Technical what year?
Discussion in 'Traditional Hot Rods' started by backrodebob, Nov 21, 2019.
  1. backrodebob
    backrodebob
    Ok flathead guru's I need help! I have a 29 ford model A with a 49-53 flathead, is there anyway to tell exact year other then #'s stamped on block? the only # I can see is something that looks like a 2....
  2. leon bee
    leon bee
    The ones I've had, no. Not that many, but I've found no useful markings. It hardly matters except for one thing: the last ones, many didn't have valve seat inserts.
  3. Texas Webb
    Texas Webb
    Van Pelts has the info.
  4. clem
    clem
  5. backrodebob
    backrodebob
    Hey guys, I narrowed it down to a 49, thanks for your help! Learning more about these flatheads every day.....
  6. clem
    clem
    Now for the pictures...........?
  7. backrodebob
    backrodebob
    Tim, KoolKat-57 and dwollam like this.
  8. rustydusty
    rustydusty
  9. It doesn't really matter because they're basically unchanged throughout the last years, but someone already mentioned Van Pelts and you figured it out. Mine had a factory relief for the valve to cylinder area and valve seat inserts. Some do not have that. All of the parts will interchange.
  10. backrodebob
    backrodebob
    yup! I found that out!
  11. backrodebob
    backrodebob
    Have any of you repaired a spark plug threads while head on the engine?
  12. deathrowdave
    deathrowdave
    from NKy
    Yes I have , not sure it’s the correct type of repair . But when your bike blows a plug , what else are you goin to do ? I greased up the drill bit and tap and cleaned with carb spray , lock tight on the insert . Screw the plug in and light the brute and go man go .
