New Banger block in the works.
Discussion in 'The Hokey Ass Message Board' started by 58custom, Aug 11, 2011.
  1. 427designer
    427designer
    from Ohio
    Here are the pictures of the first B head samples. One of the deck side and one of the top of the other. These are right out of the sand before clean up, heat treat, and shot blast.
    These two heads are aluminum and are not spoken for yet. If someone is interested, let me know. I have 4 or 5 iron ones to make asap.
    Tod
    KiWinUS, Dannerr, waxhead and 2 others like this.
  2. 427designer
    427designer
    from Ohio
    Making some progress, despite being pretty busy.
    KiWinUS, Smjacob, woodz and 12 others like this.
  3. 427designer
    427designer
    from Ohio
    First B head in iron. Can't wait to machine it and get it on an engine.
  4. belair
    belair
    congratulations.
    kidcampbell71 likes this.
  5. rottenleonard
    rottenleonard
    Really enjoying this thread Tod, thanks for the ride.
    I've sort of lost touch on the aluminum block is it still going to happen? If so when do you figure they will be available roughly?
  6. Wow Tod you are fantastic, even though I don't mess with 4 bangers I greatly appreciate those who put forth the effort to keep it alive. Once again thanks..........even though I spent the last coupla hrs going through this thread
    427designer and kidcampbell71 like this.
  7. 427designer
    427designer
    from Ohio
    Yes, the aluminum blocks are happening. I have a 3 main in the machine that may need a home. I have a 5 main sample that is going to be replaced with a block from the new sand process, and it will need a home eventually. The next block to get machined belongs to crazydaddyo.
    Tod
    Crazydaddyo, BlueHeart and town sedan like this.
  8. 427designer
    427designer
    from Ohio
    Let's not get carried away. This is my job, so it is nothing special. Once I get the Model A blocks going I hope to get my new 8BA V8 underway.
    Tod
  9. haileyp1014
    haileyp1014
    from so cal
    How long before speedway knocks these off?
  10. RussTee
    RussTee
    hows the progress Tod on both the blocks and overhead valves
  11. 427designer
    427designer
    from Ohio
    Moving along though slowly.
    Tod
  12. Big John M
    Big John M
    from New York
    Tod,
    Any of the aluminum heads still available ? Pricing if available ?
    Thanks John
  13. Colonial Coupe
    Colonial Coupe
    What's the advantage of using Chevy 283 pistons in a Model A rebuild.
    Thanks
  14. 427designer
    427designer
    from Ohio
    Which head are you interested in?
    Tod
  15. 427designer
    427designer
    from Ohio
    A builder could better answer that, or Snyder's.
    Tod
  16. Colonial Coupe
    Colonial Coupe
    Thanks, found a bunch of info over on ford barn. Interesting subject. Sold my 30 coupe almost 30 years ago, there wasn't much information back then before the www. Got a 28 coupe now and we're going to have some fun with this 4 banger. Thanks to you and others making new speed equipment for them. I talked with the guy that does the Burns intakes at Hershey very helpful and lots of good tips. Of course I now have one of his setups. In the process of replacing the matching number motor with a mule motor so I can go through it.
    kidcampbell71 and lothiandon1940 like this.
  17. J'st Wandering
    J'st Wandering
    Inquiring minds want to know. Why put 283 pistons in a Model A?
  18. azmodela
    azmodela
    from Tucson, AZ
    They fit almost perfectly for one. Main reasons: shorter skirt, lighter, and they use modern rings.
  19. drtrcrV-8
    drtrcrV-8
    Also (usually!) stronger , &, when you buy a set , you can do 2 Model "A" motors! LOL!
    Okie Pete, Outback and Colonial Coupe like this.
  20. J'st Wandering
    J'st Wandering
    Thank you for the information. Now I just need to remember it!
  21. rottenleonard
    rottenleonard
    Are they using the model A rod?
  22. Colonial Coupe
    Colonial Coupe
    Yes but you have to Bush the small end for the difference in pin size. Snyders is supposed to sell a rod that works out of the box but I haven't checked into it yet.
    Dannerr and kidcampbell71 like this.
  23. 427designer
    427designer
    from Ohio
    Here is one of the aluminum B heads in the fixture so I can get it set up and ready to write the program for machining it. Also setting on an aluminum 5 main block. Tod b bead in fixture.jpg B head and block.jpg
  24. Crazydaddyo
    Crazydaddyo
    Is this a new block casting too?
  25. 427designer
    427designer
    from Ohio
    This is not the one that I am making from the newest process. That will be made soon. I was ready to take sand to the foundry but the owner had to go out of town. The new process will be nicer.
    Tod
  26. 427designer
    427designer
    from Ohio
    OK, here we go with the first aluminum 5 main block just out of the sand. After talking to the foundry, it sounds like I need to provide for chilling a few spots, but for the first attempt in a new molding and pouring method, I think it looks pretty good. Can only get better from here on.
    Tod
    Okie Pete, KiWinUS, Smjacob and 19 others like this.
  27. wheeltramp brian
    wheeltramp brian
  28. drtrcrV-8
    drtrcrV-8
  29. Genes12320
    Genes12320
    any update on aluminum 5 main block availability?
