Customs which car would you have saved?
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Sep 3, 2017.
  1. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    When better cars were built, Buick built them!!!
  2. I never owned a Buick car, but I had a 54 Century engine with a 3 speed, in a 47 Chev, and that engine was indestructible. I over revved it once, (missed a shift), and the valve kissed the piston blowing everything apart above the piston pin bosses. There wasn't a scratch in the cylinder. I put in a new piston, and I was good to go. The nailheads were my favourite engine ever.
    Bob
    Bowtie Coupe and tb33anda3rd like this.
  3. tb33anda3rd
    tb33anda3rd
    while working on the valve covers I found out these were held on using studs and nuts. I was told 54 was the only year that the nail head did this. all of the others used two bolts to hold the covers on.
    Bowtie Coupe likes this.
  4. tb33anda3rd
    tb33anda3rd
  5. tb33anda3rd
    tb33anda3rd
    and for the record, this screw is left hand threaded. I tried and tried to get it off gently. sometimes a stuck bolt will come loose by trying to tighten it, so I turned it clockwise. it gave a snap and turned, I thought I broke it. I twisted it back and forth and then realized it was not normal. IMG_8118.JPG
  6. stillrunners
    stillrunners
    from dallas
    The one that all the numbers matched....body went down the road but still have most all the numbers stuff...it was the 80's and we never thought it would be a big deal....also my 1956 frame with a little Hemi engine modification....could have fixed that - it was the original for my Fury but my parts car had a stout 277/overdrive - so that's what went under it.
  7. tb33anda3rd
    tb33anda3rd
    update on the little 54, I put brake fluid in the master and it ran right out. I put it on the lift and found a newer piece of brake line someone spliced in with a compression fitting. the line was rusty, as were all the lines. I removed all the steel lines and started replacing them all. IMG_9270.JPG IMG_9271.JPG
  8. BamaMav
    BamaMav
    from Berry, AL
    I’ve seen that done before, sometimes it works, sometimes it leaks. I always replaced them when I found them too.
  9. tb33anda3rd
    tb33anda3rd
  10. The37Kid
    The37Kid
    ^^^ Nice Christmas present for both of you! Merry Christmas. Bob
  11. tb33anda3rd
    tb33anda3rd
    merry Christmas!
    kidcampbell71 and biggeorge like this.
  12. low budget
    low budget
    from Central Ky
    Whats next? Back to your other cars? got pics?
  13. tb33anda3rd
    tb33anda3rd
    still want to find a Buick motor for the 31 coupe I have.
