HD powered Reverse Trike
Discussion in 'The Antiquated' started by '52 F-3, Nov 19, 2019.
  1. '52 F-3
    '52 F-3
    from Central PA
    I think this build meet's Webster definition of "antiquated", BUT not sure if it's HAMB friendly or not. It'll have a lot of used Pre-60's parts and not look like an 80's Street Rod.
    Basically I started with an idea to use this 37-38 Willy axle and knuckles, and build a Ed Roth inspired trike using a Harley Davidson Panhead engine. Ended up with a great deal on a wreck with a good Twin-Cam and ******.
    Body is being build from not matching 49 Desoto and 49'ish Chrysler front fenders,
    and hood and truck lid from a 50/51 Plymouth.
    bottom half of a 1920ish windshield
    Galaxy Tail Lights
    also a 1934 chevy dash
    using a 1959 edsel grille :)
    1961 Chrysler Imperial headlights[​IMG]
    Engine/Trans etc... pulled from a wrecked Harley Davidson
    Deuces, brEad, egads and 2 others like this.
  2. '52 F-3
    '52 F-3
    from Central PA
    those are Falcon tail lights...
    Deuces, brEad, Ron Funkhouser and 8 others like this.
  3. Damaged1
    Damaged1
    I love the vision of people on here. NEVER would have come up with a cool idea like this. The fenders look like they were MADE for this application.
    '52 F-3 likes this.
  4. '52 F-3
    '52 F-3
    from Central PA
    engine/trans as I got it... and after a couple weekends. 20190817_154133.jpg
  5. pumpman
    pumpman
    Gonna watch this one for sure.
    '52 F-3 likes this.
  6. '52 F-3
    '52 F-3
    from Central PA
    so I couldn't decide between one seat or two, I thought a single seat would sit higher than looked "correct" with a steering wheel, so motorcycle handle bars would need to be used. But i really wanted to use this this steering column etc... from a Econoline.
    also I converted (oblong holes) pattern from the willys 4 on 4"(101.6) to a metric wheel pattern of 4x100mm because. 3 reasons, I found some VW rotors and these wheels at a good deal.
    1 issue was they are too wide so remove 4" of back spacing. Other issue is they are billet, not sure what to do about that yet... the big *** weld bead helps some
    Ron Funkhouser, egads and Okie Pete like this.
  7. '52 F-3
    '52 F-3
    from Central PA
    was going to widen and extend Harley swingarm but couldn't find an affordable wide wheel. Ended up buying this Hayabusa swingarm and wheel.
    Widened it 2", welded in some 6" extenders and made a 3/4" spacer for the extra large sprocket to keep chain off the tire...
  8. '52 F-3
    '52 F-3
    from Central PA
    mounted the 16" truck tire and continue working on 1x2 frame.
    Deuces, brEad, Ron Funkhouser and 3 others like this.
  9. pumpman
    pumpman
    Out of my wheel house but really dig it.
    '52 F-3 likes this.
  10. '52 F-3
    '52 F-3
    from Central PA
    Frame structure done, reused Harley Davidson rear shocks/springs and upper mounts. Also front suspension with F-350 sway bar mostly complete.
    Deuces, brEad, Ron Funkhouser and 2 others like this.
  11. '52 F-3
    '52 F-3
    from Central PA
    Used 38 dodge upper shock mounts, look similar to F-1's (not as tall) and decided to got with a rack n pinion from a 70/71 pinto.... after cleaning up the axle, leaf springs, control arms mount brackets I'm considering Nickle plating similar to some of my Pea Green parts.
    If anyone sees issues or possible problems (especially with from front suspension) please comment, i'm kind of making this one up as I go.
  12. '52 F-3
    '52 F-3
    from Central PA
    worked on rear a little this morning, still trying to figure out inner fender wheel area...
    Deuces, brEad, kidcampbell71 and 3 others like this.
  13. '52 F-3
    '52 F-3
    from Central PA
    Got some actual new sheet metal from a friend, thanks Mike. Was even pre-rolled with Rex's approval. Plan to use for tunnel, inner fenders etc...
    brEad, Ron Funkhouser and Okie Pete like this.
  14. SnakePlissken69
    SnakePlissken69
    Man I wish I had your skill, imagination and money! That thing is coming together awesome. Def bookmarking this thread!
    '52 F-3 likes this.
  15. '52 F-3
    '52 F-3
    from Central PA
    my imagination in much better than my skills or money, but i'm getting better...
    next is behind seats and tunnel...
    Deuces, brEad, Ron Funkhouser and 5 others like this.
  16. pumpman
    pumpman
    This is really turning out great!
    '52 F-3 likes this.
  17. Man that thing is so awesome! :D
    '52 F-3 likes this.
  18. Cool. Subscribed.
    '52 F-3 likes this.
  19. IowaMercMan
    IowaMercMan
    Man you really have the creative vision. Still watching Pea Green....
    Walt
    Outsiders CC
    '52 F-3 likes this.
  20. '52 F-3
    '52 F-3
    from Central PA
    Nothing exciting going on, using 16 gauge for the inner floors (pretty ugly, trying to use every inch, leg room is going to be minimal. Plan to mount the idler sprockets tomorrow and build a "chain guard/cover"...
    also using seats from a transit van.
    Deuces, brEad, Okie Pete and 2 others like this.
  21. '52 F-3
    '52 F-3
    from Central PA
    thinking about exhaust... have 3 ideas, none
    are good :(
    bolts are so I can remove body to paint.....
  22. dirt t
    dirt t
    I'm not a cycle guy, I love your vision.
  23. '52 F-3
    '52 F-3
    from Central PA
    Worked on the structure up front a little bit. the 3/4 x 3/4 square tube I'm using bends pretty nice if you go slow.
  24. '52 F-3
    '52 F-3
    from Central PA
    1/2 the firewall done and thinking about grill/headlight ideas...
    Deuces, brEad, kidcampbell71 and 4 others like this.
  25. dirt t
    dirt t
    Thank's for sharing.
    '52 F-3 likes this.
  26. woodbutcher
    woodbutcher
    :D Looks like things are coming along just fine.I`ll saddle up and go along for the ride.
    Good luck.Have fun.Be safe.
    Leo
    '52 F-3 likes this.
  27. '52 F-3
    '52 F-3
    from Central PA
    Made some mounts for unknown windshield frame and then redid cowl to match. still thinking about grill and shell, just not liking it....
  28. '52 F-3
    '52 F-3
    from Central PA
    haven't been happy with grill progress, so started placement of gas tank and it won't fit were I planned even with major modifications. So set it all aside and decided to try to make some front fenders.
    have been saving the left and right side of trunk lid for this, rolled some 1/4" round rod and made a wooden "die" to ***ist forming. Might end up a hot mess, but "I have a plan".....
  29. Cliff Ramsdell
    Cliff Ramsdell
    Drag pipes straight up? Maybe a slip in baffle for good measure? ;)
    Cliff Ramsdell
  30. Cliff Ramsdell
    Cliff Ramsdell
    How about an Edsel horse collar grill? Just a thought. I’m not a photoshop guy.
    Cliff Ramsdell
    Deuces, Okie Pete and '52 F-3 like this.
