Projects 60's Era Street/Strip Model A Coupe
Discussion in 'Traditional Hot Rods' started by -Brent-, Aug 1, 2019.
  1. -Brent-
    -Brent-
    Ryan made this stand/cart to move the engine/trans around.
    The pics were pretty neat of the motor so I figured I'd share them. The engine is an ol' worn 283.
    Ansen Bellhousing Autogear M23 Dual Quad 283 Headman Headers Hurst Weiand.jpg
    Looking at the above pic has me really wanting to figure a way to rework this side header so the outlet is angled forward and it clears the steering box. I think with a little finesse it could happen.
    The bellhousing is an Ansen blowproof. The trans is an Autogear M23. Headers vintage Hedman. The front mount is an original Hurst. Intake is a Weiand WCV 283.
  2. You simply must make the Hedmans work...
    or sell them to me!
    31chevymike, Chris, mad mikey and 6 others like this.
  3. -Brent-
    -Brent-
    I've been looking at them with solving the fitment problem, in mind. It's possible and probably less expensive than replacing them with something else.
    They collector needs to be tilted, say at a 45 and moved forward a few inches and maybe up a bit.
  4. It will be worth it!
    mad mikey, brad2v, loudbang and 2 others like this.
  5. T&A Flathead
    T&A Flathead
    Damn good stuff going on here.
  6. wrenchbender
    wrenchbender
    Been following along and dig your build and so far have understood why you are doin things the way you are honestly never thought about the narrowed fenders that’s a new one for me but it does look real good the one question I have is do you have the lower collector for the headers I am curious to see what they look like
  7. -Brent-
    -Brent-
    The fenders are pretty uncommon. There was a lot of modifying and chopping up going on but I think Maratta was onto something with the Missile. His fenders, because they looked rather stock, probably didn't get a second look by many, including the guys inspecting the car.
    I don't have the corresponding ends for the Hedmans. If I end up running them, my plan was to get some stainless flanges cut for the down pipes to continue on.
  8. wrenchbender
    wrenchbender
    Right on will you keep them individual and run two pipes on each side or will you run them into one on each side just curious as I am in the middle of making a set much like that I’ve seen them in the past and thought they were kool so I started fabricating a set to fit my application but wasn’t sure how to run them out the back
    31chevymike, mad mikey, Thor1 and 2 others like this.
  9. -Brent-
    -Brent-
    For simplicity's sake, my plan is to run one on each side, exiting under the running board.
  10. dumprat
    dumprat
    from b.c.
    The sound with four pipes per side would be crazy. Might be crazy loud too though.
  11. -Brent-
    -Brent-
    Starting the body mount process:
    Got to pop a hole in here to make putting a bolt in easier. Later on we'll make a relief or a cap or something.
  12. Tim
    Tim
    from KCMO
    Ohhhhh about to get awesome! This mock up is going to rule!
    31chevymike, mad mikey, enloe and 4 others like this.
  13. Hotrodtoms
    Hotrodtoms
    Please tell me there's a picture of the body on and the fenders mocked up surfacing today?
    Sent from my CLT-L09 using The H.A.M.B. mobile app
  14. manyolcars
    manyolcars
    Information from the archives show that Henry did not put bolts thru the body and frame at the firewall. He said the body needed to be able to flex there
    loudbang and -Brent- like this.
  15. -Brent-
    -Brent-
    I have pulled bolts from that location from a few cowls.
  16. 6sally6
    6sally6
    [​IMG]Where is the crank snout and lower pulley?!
    1947knuck, enloe, Thor1 and 3 others like this.
  17. -Brent-
    -Brent-
    @6sally6 love the Freakin' A! Same mock-up motor, different headers. Those headers are similar but the collector is situated 90* different than my current Hedmans.
    The Freakin' A also runs a Vega or Corvair box... so that frees up some space.
    1947knuck, mad mikey, enloe and 3 others like this.
  18. manyolcars
    manyolcars
    I have too.They may have been added and its possible the info was for 28-29.I searched Fordbarn but couldnt find that post today
  19. -Brent-
    -Brent-
    I appreciate that effort! As Ryan and I have both said, this is "race car sh*t". The chassis and body will be far-and-away more stiff than the stocker ever was.
    Plus, as far as Henry goes, if he were around, we'd already have turned him off with the drivetrain. Haha.
    1947knuck, mad mikey, Thor1 and 2 others like this.
  20. -Brent-
    -Brent-
    ... and speaking of drivetrain, a couple important packages showed up (on a Sunday!): A posi, 3.64 gears, and a build kit for the rear. I have an empty 1962 housing in the garage, so I'll haul it over to my pal whose done a couple other thirds for me.
  21. -Brent-
    -Brent-
    This is just a mock-up. The car was never finished. It is for sale though.
    1947knuck, mad mikey and loudbang like this.
  22. -Brent-
    -Brent-
    The kid in me is psyched!!!
    It's not a full mock-up. Just enough to get the body correctly in place.
    First person I sent this pic to was Matt. The rear bob is perfect in my opinion.
    It'll likely sit a bit higher than this on the A spring. I'm thinking I may have to get one with a reversed eye main leaf.
    The stance will be different... imagine it with some rake.
  23. Stovebolt
    Stovebolt
    Ooo La La @-Brent-
    You had me at "It's not a full mock-up."
    One bitchin hot rod there Mr.
  24. mad mechanic
    mad mechanic
    HUBBA HUBBA! *cartoon heart pumping out of chest*
    As we say in the south west of England..." Gert Lush in 'um!"
    That Sir, is a fine looking automobile....
  25. Stogy
    Stogy
    Lickety Slick...Get up Stance is notable and it is a very 'A' Proud Coupe...I feel that Talking...that's inspiring @-Brent-
  26. 427 sleeper
    427 sleeper
    Man!!! That is one Tuff lookin' A-Bone!!! I love it!!! [emoji41]
  27. dumprat
    dumprat
    from b.c.
    Are you narrowing the rear?
  28. -Brent-
    -Brent-
    Actually, the rear has been narrowed 6". It came out of this 59 Pontiac.
    It's big, now, but it was way too big, before. Haha.
    I stripped it down and had it blasted.
    Then, a pal narrowed it and put new Pontiac ends on it. Looking back, I should have used Ford ends and saved myself some money on brake parts.
    Here it is, looking "skinny".
    This is just about what an Early Bronco 9" measures.
    The Maratta Missile's rear is a similar width and that car has been an influence.
  29. kidcampbell71
    kidcampbell71
    Damn. Dat' ass ... ^^^^
  30. -Brent-
    -Brent-
    More mock-ups: F1 Steering Box and Column
    Got the F1 Steering box set into place and a steering wheel mounted to figure best placement.
