Technical ***November 2019 Banger Thread. Really? Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 31, 2019.
  1. V4F
    V4F
    from middle ca.
    john , IMHO you are one of the knowledgably & sharing people I know . you have helped me so many times .
    never seen your work before …………. awesome work ………… thanks much ……….. steve
  2. Thanks for the kind words,
    now for some ****?!? this one did 179.5 mph at Bonneville last year while burning out the valve seats. IMG_0236 reduced.jpg
    Dannerr, Lil'Alb, Crazydaddyo and 9 others like this.
  3. V4F
    V4F
    from middle ca.
    just amazing
  4. poshdbs
    poshdbs
    What head is this one now John? Fantastic.
    The water pump on the Dodd looks similar to a Dan Price one.
    Sent from my SM-A320FL using The H.A.M.B. mobile app
  5. poshdbs,
    I think you are right Dan Price might make that pump.
    This head is a highly modified Moller casting. It is a monster, I sheared off the driveshaft in the dyno with it.
    Needless to say, it only goes down course anymore and I just work on refining the tune from there.
    John
    Jet96, Old Dawg and poshdbs like this.
  6. V4F
    V4F
    from middle ca.
    but it goes darn fast
  7. V4F
    V4F
    from middle ca.
    model a people . talking stock A . has anyone ever tried to set valves & not be able to ? lifters not coming up enough to get ahold of lifter body or adjustment nut ……………. help please if you can ………….. steve
  8. wheeltramp brian
    wheeltramp brian
    Dannerr, Lil'Alb, BigO and 9 others like this.
  9. JT1930
    JT1930
    Farewell banger friends. It was fun while it lasted.
  10. railcarmover
    railcarmover
    Did the banger sell yet?
  11. rudestude
    rudestude
    You probably got your clamp ordeal taken care of already but another place to find that type of clamp is on some old oil bath air cleaners ...some are flat but I have had some that were V shaped..here's kind of a cool one if a quik release would help, this one is from dairy farm milking equipment.
    The small one with the thumb screw is a aircraft one.
    Sent from my SM-T387V using The H.A.M.B. mobile app
    Dannerr, poshdbs, G Baese and 2 others like this.
  12. JT1930
    JT1930
    @railcarmover got a guy interested and said he’s coming for it this weekend. We’ll see.
  13. railcarmover
    railcarmover
    Heres to it happening,you can sink the dough in hopping up the flattie...its never enough you know,its just like doing dope...
  14. JT1930
    JT1930
    Oh I’ve already got stuff coming. Sharp heads, a cam and dual carb intake.
    Garagekulture13 likes this.
  15. No, that's an A-6019-BR cover which was supplied to service for Model A's after 1932 Model B production began.
    On the B timing covers, the timing pin hole is higher.
    You can time an A engine with a b distributor with an A timing cover though.
    Dannerr likes this.
  16. Crazydaddyo
    Crazydaddyo
    Pretty close to coil bind there. ;):eek::D
    Old Dawg likes this.
  17. railcarmover
    railcarmover
    upper neck,repop 28/29 radiator..soldered in crooked,the solder barely held the right side in.Fix that original radiator,I've had good luck back flushing them with an industrial hot water/chemical pressure washer, saved a few that way.
  18. Na, can go another .050
    Those springs couldn't keep up, went to the 1.6 dia big block springs and picked up some revs.
    All good, hey did you get your block yet?
    John
  19. Jiminy
    Jiminy
  20. Crazydaddyo
    Crazydaddyo
    "soon" :mad::rolleyes::(
    At this rate, Terry Burtz's project will get one to me first.
    waxhead likes this.
  21. jim1932
    jim1932
    poshdbs likes this.
  22. poshdbs
    poshdbs
    Thanks, I hope to be sorted on this. A guy on here is sending one to me.
    rudestude likes this.
  23. Jalopy Banger
    Jalopy Banger
    from Sweden
    I made a jigg to copy the B hole on a A timing cover. Can´t find the picture right now, but from the edge of the A´s thread hole to the punch mark for the B thread hole, it is 0,231"
    and from center of the A´s thread hole to the punch mark, it is 0,375"
  24. Jalopy Banger
    Jalopy Banger
    from Sweden
    Dannerr likes this.
