junk yard. It's from a 96 Chev Geo Metro. It has a built
    in stop, and return spring. They had 4 cars in a row, bought them all 20 bucks,
    already gave 2 to friends
    Second pic:
    This a new (old style) Flaming River Column that I welded a piece of 3/8" stock on
    that will index into a notch in the tubing welded to the firewall. coupe211.JPG coupe212.JPG
    Vic Walter, Lil'Alb, nunattax and 8 others like this.
  14. Rich B.
    Rich B.
    from Portage,IN
    This shows how the column indexes into the firewall piece which clocks it with
    the turn signal, and proper depth setting. There is a locking screw on the engine
    side of the firewall, plus the column drop.
    The gas pedal has been bent, with a tab welded to catch the cable carb linkage.
    There was grinding needed on bracket to get full stroke needed for carb.
    The round pedals did not give me enough room, so I fabbed new rectangular metal
    pads, to fit rubber pedal covers I found on line at Summit. I welded a spacer into
    the column drop to fit the new column, and added braces to the firwall that are
    not visible in this pic. I made a hold down for the rubber boot on the shifter. coupe213.JPG coupe214.JPG
    Vic Walter, Rathbone, brEad and 9 others like this.
  15. Rich B.
    Rich B.
    from Portage,IN
    I wanted to finish covering the rear suspension. This piece ties into the rear panel
    covering the tail lites. There is a removable cover for acess to tank sending unit,
    and fuel feed. The card board simulates battery box.
    This piece has inset removable plates to acess body mount bolts, and upper coil
    overs. Making card board template seal off p***enger compartment. Had to be
    in two pieces , would not fit as one large piece.
    brEad, D-Russ, Thor1 and 6 others like this.
  16. Rich B.
    Rich B.
    from Portage,IN
    I needed to fab a battery box, and a mount for it to sit in.
    Vic Walter, nunattax, Thor1 and 6 others like this.
  17. Rich B.
    Rich B.
    from Portage,IN
    I decided to go ahead , and make a battery box.
    I get most of my solid rivet supplies from Aircraft Spruce.
    I used #2 cable, and clear plastic for a vent line, none of this will be visible. coupe219.JPG coupe220.JPG
  18. Stan Back
    Stan Back
    The Toledo Salon was the lesser model. This is the sought-after Torpedo Salon.
  19. Blues4U
    Blues4U
    from So Cal
    Wow, amazing workmanship and vision. Fascinating thread!
  20. Rich B.
    Rich B.
    from Portage,IN
    I’ll have to Stan Back, and be corrected!
    I should have known better, Lol
    Rich
  21. Rich B.
    Rich B.
    from Portage,IN
    I wanted to add a pic that might show the steering column set up a little clearer. DSC00680.JPG
  22. Rich B.
    Rich B.
    from Portage,IN
    I had shown the steering stablizer attachment to the drag link. I
    didn't like it, and changed it around a little. These half coupling
    lock spacers are from the local Sears store. They bite into a standard
    size drag link tubing, and do not slip. The rest of the pieces are standard
    clevis, rod ends, etc. That is a small piece of drag link to set things up with.
  23. IowaMercMan
    IowaMercMan
    Subscribed, Rich. Wow.
    Walt
    Outsiders CC
    loudbang and scotty t like this.
  24. Rich B.
    Rich B.
    from Portage,IN
    I wanted to get an idea what shape to make the hood blisters, and the placement
    I wanted to visually see the blisters so I glued some particle board together, and
    shaped with the DA. Dusty, but shapes very easily.
    D-Russ, Thor1, oldiron 440 and 3 others like this.
  25. Rich B.
    Rich B.
    from Portage,IN
    More particle board glued together for the hammer form.
    I used .063 alum. for the blister. I'm anealing it with a soft torch
    flame to soften the aluminum. I had to do this several times to keep from
    D-Russ, Thor1, mkebaird and 5 others like this.
  26. Rich B.
    Rich B.
    from Portage,IN
    Cheap Harbor Freight planishing hammer, but it does the job.
    The foot ball shaped dolly in the vise is used to fine tune the blisters. The red
    laser dot shining on the dolly helps find the sweet spot. I picked that up from
    the guys on the Metal Meet forum
    Heres the laser stuck in a piece of 2 x 4 screwed to the ceiling
    brEad, Thor1, oldiron 440 and 4 others like this.
  27. Rich B.
    Rich B.
    from Portage,IN
    A202.JPG After a little prime, and block.
    Lil'Alb, nunattax, D-Russ and 10 others like this.
  28. Rich B.
    Rich B.
    from Portage,IN
    All the above is destined to be repeated in steel only larger !
    Great practice though.
    brEad, loudbang and scotty t like this.
  29. kadillackid
    kadillackid
    Wow...great build and craftsmanship..
  30. Rich B.
    Rich B.
    from Portage,IN
    I used epoxy primer, urethane single stage, and clear from Eastwood with a cheap
    gravity gun. I plan on shooting the frame with the same stuff. A232.JPG A233.JPG A234.JPG coupe192.JPG
    Lil'Alb, brEad, D-Russ and 8 others like this.
