Motion Pictures Small block engines, Picture thread
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Dec 18, 2018.
  1. 56sedandelivery
    56sedandelivery
    This right here, this right here, this right here, is what the makers of ****** were attempting to accomplish!!! I can't think of another thing that would work as well, for me anyways!!! I have ALL the parts to ***emble this same engine, right down to the air cleaners. Simple and beautiful, and I don't care that there are better setups available now. One of these days.........................................I am Butch/56sedandelivery.
  2. loudbang
    TWO LOL The Freight Train
  3. Sky Six
    Sky Six
    from Arizona
  4. loudbang
  5. loudbang
  6. vetteguy402
    vetteguy402
    from omaha, ne
    Deuces, loudbang and enloe like this.
  7. loudbang
  8. loudbang
  9. Boneyard51
    Boneyard51
    Pertty close to this car???
    Bones
  10. loudbang
  11. DDDenny
    Deuces likes this.
  12. Deuces
    Deuces
  13. loudbang
  14. DDDenny
    Thanks man!
    Deuces likes this.
  15. Deuces
    Deuces
    No problem.....
  16. loudbang
    318 wide block ?? Wide block
  17. impala4speed
    impala4speed
    I believe that all the 318's, either the old poly wide blocks or the later LA blocks, had the distributor in the back LB. So this one might be a 361 or 383? Mopar had some other lesser known big block displacements like a 350 and maybe a few others. Great picture.
    das858, Deuces and loudbang like this.
  18. loudbang
    I thought it looked like that but that "wide block" was the caption.
    loner2 and 1947knuck like this.
  19. loudbang
    Y Block Looks like maybe Oz or New Zealand with right steer and all the safety "fences"
  20. loudbang
  21. loudbang
    1962 Chevrolet fuelie-327 Corvette-engine
    loner2, 1947knuck, treb11 and 5 others like this.
  22. Tickety Boo
    Tickety Boo
    from Wisconsin
    Goal to make 350 look more traditional 327 sleeper in a 1964 Chevelle, 11-23-19.JPG Found out the raised rail Vortec heads with valve cover adapters have enough room to hide a stud girdle under the 327 valve covers.
    Then drilled the summit Holley square bore Vortec intake for front oil fill tube and tapped a 3/8 hose ****** in rear for crankcase vent.
    Made a smaller air cleaner base and K&N filter to fit a Holley and leaves about a 2" opening around the bottom of a stock lid for more air.
  23. Mike VV
    Mike VV
    from SoCal
    Does this one count ?
    While it IS big on the outside, it's only 259 inches on the inside ! Still not running yet, should be by early summer.
    Mike
  24. loudbang
  25. SquintBoy
    SquintBoy
    Here's one Butch56 & maybe loudbang should like. It's my '56 265 Power Pack with solid 097 cam. It runs so nice with the early Rochesters and progressive linkage that I'm not going to look for another 4 barrel with air cleaner (have one of each), linkage and snowflake manifold.
    Sent from the red phone
  26. Stephen Barrett
    Stephen Barrett
  27. rumblegutz
    rumblegutz
  28. loudbang
